Importing a source tree [message #166736] |
Wed, 29 March 2006 06:00  |
Originally posted by: gareth.foster.siemens.com
I have an existing source tree that I would like to use in Eclipse with
CDT. The only way I can see to use this tree is to 'import' it, but that
means copy, and that is not what I want to do, I want to edit the files
where they are.
The project is on a ClearCase dynamic view (essentially a mapped drive
under windows), I have the ClearCase plugin installed. The source uses
makefiles. I am not interested in building it from Eclipse.
What is the best way to do this? Can anyone help?
Gareth
Re: Importing a source tree [message #166800 is a reply to message #166777] |
Thu, 30 March 2006 00:47  |
Thomas,
> you can always just create a Standard Make Project and on the first page
> of the creation wizard uncheck the box by the "use default" option in the
> Project contents section. Then just enter the path to the root of the
> source tree. This will create the eclipse project in that directory and
> you then work on the files directly.
that's one way to do it, which has the side-effect that the project files
(.project, .cdtproject) are created in the CC dynamic view. If that is a
problem you can also create the project in the default location and then
create a linked folder which points to the sources in the dynamic view.
Greetings,
Norbert Ploett
FUDForum. Page generated in 0.51583 seconds
