Does using IFiles require writing a plugin? [message #167994] |
Tue, 09 December 2003 06:34  |
Originally posted by: joerg.von.frantzius.artnology.nospam.com
maybe this one is a bit silly, but if I want to get hold of an IFile,
can I do so only from within a plugin? Or is there a way to bootstrap
the platform and obtain a Workspace from within my own main()?
Jörg.
Re: Does using IFiles require writing a plugin? [message #171193 is a reply to message #167994] |
Tue, 16 December 2003 14:49  |
Originally posted by: John_Arthorne.oti.com_
You really need the platform to be running to use the workspace.
However, there is no requirement that the platform have a UI. You can
create an eclipse application that just uses the org.eclipse.core.*
plugins, and then this application will have access to the workspace.
Do a search for the org.eclipse.core.runtime.applications extension
point for more details.
Joerg von Frantzius wrote:
> Jörg.
FUDForum. Page generated in 0.05916 seconds
