Home » Archived » BIRT » How to set dial region at runtime
How to set dial region at runtime [message #167013] Fri, 02 June 2006 08:34 Go to next message
Originally posted by: wirojp.yahoo.com
Hi..
I want to change dialregion marker of Meter chart by set StartValue and
EndValue at runtime. I try to adapt from markerRange example but it's not
work.
function beforeGeneration( chart, context ){
var firstAxis =
chart.getSeriesDefinitions().get(0).getSeriesDefinitions().g et(0).getSeries().get(0).getDial();
var firstRange = firstAxis.getDialRegions().get(0);
firstRange.setStartValue( NumberDataElementImpl.create( 0 ) );
firstRange.setEndValue( NumberDataElementImpl.create( 9000 ) );
Does anyone can help me to solve this problem? I'm quite new for BIRT.
Thank you.
Wiroj P.
Re: How to set dial region at runtime [message #177097 is a reply to message #167013] Wed, 12 July 2006 19:15 Go to previous messageGo to next message
How can this be done? Anyone?
Thanks in advance for any help on this topic!
"wirojp" <wirojp@yahoo.com> schrieb im Newsbeitrag
news:00d6eaa4ac10c2f13c2cefe9cec0fb4d$1@www.eclipse.org...
> Hi..
> work.
> var firstAxis =
> Thank you.
> Wiroj P.
Re: How to set dial region at runtime [message #177113 is a reply to message #177097] Wed, 12 July 2006 23:36 Go to previous message
Try this, you need to create the region before use it.
var firstAxis =
var firstRange = DialRegionImpl.create();
firstRange.setFill(ColorDefinitionImpl.CREAM());
firstAxis.getDialRegions().add(firstRange);
>> Hi..
>> work.
>> var firstAxis =
>> Thank you.
>> Wiroj P.
Previous Topic:xpath and xml datasource
Next Topic:Chart library problem
Current Time: Wed Jul 16 02:10:55 EDT 2025
Powered by FUDForum. Page generated in 1.27246 seconds
