Callisto doesn't work [message #169079] |
Sun, 03 September 2006 04:00  |
hello
The plugin installation with callisto doesn't work anymore under linux. If
I choose a plugin in the update dialog and try to download it than I
receive always the following dialog-box:
An exception occured while downloading feature from
" http://download.eclipse.org/callisto/releases/features/org.e clipse.cdt_3.1.0.200606261600.jar"
Do you want to retry?
But I can download the file manually.
There is the same problem with other plugins too. But for example the
installation of the subclipse plugin with an other url than the callisto
download url works fine.
Eclipse: Version: 3.2.0, Build id: M20060629-1905
Tested with Sun JDK 1.5.06 and JDK 1.5.08
Under Windows XP it works!
Somebody has an idea?
Is the update-server broken?
Two or three month ago it worked.
thanks,
Chris
Re: Callisto doesn't work [message #169221 is a reply to message #169140] |
Mon, 04 September 2006 03:06  |
No, I think there is a problem with an linux update.
With the debian testing version it doesn't work anymore. But some weeks ago
it woked fine with this installation. With the current version of Ubuntu it
doesn't works too.
I didn't changed my configuration: same os, same network configuration,
same machine, same JDK etc. but I have installed always the linux updates.
On another partition I have an old debian sarge installation and there it
works. So I think it must be something with an linux update (patch,
security
update, lib-update,..) in the last days/weeks.
Chris
FUDForum. Page generated in 0.55545 seconds
