Re: how do dynamic popup menus [message #168482 is a reply to message #168453] |
Wed, 16 January 2008 14:22 |
Originally posted by: trommas.yahoo.com
Dimitrios Kolovos wrote:
> The dynamic menu items are just actions, so if GMF supports this you
> should be able to do it from within those actions as well.
Of course, I should have thought of that. However, I need the new
diagram to be related/synced to the diagram you launch it from (As can
be done with "Load Resource" or like it happens with diagram
partitioning). Is this possible in principle ?
Does your
> question relate to this thread?
Yes. I use double click (diagram partitioning) to relate 4 subdiagrams
to a superdiagram (To ensure that all diagrams work on the same resource
set). However, when I try to make a new diagram and set it as sub of one
of the above subdiagram (3 levels of diagrams) - it won't work (see my
other thread for details). This is the reason I'm trying to launch a
diagram from a popup - but as mentioned it needs to relate to the other
diagrams.
Thanks for helping
Tomas Zijdemans
> http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg03651.html
> Cheers,
> Dimitrios
> Tomas Zijdemans wrote:
>> Hi Dimitrios
>> That looks very cool :) I think I need to try that out..
>> I just have a follow-up question to this:
>> Is it possible to launch an editor (a diagram) from such a popup
>> menuitem ?
>> Basicaly: just refer to, or copy, the behavior that gets initialized
>> when you select a new diagram from the main menu
>> Regards,
>> Tomas Zijdemans
>>> We've recently done something similar. These may be of assistance:
>>> (plugin.xml)
>>> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/eps ilon/org.epsilon.ewl.eclipse.gmf/plugin.xml?revision=1.3& ;root=Technology_Project&view=markup
>>> and
>>> (the class that contributes the sub-menu items)
>>> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/eps ilon/org.epsilon.ewl.eclipse.gmf/src/org/epsilon/ewl/eclipse /gmf/ContributeWizardsAction.java?revision=1.7&root=Tech nology_Project&view=markup
>>> Cheers,
>>> Dimitrios
>>> John Yotka wrote:
>>>> I have a need to create a dynamic submenu off of the popup menu for
>>>> my diagram. The items for the popup submenu are determined by the
>>>> items selected and the current state of a database table. In the
>>>> EMF editor I could do this with the menuAboutToShow method of the
>>>> <model>ActionBarContributor class.
>>>> How can you do this in GMF?
Re: how do dynamic popup menus [message #168497 is a reply to message #168482] |
Wed, 16 January 2008 14:42 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Tomas,
I'm afraid that my limited knowledge of GMF is not sufficient for
answering your questions :(. I hope someone else can help you with that.
Dimitrios
> Does your
> diagrams.
> Thanks for helping
> Tomas Zijdemans
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios
>>> menuitem ?
>>> Regards,
>>> Tomas Zijdemans
>>>> (plugin.xml)
>>>> and
>>>> Cheers,
>>>> Dimitrios
FUDForum. Page generated in 0.03304 seconds
