CompoundDirectedGraphLayout question [message #168961] |
Sun, 20 February 2005 22:08  |
Originally posted by: yabing.crimsonlogic.com
I need to layout a graph, which contains subgraphs. each subgraph is a
rectangle box containing some nodes. the subgraph is like a database
table. columns in the table are its nodes. and there are two types of
connection lines. one is between subgraphs, or between tables. the other
is between one node in one subgraph (one column in one table) and another
node in another subgraph (another column in another table). there is no
connection line within one subgraph or one table. in this case, can I use
CompoundDirectedGraphLayout to make a nice layout of the graph? if not, is
there any other way?
Thanks a lot!
Yabing
Re: CompoundDirectedGraphLayout question [message #169450 is a reply to message #169356] |
Wed, 23 February 2005 10:23  |
Probably so.
"yabing chen" <yabing@crimsonlogic.com> escreveu na mensagem
news:cvgn92$8pr$1@www.eclipse.org...
> Thanks! got a reply finally.
> yeah, the columns of a table is layed out vertically top-to-bottom, and
> their location in the table shouldn't be changed in the layout. the
> purpose of the layout is to change the location of all the tables to make
> them and the connections between them and the connections between columns
> presented nicely. can do it using CompoundDirectedGraphLayout?
> Yabing
FUDForum. Page generated in 0.04513 seconds
