Home » Language IDEs » Java Development Tools (JDT) » stdout and stderr problem
stdout and stderr problem [message #169060] Fri, 16 July 2004 17:42 Go to next message
Originally posted by: dtwchiu.hotmail.com
I am writing an action that will launch a Java application using the
IVMRunner interface and for some reason, the application does not come up
at all. I stepped through the StandardVMRunner class and it seems all the
arguments and environment variables are set properly. I can also see the
process running using "ps" command, but the UI does not come up nor does
anything get logged into the application log. To help me debug this
problem, I would like to know that if the stdout and the stderr of the
application are automatically pipe out to the console window. If not, how
can I do that. Right now, I am not seeing any output except seeing the
process is running.
Thanks.
David.
Re: stdout and stderr problem [message #169084 is a reply to message #169060] Fri, 16 July 2004 19:04 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
If you are just launching a vm with nothing fancy but using the
classpath of a project, then you can just use the standard java launch
configuration on your own and setup the parameters and such.
See:
http://www.eclipse.org/articles/Article-Java-launch/launchin g-java.html
for how to just launch a vm against a project.
Otherwise you should write your launcher instead. Those when launched
properly will add themselves to the console log. The IVMRunner is now a
class used within launchers. It is not typically used by itself.
See:
http://www.eclipse.org/articles/Article-Launch-Framework/lau nch.html
for how to create your own launcher.
Thanks, Rich Kulp
Re: stdout and stderr problem [message #169091 is a reply to message #169084] Fri, 16 July 2004 19:09 Go to previous messageGo to next message
Make that a correction. If all you want to do is launch a vm then use
> See:
it doesn't have to refer to a project in the workspace.
Thanks, Rich Kulp
Re: stdout and stderr problem [message #169557 is a reply to message #169084] Tue, 20 July 2004 14:11 Go to previous messageGo to next message
Originally posted by: turker.keskinpala.vanderbilt.edu
When I read your reply, I was working on something similar. I was having the
same problem when I used the VMRunner approach. Thanks for the tip. This
helped me to run my app in debug mode.
I would like to ask a follow-up question. I would like to be able to
programmatically step through the code that I am debugging or get some info
during the debug. For this, I should be able to get the debug events, I
suppose. I know that one has to implement an IDebugEventSetListener to be
able to receive events during debug. However, I cannot figure out how to go
about doing this. When you use IVMRunner.run, it contributes results to
debug targets and processes to the given launch. What happens when using
DebugToolsUI.launch? Well, apparently, I am confused about this.
I will appreciate if you could provide some help with this.
Thanks for your time,
Turker Keskinpala
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cd9mre$25g$1@eclipse.org...
> See:
> See:
> Thanks, Rich Kulp
Re: stdout and stderr problem [message #169565 is a reply to message #169557] Tue, 20 July 2004 14:22 Go to previous messageGo to next message
Sorry, can't help with that. I never did that. Maybe somebody else can
answer that question.
> Turker Keskinpala
Thanks, Rich Kulp
Re: stdout and stderr problem [message #169657 is a reply to message #169557] Wed, 21 July 2004 09:45 Go to previous messageGo to next message
Just register your IDebugEventSetListener with the DebugPlugin. You will
receive all debug events from all registered targets.
Darin
"Turker Keskinpala" <turker.keskinpala@vanderbilt.edu> wrote in message
news:cdjn4v$8nq$1@eclipse.org...
the
info
go
> Turker Keskinpala
> > See:
> > See:
> > Thanks, Rich Kulp
Re: stdout and stderr problem [message #169688 is a reply to message #169657] Wed, 21 July 2004 12:19 Go to previous messageGo to next message
Thanks for your reply. I'll assume the debug target will automatically be
registered when DebugUITools.launch(configuration,ILaunchManager.DEBUG_MODE)
executes. I'll see soon if this is true:-)
Turker
"Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
news:cdls6p$hl6$1@eclipse.org...
> Darin
> > Hi,
> the
> info
be
> go
> > Turker Keskinpala
> > > See:
a
> > > See:
> > > Thanks, Rich Kulp
Re: stdout and stderr problem [message #170098 is a reply to message #169091] Mon, 26 July 2004 17:30 Go to previous messageGo to next message
Rich,
Thanks for your response. I followed the instruction and my app is able
to come up fine. However, there is one remaining problem which causes an
error in my application (the socket problem I posted later in this
newsgroup).
My application does not work properly when my custom jar files are placed
in front of the jre jars in the bootpath. I am wondering how to make sure
the jre jars are in front of my jars in the bootpath. Is this something
related to the "/a" in the bootpath? How to make sure that happens
programmatically in eclipse?
David.
> > See:
Re: stdout and stderr problem [message #170106 is a reply to message #170098] Mon, 26 July 2004 17:46 Go to previous messageGo to next message
Please disregard my question. The ordering of the bootpath is the same as
the ordering in the list that is being set to ATTR_CLASSPATH.
David.
David Chiu wrote:
> Rich,
> newsgroup).
> David.
> > > See:
Re: stdout and stderr problem [message #170114 is a reply to message #170098] Mon, 26 July 2004 17:49 Go to previous message
How are you adding them to your classpath? Are you making them system
type classpath entries in java build path? If so, then just make sure
they are after the JRE_CONTAINER or JRE_LIB entries in the classpath.
Thanks, Rich Kulp
Previous Topic:weird word jumping behavior
Next Topic:Plugins: J2EE support?
Current Time: Thu Jul 17 20:43:10 EDT 2025
Powered by FUDForum. Page generated in 0.30478 seconds
