Eclipse as a better editor in a non-Eclipse project? [message #15883] |
Tue, 25 January 2005 03:33  |
Originally posted by: sargon42.macnews.de
I'd like to use Eclipse for an existing, quite large project in C++, which
is based on a completely handwritten make-environment. (no IDEs in use etc)
I've noticed that Eclipse doesn't do a whole lot without a project. So I
created a dummy-project and wanted to specify some directories where
Eclipse should look for classes - but w/o copying all of the stuff to its
environment. That doesn't seem to be possible though.
Basically I'd like to use Eclipse as an alternative editor with ctags-like
support. But it seems to me, that Eclipse is pretty useless if the whole
project is not an Eclipse project. Or am I missing something?
Ideas? Comments? Shrieking epitaphs?
Daniel
Re: Eclipse as a better editor in a non-Eclipse project? [message #15993 is a reply to message #15883] |
Tue, 25 January 2005 10:18  |
Originally posted by: Chris_Laffra.ca.ibm.com
You can create a project without needing to copy everything to your eclipse
workspace.
You can create an external project or you can use linked resources.
For a discussion, see:
http://www.eclipsefaq.org/chris/faq/html/faq36.html
Have you looked at CDT? It has support for existing projects with makefiles.
Chris Laffra, http://eclipsefaq.org
"Daniel Clausen" <sargon42@macnews.de> wrote in message
news:ct5099$uh1$1@www.eclipse.org...
> Hi
etc)
> Daniel
FUDForum. Page generated in 0.06839 seconds
