Home » Language IDEs » C / C++ IDE (CDT) » Simple Indent 1.1.0 has been released (It uses astyle)
Simple Indent 1.1.0 has been released (It uses astyle) [message #168958] Sun, 30 April 2006 14:57 Go to next message
Originally posted by: plankton.softwitch.net
http://softwitch.net/blog/index.php/simple-indent-110-has-be en-released/
I've got vacation from my military service for ten days.
Re: Simple Indent 1.1.0 has been released (It uses astyle) [message #168966 is a reply to message #168958] Sun, 30 April 2006 15:00 Go to previous messageGo to next message
oops...
It's a code formatter for eclipse cdt. anyway too busy.
Re: Simple Indent 1.1.0 has been released (It uses astyle) [message #169110 is a reply to message #168958] Wed, 03 May 2006 03:26 Go to previous messageGo to next message
Originally posted by: znib.gmx.net
This would be a very usefull plugin to me, but when I try to open its
preferences page I get the following error:
Unable to create the selected preference page.
Reason:
Plug-in net.softwitch.simpleIndent was unable to load class
net.softwitch.simpleIndent.preferences.SimpleIndentPreferenc esPage.
Any idea what's wrong? I'm using
Eclipse 3.1.2
CDT 3.0.2
java 1.5.0_06
WinXP
All I did was downloading
http://softwitch.net/eclipseUpdate/plugins/net.softwitch.sim pleIndent_1.1.0.jar
and copied it into the plugins directory of my eclipse installation.
Re: Simple Indent 1.1.0 has been released (It uses astyle) [message #169118 is a reply to message #169110] Wed, 03 May 2006 04:34 Go to previous messageGo to next message
I think you may use several jvm. Are you sure your eclipse launched with
JAVA 5.0? Just try to type in console likes "java -version"
> Reason:
> Eclipse 3.1.2
> CDT 3.0.2
> java 1.5.0_06
> WinXP
Re: Simple Indent 1.1.0 has been released (It uses astyle) [message #169125 is a reply to message #169118] Wed, 03 May 2006 04:47 Go to previous message
That says 1.5.0_06, but you were right anyway. :) I once played with
different VMs and changed the link I use to start eclipse to use the 1.4
VM....
Now that I changed it back it works perfectly! Thanks for pointing me
into the right direction.
Cheers
Marco
Previous Topic:Is it possible to disable the -M flags in a managed make build?
Next Topic:How is the link order determined?
Current Time: Thu Jul 17 21:29:21 EDT 2025
Powered by FUDForum. Page generated in 1.10548 seconds
