Home » Newcomers » Newcomers » Plugin auto-update mechanism
Plugin auto-update mechanism [message #169213] Mon, 04 September 2006 02:49 Go to next message
Originally posted by: wolfgang.moestl.softwareag.com
How do you implement an auto-update mechanism for a self written plugin?
My plugin is distributed using the standard eclipse updatesite mechanism.
If there is a newer version available on the update site, I want to
display the user a little "Hey, there is a newer version available, do you
want to update?" dialog with an "Update now" button.
I played around a bit with org.eclipse.update.core.SiteManager but that
didn't look the right way.
Is an OSGI code snipet out there?
Thanks a lot!
Wolf
Re: Plugin auto-update mechanism [message #169263 is a reply to message #169213] Mon, 04 September 2006 10:39 Go to previous messageGo to next message
Hi Wolf,
If you go to Help -> Software Updates->Find and Install a wizard is
opened. The first page of this wizard has two radio buttons.
The first button is the "Search for updates of the currently installed
features".
You can check the code of this wizard.
org.eclipse.update.internal.ui.wizards.InstallWizard. (It is located in
org.eclipse.update.ui plugin).
kiril mitov.
Wolf wrote:
> Thanks a lot!
> Wolf
Re: Plugin auto-update mechanism [message #169270 is a reply to message #169263] Mon, 04 September 2006 10:41 Go to previous message
You can start the update process when a plugin of your is activated. Maybe
in the activator class.
kiril mitov wrote:
> Hi Wolf,
> features".
> kiril mitov.
> Wolf wrote:
>> Thanks a lot!
>> Wolf
Previous Topic:Built in J2SE API Doc?
Next Topic:auto import
Current Time: Sun Aug 31 14:38:57 EDT 2025
Powered by FUDForum. Page generated in 0.06940 seconds
