Problem deploy web application from eclipse 3.1.2 to WAS 6 [message #167152] |
Fri, 21 April 2006 02:08 |
Originally posted by: td.jworx.com
Hi!
I'm having trouble to start my web application from eclipse 3.1.2 wtp
1.0.1 in WAS 6.0.2!
I have setup a server in eclipse which runs on IBM jre and I have no
problems starting the server from eclipse but the IDE does not seem to
deploy my application to my WAS profile. It seems to deploy it to an
eclipse plugin dir in my workspace.
Any idea of how to have eclipse deploy my apps to WAS to be able to debug
it?
This are my server startup settings in eclipse:
---- Program args ----
com.ibm.ws.runtime.WsServer "C:/Program
Files/IBM/Rational/SDP/6.0/runtimes/base_v6/profiles/ANSS/co nfig "
"dse31472Node02Cell" "dse31472Node02" "server1"
---- VM args ----
"-Duser.install.root=C:/Program
Files/IBM/Rational/SDP/6.0/runtimes/base_v6/profiles/ANSS"
"-Dserver.root=C:/Program
"-Dwas.install.root=C:/java/runtimes/was/base_v6"
"-Dcom.ibm.itp.location=C:/java/runtimes/was/base_v6/bin"
" -Dws.ext.dirs=C:/java/runtimes/was/base_v6/java/lib;C:/Progr am
Files/IBM/Rational/SDP/6.0/runtimes/base_v6/profiles/ANSS/cl asses;C:/java/runtimes/was/base_v6/classes;C:/java/runtimes/ was/base_v6/lib;C:/java/runtimes/was/base_v6/installedChanne ls;C:/java/runtimes/was/base_v6/lib/ext;C:/java/runtimes/was /base_v6/web/help;C:/java/runtimes/was/base_v6/deploytool/it p/plugins/com.ibm.etools.ejbdeploy/runtime "
-Xbootclasspath/p:C:/java/runtimes/was/base_v6/java/jre/lib/ ext/ibmorb.jar;C:/java/runtimes/was/base_v6/java/jre/lib/ext /ibmext.jar
-Xms50m -Xmx256m "
-Dcom.ibm.CORBA.ConfigURL=file:C:/Program
Files/IBM/Rational/SDP/6.0/runtimes/base_v6/profiles/ANSS/pr operties/sas.client.props "
"-Dcom.ibm.SOAP.ConfigURL=file:C:/Program
Files/IBM/Rational/SDP/6.0/runtimes/base_v6/profiles/ANSS/pr operties/soap.client.props "
" -Djava.util.logging.manager=com.ibm.ws.bootstrap.WsLogManage r "
"-Djava.util.logging.configureByServer=true"
"-Dibm.websphere.preload.classes=true"
" -Djava.library.path=C:/java/runtimes/was/base_v6/java/bin;C: /java/runtimes/was/base_v6/bin;C:/java/runtimes/was/base_v6/ java/bin;C:/java/runtimes/was/base_v6/java/jre/bin "
---- Working directory ----
C:/Program Files/IBM/Rational/SDP/6.0/runtimes/base_v6/profiles/ANSS
/Tony
FUDForum. Page generated in 0.02877 seconds
