Home » Eclipse Projects » Eclipse Platform » Eclipse with struts example
Eclipse with struts example [message #167947] Tue, 09 December 2003 05:44 Go to next message
Originally posted by: peter.tilm.gmx.de
i'm new to eclipse and struts. I' just tryin to get the Jakarta
struts-example running. When creating a new Java Project pointing to the
example directory i receive the following eclipse messages:
- The project was not built since its classpath is incomplete. Cannot find
the class file for javax.servlet.ServletException. Fix the classpath then
try rebuilding this project.
and
- This compilation unit indirectly references the missing type
javax.servlet.ServletException (typically some required class file is
referencing a type outside the classpath).
anyone a clue how i can get rid of these messages and build and run this
example?
thanks,
Peter
Re: Eclipse with struts example [message #167970 is a reply to message #167947] Tue, 09 December 2003 07:14 Go to previous messageGo to next message
You must set servlet.jar from btw. tomcat and struts.jar form struts
regards
Haris Peco
Peter wrote:
> and
> example?
> thanks,
> Peter
Re: Eclipse with struts example [message #168003 is a reply to message #167970] Tue, 09 December 2003 06:33 Go to previous messageGo to next message
how do i do that (newbie);-) if i right-click on the project name i can go
to a dialog "Java Build path" where i can choose libraries. There i have
the struts.jar included but how do i include the servlet.jar?
thanks,
Peter
> regards
> Haris Peco
> Peter wrote:
> > Hi,
> > and
> > example?
> > thanks,
> > Peter
Re: Eclipse with struts example [message #168213 is a reply to message #168003] Tue, 09 December 2003 13:47 Go to previous message
For struts you need servlet container (tomcat from jakarta.apache.org)
servlet-api.jar is in common/lib
Yo see myeclipse, too www.myeclipseide.com (29.95$ for year)
regards
> thanks,
> Peter
>> regards
>> Haris Peco
>> Peter wrote:
>> > Hi,
>> > the example directory i receive the following eclipse messages:
>> > find the class file for javax.servlet.ServletException. Fix the
>> > classpath then try rebuilding this project.
>> > and
>> > this example?
>> > thanks,
>> > Peter
RCP using Swing? [message #168244 is a reply to message #168213] Tue, 09 December 2003 13:39 Go to previous message
Is there any chance the RCP will toss out SWT in favor of using Swing, or at
least allow Swing to be used in place of SWT? There are some platforms SWT
doesn't work on very well, that Swing is solid in. I also wish SWT and Swing
would merge, keeping the Swing API but adding some of the native SWT
capabilities into the JDK. I have chatted with many developers in regards to
SWT and Swing, and the general concensus is that while SWT offers some nice
things, the majority of developers are going to be using Swing, and many
will not spend the time, or get paid to do so, to learn the SWT API for
future applications especially when their apps are already Swing based. I
think its a real shame to be stuck using SWT with the RCP. The RCP will
offer a lot of valuable features for developing UI applications quickly, but
without Swing I fear it will not be nearly as used as it could be.
Previous Topic:Projects question
Next Topic:Contributing to the main menu bar
Current Time: Sun Aug 31 23:53:05 EDT 2025
Powered by FUDForum. Page generated in 0.08418 seconds
