Home » Archived » Voicetools » CVS Repository checkout error
CVS Repository checkout error [message #15828] |
Wed, 23 August 2006 19:47  |
Brent,
This happened before your comments about my using the DTD for custom
objects in the VTP instead of modifying the XML editor, but I thought I'd
mentioned what happened anyway, just for future reference.
I was trying to check out the VTP plugins via the CVS repository and as it
was rebuilding the workspace, I got a dialog that was titled, "Building
workspace" with error, "Errors during build". In the "Details" section, I
see the following two times:
Errors running builder "Integrated External Tool Builder" on project
org.eclipse.vtp.source. The builder launch configuration could not be
found.
What does this mean. I tried the checkout again, this time I didn't see
this error. Does this mean the checkout was successful afterall?
I see a bunch of error in the plugin error log, things like:
!ENTRY org.eclipse.ui 4 4 2006-04-25 12:33:27.907
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-04-25 12:33:27.927
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.wst.xml.core.internal.provisional.format.TextNod eFormatter.formatNode(TextNodeFormatter.java:60)
!ENTRY org.eclipse.wst.xml.core 4 4 2006-04-25 16:12:16.14
!MESSAGE Access is denied
!STACK 0
java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(Unknown Source)
If I decide not to make any changes, how do I "uncheckout" and remove the
projects from my Plug-in Development Package Explorer?
Sorry so wordy, thanks.
Stan
UPDATE Re: CVS Repository checkout error [message #15848 is a reply to message #15828] |
Thu, 24 August 2006 12:05   |
I have downloaded WTP 1.5 and using it with VTP 1.0. I immediately
checked out the VTP via the CVS. Again, during the build of the
workspace, I got the same errors. However, since this was a fresh install
of WTP/VTP, the errors in the plugin log are not so cluttered and I
thought I'd paste the entire log file here, so here it is (thanks for the
help ahead of time):
!SESSION 2006-08-24 09:12:56.859
eclipse.buildId=M20060628-1325
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 2 0 2006-08-24 09:16:23.831
!MESSAGE Warnings while parsing the editor contributions from the
'org.eclipse.ui.editorActions' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2006-08-24 09:16:23.831
!MESSAGE Actions require a non-empty label or definitionId:
plug-in='org.eclipse.vtp.editor.ccxml.ui',
id='AUTOGEN:::org.eclipse.core.runtime.xml.source.ruler.acti ons2/org.eclipse.ui.texteditor.BookmarkRulerAction2'
id='AUTOGEN:::org.eclipse.core.runtime.xml.source.ruler.acti ons2/org.eclipse.ui.texteditor.SelectRulerAction2'
id='AUTOGEN:::org.eclipse.core.runtime.xml.source.ruler.acti ons3/1'
plug-in='org.eclipse.vtp.editor.srgxml.ui',
plug-in='org.eclipse.vtp.editor.vxml.ui',
!ENTRY org.eclipse.core.resources 4 2 2006-08-24 09:31:51.733
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 1
org.eclipse.core.runtime.CoreException: The builder launch configuration
could not be found.
org.eclipse.ui.externaltools.internal.model.ExternalToolsPlu gin.newError(ExternalToolsPlugin.java:73)
org.eclipse.ui.externaltools.internal.model.ExternalToolBuil der.build(ExternalToolBuilder.java:72)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:603)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:167)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:230)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:233)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:252)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:285)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:145)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:208)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!SUBENTRY 1 org.eclipse.ui.externaltools 4 0 2006-08-24 09:31:51.854
!MESSAGE The builder launch configuration could not be found.
!ENTRY org.eclipse.core.resources 4 2 2006-08-24 09:31:53.427
!STACK 1
could not be found.
!SUBENTRY 1 org.eclipse.ui.externaltools 4 0 2006-08-24 09:31:53.427
!ENTRY org.eclipse.core.resources 4 75 2006-08-24 09:31:59.409
!MESSAGE Errors during build.
!SUBENTRY 1 org.eclipse.ui.externaltools 2 75 2006-08-24 09:31:59.409
!MESSAGE Errors running builder "Integrated External Tool Builder" on
project org.eclipse.vtp.source.
!SUBENTRY 1 org.eclipse.ui.externaltools 4 0 2006-08-24 09:31:59.409
Thanks again,
Stan
Re: UPDATE Re: CVS Repository checkout error [message #15866 is a reply to message #15848] |
Thu, 24 August 2006 16:24  |
Originally posted by: bdmetz.us.ibm.com.spam
Just an FYI in case anyone was following along, since I replied already via
email:
These errors indicate some issues in the code but from a user perspective
should be viewed as harmless. If you see any issues using the XML editors
with WTP please let us know on the newsgroup or file a bugzilla.
"Stan Rivera" <stan.rivera@verizonbusiness.com> wrote in message
news:3564e6e96268644def97c40cea9fd160$1@www.eclipse.org...
>I have downloaded WTP 1.5 and using it with VTP 1.0. I immediately checked
>out the VTP via the CVS. Again, during the build of the workspace, I got
>the same errors. However, since this was a fresh install of WTP/VTP, the
>errors in the plugin log are not so cluttered and I thought I'd paste the
>entire log file here, so here it is (thanks for the help ahead of time):
> !SESSION 2006-08-24
> 09:12:56.859 -----------------------------------------------
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> could not be found.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> could not be found.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks again,
> Stan
UPDATE Re: CVS Repository checkout error [message #575294 is a reply to message #15828] |
!STACK 1
could not be found.
!STACK 1
could not be found.
Thanks again,
Stan
Re: UPDATE Re: CVS Repository checkout error [message #575347 is a reply to message #15848] |
email:
> !SESSION 2006-08-24
> !STACK 1
> could not be found.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> could not be found.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks again,
> Stan
Current Time: Sat Jun 07 22:22:14 EDT 2025
Powered by FUDForum. Page generated in 0.03875 seconds
