CDT, DBG: debug C++ dll with VB60 executable [message #166934] |
Thu, 30 March 2006 07:05  |
Originally posted by: rene.nijboer.siemens.com
Eclipse: Version: 3.1.2
CDT: 3.0.2
In Eclipse (CDT) I have created a DLL. The DLL compiles and can be debuged
within Eclipse using a testproject (C++).
I have also a VB60 executable that is using the c++ dll. When I run the
executable (without debugging) the DLL returns the correct values. But
when I want to debug the DLL using this VB60 executable a message box
pops-up with the following message:
Unable to set the temporary breakpoint in main.
Reason: Target request failed: No symbol table is loaded. Use the "file"
command...
Continue?
If I select the [Yes]: the program is running fine, but with debugging
functionality...
Additional info:
I have set the option -g in the debug option.
Part of the messages in the console when compiling/building.
Invoking: GCC C++ Compiler
g++ -O0 -g3 -g -Wall -c -fmessage-length=0 -oMain_C_Wrapper.o
../Main_C_Wrapper.cpp
What am I doing wrong?
Tanks in advance.
Rene
Re: CDT, DBG: debug C++ dll with VB60 executable [message #167993 is a reply to message #166934] |
Wed, 12 April 2006 15:33  |
Originally posted by: jancewicz.comcast.net
I had similar difficulties when trying to use Eclipse to debug a Java app
that called native C code in a DLL. I could not get the Eclipse C/C++
debugger to set the breakpoint in my C code in the DLL, even after the Java
JVM had loaded the DLL into its process space. I ended up having to use the
Insight debugger to debug my C DLL. This link explains how I did it:
http://www.kineteksystems.com/white-papers/mixedjavaandc.htm l
You might be able to do something similar by attaching the Insight debugger
to your VB process *after* it has loaded your DLL but *before* it calls the
C function or C++ method in your DLL that you want to debug.
Hope it helps,
Nick Jancewicz
"Rene Nijboer" <rene.nijboer@siemens.com> wrote in message
news:00c3ed519ea83664f4c98443cae3f6da$1@www.eclipse.org...
> Hello,
> CDT: 3.0.2
> pops-up with the following message: Unable to set the temporary breakpoint
> in main.
> command...
> Continue?
> functionality...
> Additional info:
> Tanks in advance.
> Rene
FUDForum. Page generated in 0.36058 seconds
