Home » Archived » BIRT » Building BIRT 2.1RC4
Building BIRT 2.1RC4 [message #168886] Fri, 09 June 2006 13:37 Go to next message
I am unable to successfully built BIRT 2.1RC4. I was also not able to
successfully build BIRT2.1RC3, but got further with RC4 than RC3. This is
an extremely frustrating process.
I am able to build BIRT 2.0 with no problems, but the solutions for 2.1
are a black hole.
I start by downloading the 2.1RC4 all-in-one solution. Then, I connect to
CVS and check out all the source files for 2.1RC4. Then I close the test
projects, close the flat file driver projects, and add iText.jar to the
com.lowagie.itext plugin.
When I try to compile, I get over a thousand errors. There are many errors
of the type "assert cannot be resolved". These are really annoying and
probably mask my other problems. I don't know how to turn them off. My
compiler settings are set for 1.4.
I also saw one email from Jason that said "I also had to add a dependency
to org.eclipse.birt.report.designer.ui to the
org.eclipse.birt.report.debug.ui plugin to get it to build.", but I don't
understand how or what that actually gets done.
Re: Building BIRT 2.1RC4 [message #168888 is a reply to message #168886] Fri, 09 June 2006 14:21 Go to previous messageGo to next message
Ok, I was able to reduce my numbers of errors to 2:
Severity and Description Path Resource Location Creation Time Id
Host bundle 'org.eclipse.birt.report.data.oda.flatfile.ui' cannot be
resolved org.eclipse.birt.report.data.oda.flatfile.ui.nl/META-INF MANIFEST.MF line
6 1149876884776 30
Host bundle 'org.eclipse.birt.report.data.oda.flatfile' cannot be
resolved org.eclipse.birt.report.data.oda.flatfile.nl/META-INF MANIFEST.MF line
6 1149876884541 28
Can someone tell me how to resolve these errors?
Re: Building BIRT 2.1RC4 [message #168956 is a reply to message #168888] Sat, 10 June 2006 22:26 Go to previous messageGo to next message
Terry,
Close those projects. The source for them will be removed.
All of the flat file driver code has been moved to DTP.
Jason
"Terry Partridge" <terrypartridge@fairisaac.com> wrote in message
news:e0cd8c120cd917753a17a2a6b5e4bc44$1@www.eclipse.org...
> MANIFEST.MF line 6 1149876884776 30
> Host bundle 'org.eclipse.birt.report.data.oda.flatfile' cannot be resolved
> org.eclipse.birt.report.data.oda.flatfile.nl/META-INF MANIFEST.MF line 6
> 1149876884541 28
Re: Building BIRT 2.1RC4 [message #169321 is a reply to message #168956] Mon, 12 June 2006 13:26 Go to previous message
Hi Jason,
Thank you, that resolved my problems.
Regards, Terry
Previous Topic:Library Explorer shows nothing (2.1RC4)
Next Topic:Expression Builder - Where is it?
Current Time: Sun Aug 31 23:53:04 EDT 2025
Powered by FUDForum. Page generated in 0.05363 seconds
