Home » Eclipse Projects » Subversive » SVN providers for Ganymede/Eclipse-3.4M6?
SVN providers for Ganymede/Eclipse-3.4M6? [message #15925] Tue, 08 April 2008 10:41 Go to next message
Originally posted by: jens.ja-web.de
hello,
I want to try out M6 and can't get subversive to work.
The subversive team provider comes through the Ganymede update site as
before.
but the Connectors update site
( http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/)
does not work with M6 (with the new install/update UI)
After resolving dependencies for the SVN Connector I get
"Problems resolving provisioning plan."
When will the connectors get updated?
thank you
Re: SVN providers for Ganymede/Eclipse-3.4M6? [message #15943 is a reply to message #15925] Wed, 09 April 2008 05:09 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Jens,
I've checked installation of Subversive plug-in (main plug-in and
connectors) into Ganymede M6 again and found no problems. May be in your
case problem is related to network failure. If so, please try to run
installation once more.
Re: SVN providers for Ganymede/Eclipse-3.4M6? [message #16698 is a reply to message #15943] Sat, 19 April 2008 11:41 Go to previous messageGo to next message
I also had problems with M6, and there were a number of P2 bugs. The
latest I-build seems to have a much more robust P2 updater
implementation. It's just a shame that it's got some other 'issues'
(not P2) that I need to track down and report ;)
Alexander Gurov wrote:
> Hello Jens,
Re: SVN providers for Ganymede/Eclipse-3.4M6? [message #16714 is a reply to message #16698] Mon, 21 April 2008 07:08 Go to previous message
> implementation.
hi,
I started from scratch with eclipse-platform-I20080410-1022-win32.zip
and based on that I could install the SVN from Ganymede and the
connector from the external site (Polarion).
No more complains about incompatibilities.
thanks
Jens
Previous Topic:Accepting Incoming Changes (Updates) Slow
Next Topic:Subversive History Extremely Slow
Current Time: Tue May 13 15:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.03190 seconds
