Home » Eclipse Projects » GEF » GEF and MultiPageEditorPart
GEF and MultiPageEditorPart [message #168231] Mon, 14 February 2005 13:26 Go to next message
Originally posted by: sinleeh.hotmail.com
Dear All,
I am using GEF editor in as a page in the multiPageEditorPart. When
tackling a problem with MySelectionAction not being informed about
selection event, and with the clue provided by Randy Hudson,about
GraphicalEditor#selectionChanged (thanks Randy), I finally figured out
that the problem is about Workbench Event not reaching the correct editors.
I dealt with the issue of selectionChanged() by making my
MultiPageEditorPart rebroadcast the appropriate selection event with my
GEF Editor as the IWorkbenchPart.
Lately I have to overwrite commandStackChanged() from my GEF editor to my
MultiPageEditorPart to get the workbench to realize that I had made
changes to my GEF editor.
All these allow me to learn a lot about Eclipse Platform and GEF. That's
great. But for a newbie, I am wondering whether:
(1)Is there any convension for using GEF inside a MutliPageEditorPart.
Particularly with respect to the rebroadcast of events from
MultiPageEditorPart to GEF Editor and vice-versa.
(2)Does anyone know what other events I must be aware of that might need
rebroadcasting? It takes sometime to figure out the SelectionEvent case
and it would be nice to have a "watch out" list.
Thanking you all in advance and best regards,
sinleeh
Re: GEF and MultiPageEditorPart [message #168237 is a reply to message #168231] Mon, 14 February 2005 14:04 Go to previous messageGo to next message
Sinleeh wrote:
> Dear All,
What kind of clue?
/me is really interested as well ;)
> editors.
> sinleeh
I'm using GEF inside a MultiPageEditorPart as well and I'm having a whole
lot of similar problems.
When switching Editors, the Outline and Palette (as long as not used as
flyout palette) are not updated correctly - more exactly, the palette is
updated but as soon as I click on the palette it reverts to the first
palette created.
The paletteViewer is keeping/caching a map of editor palettes I believe, and
for editors inside a MultiPageEditorPart, the MultiPageEditorPart is used
as reference.
My current workaround is to use a flyout palette....
Also, the zoomManager's ComboBox in the ToolBar is not updated when I switch
between editors,....
Do you have a more complete list or code snippets of what you had to do, to
get it working?
I'm really thankful for any hints, b/c this is really annoying me for some
time now.
Thanks a lot!
Fabian
Re: GEF and MultiPageEditorPart [message #168358 is a reply to message #168237] Tue, 15 February 2005 11:20 Go to previous messageGo to next message
Originally posted by: sinleeh.nowhere.com
Dear Fabian,
My project is not at such an advance stage as you yet so sorry I cannot
offer any help. I hope someone can help us both. Sooner or later I have to
deal with the same problem as yours. I am posting some code here, mainly
derived from LogicExample to solve the selection event problem. It might
not be the most elegant solution.
Fabian Wolf wrote:
> Sinleeh wrote:
>> Dear All,
> What kind of clue?
>> editors.
GraphicalEditor#selectionChanged was the clue to the problem. The problem
was SelectionAction.getSelectedObjects() do not seems to contain the
selected object.
Basically, there is two problems here. First, the MultiPageEditorPart do
not listen to selection events. Second, UpdateActions() inside Graphical
Editor check for this.equals(getSite().getPage().getActiveEditor()). The
parameter section will always return MultiPageEditorPart.
To solve it, I added it as a selection listener to the workbench
following the style of the LogicEditor. After that, I did a quick check at
selectionChanged() in MyMultiPageEditorPart I see that I actually captured
the selection event. Then, I have to transmit the selection event to the
GraphicalEditor. To do this, I check that my GraphicalEditor is the active
page and if so, resent the selection event with the IWorkbenchPart set to
the GraphicalEditor.
Second, I overloaded selectionChanged(IWorkbenchPart, Iselection) in my
GraphicalEditor so that if this.equals(IWorkbenchPart) it calls
updateAction as well. In short:
In MyMultiPageEditor
//remember to add this editor as selection listener to the worbench!!
public void init(IEditorSite site, IEditorInput editorInput) {
getSite().getWorkbenchWindow().getSelectionService().addSele ctionListener(this);
} //and remember to remove it from the selection service in dispose()
//Propergate selection event to MyGraphicalEditor if necesary
public void selectionChanged(IWorkbenchPart part, ISelection
selection) {
if (this.equals(getSite().getPage().getActiveEditor())){
if(MyGraphicalEditor.equals(getActiveEditor()))
MyGraphicalEditor.selectionChanged(getActiveEditor(),
selection);
In MyGraphicalEditor
selection) {
super.selectionChanged(part, selection);
if(this.equals(part)) { //Propagated from MyMultiPageEditor.
updateActions(getSelectionActions());
[snip]
> get it working?
> time now.
Hopefully someone will have wade a magic wand and our problems are
solved!!!
As you can see, my solution only works for SelectionEvent. I'm sure there
are tons of other events that I have to listen properly too.
I currenly have problem with PrintAction() in the sense that it cannot
find anything to print. I thought it was a selection event problem but the
solution above did not solve it.
Sinleeh
Re: GEF and MultiPageEditorPart [message #168373 is a reply to message #168358] Tue, 15 February 2005 14:46 Go to previous messageGo to next message
> selection) {
> [snip]
Dear Sinleeh,
you were really helpful! Not that it solved my palette or outline
problems,.. but the part/quote above solved a problem with my Alignment
Retarget Actions that were not working (as posted to this group
<cuqtd4$6tc$1@www.eclipse.org>).
Those are now working! Thanks a lot!
Fabian
Re: GEF and MultiPageEditorPart [message #168524 is a reply to message #168373] Wed, 16 February 2005 10:16 Go to previous message
Glad I could help. For your pallete/outline view problem, using the same
analogy, I probably check that the appropriate events are
transmitted/capture. Depending on implementation, looking at who calls
getAdapter() might help for the outline view.
Sorry I cannot help you here as my project haven't reach this stage
(pallete/outline view) yet. If you have a working solution for
PrintAction(), please share it coz I am having problems with it.
Sinleeh
Previous Topic:Snap to grid on creation?
Next Topic:label on connection with bendpoints not relocating
Current Time: Mon Sep 01 00:08:01 EDT 2025
Powered by FUDForum. Page generated in 0.06753 seconds
