Home » Archived » Maven Integration (M2E) » Tycho build 0.3.0-DEV-1572
Tycho build 0.3.0-DEV-1572 [message #15728] Tue, 23 September 2008 15:52
Originally posted by: igor.ifedorenko.com
New Tycho build 0.3.0-DEV-1572 has been deployed to
repository.sonatype.org and you can download distribution from [1].
This build comes packaged with newer version of maven 3.0, which
supposed to fix problems with proxy configuration.
New and noteworthy changes in Tycho itself (in no particular order)
* Added support for pack200
* Added support for signed bundles
* Tycho will properly generate multiple nested JARs as defined
in build.properties file
* Tycho will properly package bundles with existing nested JARs
* Fixed number of problems running unit tests in OSGi runtime
We also setup continuous build of tycho integration tests which we run
against Eclipse 3.2, 3.3 and 3.4. Look for tycho-its* jobs on our hudson
instance [2].
[1]
http://repository.sonatype.org/service/local/repositories/ty cho-pseudo-releases/content/org/codehaus/tycho/tycho-distrib ution/0.3.0-DEV-1572/
[2] http://ci.sonatype.org/view/Tycho/
m2e/tycho team
Previous Topic:doxia editors integrated into m2eclipse
Next Topic:Please join the E4 Resources discussions
Current Time: Tue Jul 22 09:07:25 EDT 2025
Powered by FUDForum. Page generated in 0.04315 seconds
