Home » Modeling » GMF (Graphical Modeling Framework) » Transaction problem with SortFilterPage
Transaction problem with SortFilterPage [message #15924] |
Fri, 11 August 2006 12:01  |
After sucessfully adding my own SortFilterCompartmentEditPolicy and
SortFilterContentPolicy, i can open the SortFilterDialog via the
"Filters->Sort/Filter compartment items" context menu. So this opens the
dialog and everything is shown correctly. But as soon as i press the
apply or ok button, i get the following exception:
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:517)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:206)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:169)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:156)
org.eclipse.gmf.runtime.diagram.ui.dialogs.sortfilter.SortFi lterPage.performApply(SortFilterPage.java:966)
org.eclipse.jface.preference.PreferencePage$2.widgetSelected (PreferencePage.java:282)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3164)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2840)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.gmf.runtime.diagram.ui.internal.dialogs.sortfilt er.SortFilterDialogUtil.invokeDialog(SortFilterDialogUtil.ja va:72)
org.eclipse.gmf.runtime.diagram.ui.editpolicies.SortFilterCo mpartmentItemsEditPolicy.getCommand(SortFilterCompartmentIte msEditPolicy.java:88)
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:473)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$1(GraphicalEditPart.java:1)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$1.run(GraphicalEditPart.java:414)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:258)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.getCommand(GraphicalEditPart.java:409)
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.get Command(DiagramAction.java:175)
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.get Command(DiagramAction.java:159)
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doR un(DiagramAction.java:101)
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:347)
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(A ctionManager.java:223)
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.runWithEvent(AbstractActionHandler.java:365)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.IllegalStateException: Cannot activate read/write
transaction in read-only transaction context
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.acquire(TransactionalEditingDomainImpl.java:498)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.activate(TransactionalEditingDomainImpl.java:436)
org.eclipse.emf.transaction.impl.TransactionImpl.start(Trans actionImpl.java:154)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.startTransaction(TransactionalEditingDomainImpl.java:352 )
org.eclipse.emf.workspace.AbstractEMFOperation.createTransac tion(AbstractEMFOperation.java:414)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:124)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
.... 52 more
Looks like we're still in the getCommand() method of my compartment edit
part, which is running in a read only transaction. Pressing apply will
then execute the change command inside a read transaction, which causes
this exception.
For me it's unclear if this feature isn't fully implemented or if this
is a bug.
Matthias
Re: Transaction problem with SortFilterPage [message #16038 is a reply to message #15924] |
Fri, 11 August 2006 13:52   |
Hello Matthias,
You could try returning a command from your edit policy that opens the
dialog when it is executed (from your action). #getCommand may be
called many times, but you probably don't want to make any model changes
until the command that is returned is actually executed.
Hope that helps,
Linda
Matthias Köster wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 52 more
> this exception.
> is a bug.
> Matthias
Re: Transaction problem with SortFilterPage [message #16056 is a reply to message #16038] |
Fri, 11 August 2006 14:03   |
I should add that it would be even better if you could open the dialog
from your action. When the user presses apply/ok, get the command from
your edit policy and execute it. This has the advantage of separating
the UI in the action from the semantic behaviour in the edit policy's
command. That being said, it's not always possible to separate the two...
Linda
Linda Damus wrote:
> Hello Matthias,
> Hope that helps,
> Linda
>> the dialog and everything is shown correctly. But as soon as i press
>> the apply or ok button, i get the following exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 52 more
>> edit part, which is running in a read only transaction. Pressing apply
>> will then execute the change command inside a read transaction, which
>> causes this exception.
>> is a bug.
>> Regards,
>> Matthias
Re: Transaction problem with SortFilterPage [message #16955 is a reply to message #16056] |
Mon, 14 August 2006 03:25   |
Hi Linda,
Thanks for your hints, but i think i didn't express the problem clearly
enough: i was taking about edit policy that are included in GMF and that
i want to utilize in my program. And there it looks like the design
recommendations that you have described are ignored, that's the reason
why i asked if this is a known bug or if i'm doing sth wrong.
Matthias
> Cheers,
> Linda
> Linda Damus wrote:
>> Hello Matthias,
>> changes until the command that is returned is actually executed.
>> Hope that helps,
>> Linda
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> read/write transaction in read-only transaction context
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> apply will then execute the change command inside a read transaction,
>>> which causes this exception.
>>> this is a bug.
>>> Regards,
>>> Matthias
Re: Transaction problem with SortFilterPage [message #25259 is a reply to message #16955] |
Tue, 22 August 2006 04:58   |
Does any body know if it's possible to use the SortFilterPage included
in GMF by adding your own SortFilterCompartmentEditPolicy and
SortFilterContentPolicy? I still wasn't able to get them running, as
described in my first post.
Matthias
> Hi Linda,
> Matthias
>> from your edit policy and execute it. This has the advantage of
>> separating the UI in the action from the semantic behaviour in the
>> edit policy's command. That being said, it's not always possible to
>> separate the two...
>> Cheers,
>> Linda
>> Linda Damus wrote:
>>> Hello Matthias,
>>> the dialog when it is executed (from your action). #getCommand may
>>> be called many times, but you probably don't want to make any model
>>> Hope that helps,
>>> Linda
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 52 more
>>>> transaction, which causes this exception.
>>>> this is a bug.
>>>> Regards,
>>>> Matthias
Re: Transaction problem with SortFilterPage [message #28243 is a reply to message #26328] |
Thu, 24 August 2006 04:22  |
Hi Cherie,
I've created a new bugzilla Bug 154998 and attached a patch to it.
Matthias Köster
Cherie Mahoney wrote:
> Matthias,
> This seems to be a bug in GMF. I suggest you raise a bugzilla or you could
> try to do this in a way that Linda suggests and submit the code. :-)
> Cherie
Current Time: Sun Aug 31 03:52:40 EDT 2025
Powered by FUDForum. Page generated in 0.15472 seconds
