Home » Archived » BIRT » folder -- birt/Documents/session-id/ -- how to get rid of session-id? -- 2.1RC4
folder -- birt/Documents/session-id/ -- how to get rid of session-id? -- 2.1RC4 [message #168946] Sat, 10 June 2006 21:06 Go to next message
When the Web Viewer stores an rptdocument, it puts it into this folder (by
default):
<webcontext>/Documents/<session-id>/
This means that a user who tediously and carefully creates a report on
Monday cannot go back and look at it on Tuesday. Every time he closes a
session, and comes back later, he must re-create the report. This is
irritating because the report may have many parameters to select or enter.
Is there a workaround? Can I avoid <session-id> in the folder name? What I
really prefer is to create a folder for each user. When user-A opens
report-1 on Tuesday, he sees the report-1 he created on Monday. Since I
know who the users are, by login, this is easy, except for the <session-id>
problem. Any suggestions? Thanks.
Stan Jordan
Re: folder -- birt/Documents/session-id/ -- how to get rid of session-id? -- 2.1RC4 [message #169222 is a reply to message #168946] Mon, 12 June 2006 11:47 Go to previous messageGo to next message
On the URL use __document=
This should let you name the report anything you like.
Jason
"Stan Jordan" <stan_jordan@earthlink.net> wrote in message
news:e6fq9n$b8f$1@utils.eclipse.org...
> (by
> default):
> I
> <session-id>
> Stan Jordan
Re: folder -- birt/Documents/session-id/ -- how to get rid of session-id? -- 2.1RC4 [message #169352 is a reply to message #169222] Mon, 12 June 2006 14:58 Go to previous messageGo to next message
Jason,
Thanks for your reply. You suggestion works fine, in terms of viewing the
report and saving the rptdocument file in a folder. For example, this URL
appears to work fine:
http://localhost:9080/birt210RC4/frameset?__report=PatientDi agnoses.rptdesign&__document=D:/birt/reports/tryit.rptdo cument
However *Export data will fail*. The only way to get Export data to work is
to remove the __document parameter, and go with this:
Export data and the __document URL parameter appear to be mutually
exclusive. (Argh!)
On June 6, I filed bug #145626 on this issue, but Ivy Li closed it, saying,
"We never support that you can input the document path from url..."
Can you advise on how I can save the rptdocument in a folder-of-my-choosing,
and still permit Export data? Thanks.
Stan
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e6k2ap$d7q$1@utils.eclipse.org...
> Jason
>> (by
>> default):
>> enter.
>> What I
>> <session-id>
>> Stan Jordan
Re: folder -- birt/Documents/session-id/ -- how to get rid of session-id? -- 2.1RC4 [message #169744 is a reply to message #169352] Tue, 13 June 2006 12:26 Go to previous messageGo to next message
Stan,
I believe this is still a bug.
If you add &dummy=1 to the end of your URL it will work.
In the BirtSimpleExportDataDialog.js file there appears to be a bug
__constructForm : function( )
var dialogContent = $( 'simpleExportDialogBody' );
var hiddenDiv = document.createElement( 'div' );
hiddenDiv.style.display = 'none';
var hiddenForm = document.createElement( 'form' );
hiddenForm.method = 'post';
hiddenForm.target = '_self';
var url = document.location.href;
var index = url.indexOf( "frameset" );
//this line has a problem
url = url.substring( 0, index ) + "download" + url.substring( index + 8,
url.length -1 );
//it needs to be
url.length );
I updated the bug
Jason
news:e6kdgq$jv6$1@utils.eclipse.org...
> Jason,
> is to remove the __document parameter, and go with this:
> exclusive. (Argh!)
> saying, "We never support that you can input the document path from
> url..."
> folder-of-my-choosing, and still permit Export data? Thanks.
> Stan
>> Jason
>>> (by
>>> default):
>>> enter.
>>> What I
>>> <session-id>
>>> Stan Jordan
Re: folder -- birt/Documents/session-id/ -- how to get rid of session-id? -- 2.1RC4 [message #169864 is a reply to message #169744] Tue, 13 June 2006 15:17 Go to previous message
Jason,
Yes! I have verified that your fix works. U-da-man! Thanks mucho!!
Cheers
Stan
news:e6mouo$pla$1@utils.eclipse.org...
> Stan,
> url.length -1 );
> //it needs to be
> url.length );
> I updated the bug
> Jason
>> Jason,
>> the report and saving the rptdocument file in a folder. For example,
>> this URL appears to work fine:
>> exclusive. (Argh!)
>> url..."
>> Stan
>>> Jason
>>>> (by
>>>> default):
>>>> a
>>>> enter.
>>>> What I
>>>> I
>>>> <session-id>
>>>> Stan Jordan
Previous Topic:BIRT needs debugging with Microsoft script debugger?
Next Topic:How To Set the dbURL, dbUser & dbPassword dynamically
Current Time: Mon Jul 21 21:28:58 EDT 2025
Powered by FUDForum. Page generated in 0.04163 seconds
