Home » Modeling » GMF (Graphical Modeling Framework) » Providing Links across different documents in the Runtime
Providing Links across different documents in the Runtime [message #15804] Fri, 11 August 2006 06:44 Go to next message
Originally posted by: ganesh.mohan.hp.com
Usin my GMF runtime is it possible to refer from one file to another file.
example: suppose i have a graphical editor for writing xml application.
say:
File 1:
<Root1>
<NodeB>reference to some other (NodeC) node in file2></Node>
</Root>
File 2:
<Root2>
<NodeC>..........</Node>
</Root>
My question is :
a) Is it possible after droping NodeB on the editor, we can add a new
wizard to create File2 with NodeC whose root <Root2> refers to Root1.
b) Is it possible to provide a link from NodeB to NodeC in File2.
If any of these is possible, can you please explain how it can done.
Thanx,
Ganesh
Re: Providing Links across different documents in the Runtime [message #17102 is a reply to message #15804] Mon, 14 August 2006 06:18 Go to previous messageGo to next message
Originally posted by: senthil.periasamy.flextronicssoftware.com
hi ganesh are you from india you have any reference docs or links for GMF
please let me know.
regards
senthil
Re: Providing Links across different documents in the Runtime [message #19766 is a reply to message #15804] Tue, 15 August 2006 13:32 Go to previous message
Hello Ganesh,
Check XXXItemSemanticEditPolicy generated for diagram - the code responsible
for creating NodeB is located there, so you can patch it.
Yes. Such a links are supported by EMF.
Alex Shatalin
Previous Topic:ShortCuts for Edges?
Next Topic:creating link elements in a different file
Current Time: Sat Jun 07 01:38:11 EDT 2025
Powered by FUDForum. Page generated in 0.05643 seconds
