Home » Archived » XML Schema Definition (XSD) » ComplexTypeDefinition missing when encapsulated in an element
ComplexTypeDefinition missing when encapsulated in an element [message #15710] Mon, 31 March 2003 14:55 Go to next message
hello,
I am having problems in setting a complextypedefinition encapsulated in an
element in a model group. I am attaching my code below. I have set the
attribute as :
status_dec.setLexicalValue(status);
in my complextypedefinition. The code is attached below. When the schema
is generated the attribute is missing. I have put the schema at the bottom
of the page
any help would be great
XSDParticle particle = xsdFactory.createXSDParticle();
XSDComplexTypeDefinition complex_def
=xsdFactory.createXSDComplexTypeDefinition();
complex_def.setName(item_name);
Iterator iter = properties.iterator();
while(iter.hasNext())
String prop_name = (String)iter.next();
XSDAttributeDeclaration attr_decl =
xsdFactory.createXSDAttributeDeclaration();
attr_decl.setName(prop_name);
attr_decl.setTypeDefinition(sch.getSchemaForSchema().resolve SimpleTypeDefinition( "string"));
XSDAttributeUse AttributeUse = xsdFactory.createXSDAttributeUse();
AttributeUse.setContent(attr_decl);
complex_def.getAttributeContents().add(AttributeUse);
XSDAttributeDeclaration status_dec =
status_dec.setName("Optional");
String status = new String();
status="M";
***here**
XSDAttributeUse optionalAttributeUse =
optionalAttributeUse.setContent(status_dec);
complex_def.getAttributeContents().add(optionalAttributeUse) ;
//encapsulate the complex type in an element.
XSDElementDeclaration elem_item =
xsdFactory.createXSDElementDeclaration();
elem_item.setTypeDefinition(complex_def);
//assign a dummy name on element
elem_item.setName(item_name+"_");
particle.setContent(elem_item);
particle.setMinOccurs(minOccur);
particle.setMaxOccurs(maxOccur);
List model_list = sch.getModelGroupDefinitions();
Iterator model_iter = model_list.iterator();
while(model_iter.hasNext())
XSDModelGroupDefinition group = (XSDModelGroupDefinition)
model_iter.next();
if(group_name.equals("GROUP1")){
XSDModelGroup model_group = group.getModelGroup();
model_group.getContents().add(particle);
group.setModelGroup(model_group);
sch.update();
as you can see the group is created but the attribute on the complextype
and the complex type is not shown
- <xsd:group name="GROUP1">
- <xsd:all>
<xsd:element maxOccurs="2" minOccurs="1" name="item1_" type="item1" />
</xsd:all>
</xsd:group>
Re: ComplexTypeDefinition missing when encapsulated in an element [message #16865 is a reply to message #15710] Mon, 31 March 2003 16:29 Go to previous message
Kaunteya,
As I stated in an earlier note, setAnonymousTypeDefinition is used in order for an element to
contain a complex type as opposed to setTypeDefinition which is used to refer to a type
contained elsewhere.
kaunteya bhattacharya wrote:
> hello,
> attribute as :
> of the page
> status="M";
> ***here**
> model_iter.next();
> sch.update();
> - <xsd:all>
> </xsd:all>
> </xsd:group>
Re: ComplexTypeDefinition missing when encapsulated in an element [message #567037 is a reply to message #15710] Mon, 31 March 2003 16:29 Go to previous message
Kaunteya,
> hello,
> attribute as :
> of the page
> status="M";
> ***here**
> model_iter.next();
> sch.update();
> - <xsd:all>
> </xsd:all>
> </xsd:group>
Previous Topic:Eclipse API to remove elements and groups from Schema
Next Topic:Creating a sample XML instance from a XSD Schema
Current Time: Sun Jul 13 21:53:21 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
