Plugin rules output file settings [message #15790] |
Tue, 19 May 2009 16:22  |
I think the Plugin Rules setting for Output File is limited to the default
Velocity context variables as described in
http://wiki.eclipse.org/Tigerstripe_Plugin_Miscellany
I tried ${artifact.FullyQualifiedName}.xsd
And it did not work.
It seems that only something like this will do:
${artifact.Package}_${artifact.Name}.xsd
I guess (I tried it) calling a method of a defined Velocity Context
Definition does not work as well.
So, can I have a confirmation that today I have no chance on having any
programmatic controls over the naming of generated files over than using
those documented parameters?
I want to be able to generate a file for each packages of my project
(natively defined and from dependencies). I think the easiest way would be
to use a Plugin Artifact Rule associated with the Package artifact type.
But, I want to have more control over the naming.
Any other suggestions?
Jerome
FUDForum. Page generated in 0.06570 seconds
