Home » Archived » BIRT » Complie BIRT 2_0_1 error BUILD FAILED
Complie BIRT 2_0_1 error BUILD FAILED [message #167069] Fri, 02 June 2006 10:29 Go to next message
Hello People,
I tried downloading BIRT 2_0_1 Release and following the instructions given
at http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
However, when I try to build (compile) the project as per these
instructions, the build process fails with the following error:
BUILD FAILED
C:\eclipse\workspace\org.eclipse.birt.report.viewer\BuildVie wer.xml:263: The
following error occurred while executing this line:
C:\eclipse\workspace\org.eclipse.birt.data.oda.adapter.dtp\B uildDtpOdaAdapter.xml:83:
C:\eclipse\workspace\org.eclipse.birt.report.viewer\plugins not found.
Can anybody tell me where I am going wrong?
Thanks in advance,
Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #167404 is a reply to message #167069] Mon, 05 June 2006 09:29 Go to previous messageGo to next message
Did you add the eclipse.home variable?
Jason
"Girish" <girisha@cybage.com> wrote in message
news:e5pi43$o2l$1@utils.eclipse.org...
> Hello People,
> given at http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
> BUILD FAILED
> The following error occurred while executing this line:
> Thanks in advance,
> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #167619 is a reply to message #167404] Tue, 06 June 2006 03:42 Go to previous messageGo to next message
I had forgot to add that one, thanks a lot for it Jason, it works fine now!
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e61bk3$erl$1@utils.eclipse.org...
> Jason
>> Hello People,
>> BUILD FAILED
>> Thanks in advance,
>> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #174421 is a reply to message #167619] Fri, 30 June 2006 07:44 Go to previous messageGo to next message
Originally posted by: emina.karic.dsek.lth.se
I have this exact problem when building BIRT 2.0.1. I thought I had set the
eclipse.home variable, but I still get the same error. I'm guessing I didn't
do it quite right. What is the correct way to set it?
Thanks in advance
Emina
news:e63boh$sq1$1@utils.eclipse.org...
now!
> > Jason
> >> Hello People,
> >> given at
> >> BUILD FAILED
r.xml:83:
> >> Thanks in advance,
> >> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #174698 is a reply to message #174421] Sun, 02 July 2006 20:28 Go to previous messageGo to next message
Take a look here:
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php#viewer
Jason
"Emina Karic" <emina.karic@dsek.lth.se> wrote in message
news:e832rq$rnd$1@utils.eclipse.org...
> didn't
> Thanks in advance
> Emina
> now!
>> > Jason
>> >> Hello People,
>> >> given at
>> >> BUILD FAILED
> r.xml:83:
>> >> Thanks in advance,
>> >> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #174786 is a reply to message #174698] Mon, 03 July 2006 05:02 Go to previous messageGo to next message
Yeah, that's the one I've been following. I have the same exact problem
except that setting the eclipse.home didn't fix the problem.
Any clues?
Thanks in advance
Emina
news:e89obj$opk$1@utils.eclipse.org...
> Take a look here:
> Jason
the
> > didn't
> > Thanks in advance
> > Emina
> > now!
> >> > Jason
> >> >> Hello People,
instructions
> >> >> given at
> >> >> BUILD FAILED
> > r.xml:83:
found.
> >> >> Thanks in advance,
> >> >> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #174886 is a reply to message #174786] Mon, 03 July 2006 10:35 Go to previous messageGo to next message
Can you post a screenshot of where you are setting the home and
also post the error message?
Jason
news:e8amfa$hcd$1@utils.eclipse.org...
> Any clues?
> Thanks in advance
> Emina
>> Take a look here:
>> Jason
> the
>> > didn't
>> > Thanks in advance
>> > Emina
>> > now!
>> >> > Jason
>> >> >> Hello People,
> instructions
>> >> >> given at
>> >> >> BUILD FAILED
>> > r.xml:83:
> found.
>> >> >> Thanks in advance,
>> >> >> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #175068 is a reply to message #174886] Tue, 04 July 2006 05:56 Go to previous messageGo to next message
BUILD FAILED
C:\Documents and
Settings\EEMIKAR\workspace\org.eclipse.birt.report.viewer\Bu ildViewer.xml:26
3: The following error occurred while executing this line:
C:\Documents and
Settings\EEMIKAR\workspace\org.eclipse.birt.data.oda.adapter .dtp\BuildDtpOda
Adapter.xml:83: C:\Documents and
Settings\EEMIKAR\workspace\org.eclipse.birt.report.viewer\pl ugins not found.
Total time: 16 seconds
news:e8ba0f$q1u$1@utils.eclipse.org...
> Jason
> > Any clues?
> > Thanks in advance
> > Emina
> >> Take a look here:
> >> Jason
set
> > the
> >> > didn't
> >> > Thanks in advance
> >> > Emina
fine
> >> > now!
> >> >> > Jason
> >> >> >> Hello People,
> > instructions
> >> >> >> given at
> >> >> >> BUILD FAILED
> >> > r.xml:83:
> > found.
> >> >> >> Thanks in advance,
> >> >> >> Girish
  • Attachment: scr.jpg
    (Size: 61.09KB, Downloaded 107 times)
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #175725 is a reply to message #175068] Thu, 06 July 2006 19:00 Go to previous messageGo to next message
Do you have a plugins directory below Test-Eclipse-3.1?
If the directory is Test-Eclipse-3.1/eclipse/plugins then change your entry
to
Test-Eclipse-3.1/eclipse.
I dont have quotes around the name or the value BTW.
I am not certain if this matters.
Also is you using 2.1 look at the Build Web Viewer instructions that are
downloaded as part of the source.
Jason
news:e8de06$3f3$1@utils.eclipse.org...
> BUILD FAILED
> C:\Documents and
> C:\Documents and
> found.
>> Jason
>> > Any clues?
>> > Thanks in advance
>> > Emina
>> >> Take a look here:
>> >> Jason
> set
>> > the
>> >> > I
>> >> > didn't
>> >> > Thanks in advance
>> >> > Emina
> fine
>> >> > now!
>> >> >> > Jason
>> >> >> >> Hello People,
>> > instructions
>> >> >> >> given at
>> >> >> >> BUILD FAILED
>> >> > r.xml:83:
>> > found.
>> >> >> >> Thanks in advance,
>> >> >> >> Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #176174 is a reply to message #175725] Mon, 10 July 2006 04:32 Go to previous message
entry
> to
Yes, the plugin directory is directly below Test-Eclipse-3.1. As far as the
quotes go, I've tried both with and without. Doesn't really matter, it
seems.
> Jason
I'm actually trying to build BIRT 2.0.1. So I'm following the instructions
on:
I really can't figure out where it goes wrong. Thanks in advance.
Emina
Previous Topic:Copying the report and saving with different name using birt api
Next Topic:java.lang.NoClassDefFoundError: org/eclipse/birt/report/model/activity/ActivityStack
Current Time: Sat Jul 26 09:28:50 EDT 2025
Powered by FUDForum. Page generated in 0.28003 seconds
