Home » Archived » Voicetools » Call to deployed openVXML app failing
Call to deployed openVXML app failing [message #15809] Wed, 23 August 2006 19:25 Go to next message
I have created a simple "hello world" openVXML app, deployed the VXML web
application on my weblogic app server successfully. Actually, I am seeing
one error when I first try to export the application. I select export,
then VXML Web App, then I click on "Next>", but I get a dialog box that
says "An error has occurred. See error log for more details.". I click
"Ok" and I'm then asked to enter the name of the WAR file. Don't know of
this is the root cause of my problem below, but thought I'd better mention
it. So, when calling up the application I've deployed on my weblogic app
server, http://<host>/FirstOpenVXMLApp/openVXML, I get the following
traces:
getResourceItem::/WEB-INF/openVXML/application/::true
<Aug 23, 2006 4:43:19 PM MDT> <Error> <HTTP> <BEA-101046>
< [ServletContext(id=1861120,name=FirstOpenVXMLApp,context-pat h=/FirstOpenVXMLApp)]
Failed to process call: null
org.eclipse.vtp.framework.kernel.core.DefaultApplicationMana ger.getApplication(DefaultApplicationManager.java:71)
org.eclipse.vtp.framework.kernel.core.DefaultCallManager.ini tializeCall(DefaultCallManager.java:135)
org.eclipse.vtp.framework.kernel.http.HTTPConnector.service( HTTPConnector.java:139)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
weblogic.servlet.internal.ServletStubImpl$ServletInvocationA ction.run(ServletStubImpl.java:996)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:419)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:315)
weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionAction.run(WebAppServletContext.java:6452)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Aut henticatedSubject.java:321)
weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:
118)
weblogic.servlet.internal.WebAppServletContext.invokeServlet (WebAppServletContext.java:3661)
weblogic.servlet.internal.ServletRequestImpl.execute(Servlet RequestImpl.java:2630)
at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:219 )
at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:178)
<Aug 23, 2006 4:43:19 PM MDT> <Error> <HTTP> <BEA-101020>
Servlet failed with Exception
weblogic.servlet.internal.ServletResponseImpl.sendError(Serv letResponseImpl.java:422)
org.eclipse.vtp.framework.kernel.http.HTTPConnector.service( HTTPConnector.java:150)
weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:118)
Stan
Re: Call to deployed openVXML app failing [message #15884 is a reply to message #15809] Thu, 24 August 2006 17:19 Go to previous message
Hi Stan,
I think don't think the error you are getting while exporting is the
root of the problem. The NullPointerException is occurring because the
runtime cannot find a folder in the WAR file at the path
"/WEB-INF/openVXML/application/". Is this folder present in the exported
WAR? If not, there is a bug in the export process introduced when
migrating to Eclipse 3.2. If the folder is present it may be a problem
running under WebLogic (which we have not tested under).
I have a theory: this exception will occur if WebLogic returns null when
calling ServletContext.getResource(String) with a path that points to a
directory. If this is the case then we can open a bug report and get
this fixed in CVS.
If you open a bug report on this problem and attach the exported WAR
file we can verify the above assumptions.
Thanks for your time,
Lonnie
Lonnie Pryor
OpenMethods
4741 Central Street | Suite 285 | Kansas City , MO | 64112-1533
o | +1.816.283.VXML (8965) x111 f | +1.816.817.0643
lonnie@openmethods.com | www.openmethods.com
Re: Call to deployed openVXML app failing [message #575367 is a reply to message #15809] Thu, 24 August 2006 17:19 Go to previous message
Hi Stan,
this fixed in CVS.
Lonnie
Lonnie Pryor
OpenMethods
Previous Topic:Extending the VTP, adding custom VXML tags
Next Topic:CVS Repository checkout error
Current Time: Sun Aug 31 17:25:58 EDT 2025
Powered by FUDForum. Page generated in 0.02842 seconds
