Home » Eclipse Projects » Plugin Development Environment (PDE) » Plugin doesn't get loaded after deployment
Plugin doesn't get loaded after deployment [message #1322] Sat, 19 April 2008 05:36 Go to next message
Originally posted by: kulkarni1.avaya.com
I am getting some weired problem and not able to find the solution.
I have developed a plugin and tested by "Run" and "Debug" mode.
Everything works perfect when I launch runtime Eclipse session.
But when I deploy the plugin to existing eclipse installation, then
it doesn't get loaded. The plugin is neither listed in Help->About Eclipse
SDK
nor I can see my functionality.
The way I deploy the plugin is: Select the plugin, with RMB, Export, then
"Deployable Plugins and Fragments", enter destination directory of my
eclipse
installation.
Interestingly, when I do the same steps for a sample "Hello World" plugin,
then also everything works fine.
Any suggestions would be greatly appreciated. I am using Eclipse 3.4.2.
Please help.
Santosh
Re: Plugin doesn't get loaded after deployment [message #1853 is a reply to message #1322] Sun, 20 April 2008 01:28 Go to previous message
I got the resolution of the problem. I was not taking care of dependencies.
No need to reply.
Santosh
Re: Plugin doesn't get loaded after deployment [message #565953 is a reply to message #1322] Sun, 20 April 2008 01:28 Go to previous message
No need to reply.
Santosh
Previous Topic:Plugin doesn't get loaded after deployment
Next Topic:headless product build creating different folders for each config
Current Time: Sun Jul 27 12:29:30 EDT 2025
Powered by FUDForum. Page generated in 0.03324 seconds
