Home » Modeling » GMF (Graphical Modeling Framework) » Extend tool bar dynamically
Extend tool bar dynamically [message #166741] Thu, 03 January 2008 12:12 Go to next message
Originally posted by: raedler.inf.uni-konstanz.de
I'm working on a small gmf project that supports input devices, output
devices and filters. Each of those three parts should support a dynamic
extension.
Here is a simple example:
In the filters tool bar are currently two filters like: XYSwitch,
HorizontalSwitch. The administrator of the program discovered a
requirement of a new filter called DigitalChanged. Therefor he writes a
new class. Now the class should be added to the tool bar dynamically
without creating the diagram code and so on.
Is this possible with gmf?
Thank You!
Re: Extend tool bar dynamically [message #166843 is a reply to message #166741] Fri, 04 January 2008 06:27 Go to previous message
Hello Roman,
see PaletteService.
Alex Shatalin
Previous Topic:self composition
Next Topic:"selfmade shortcuts"
Current Time: Fri Jul 18 22:48:18 EDT 2025
Powered by FUDForum. Page generated in 0.06389 seconds
