Home » Modeling » GMF (Graphical Modeling Framework) » Add Remove dialog for Properties
Add Remove dialog for Properties [message #168855] Sat, 19 January 2008 06:34 Go to next message
Originally posted by: nospam.nospam.com
Is there a way to edit reference Property values from an Add/Remove dialog
instead of a drop-down list?
Same question:
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg03616.html
The dialog I have in mind is this:
http://topcased-mm.gforge.enseeiht.fr/website/modeling/sysml /tutorials/images/requirement/testCaseCover.jpg
Re: Add Remove dialog for Properties [message #168862 is a reply to message #168855] Sat, 19 January 2008 08:33 Go to previous message
I'm not sure if this helps:
http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application
> dialog instead of a drop-down list?
> Same question:
Previous Topic:GMF Graph Generation
Next Topic:Label positioning outside a Node
Current Time: Sat Jul 26 09:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.04191 seconds
