Home » Eclipse Projects » Eclipse Platform » problems running 3.0M5 on XP
problems running 3.0M5 on XP [message #166568] Fri, 05 December 2003 15:19 Go to next message
Whenever I launch eclipse 3.0 (regardless of what workspace I point it to),
I'm getting the following stack trace:
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:861)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:767)
at org.eclipse.core.launcher.Main.main(Main.java:601)
Caused by: java.lang.NullPointerException
at org.eclipse.ui.keys.KeyStroke.hashCode(KeyStroke.java:517)
at java.util.HashMap.hash(Unknown Source)
at java.util.HashMap.get(Unknown Source)
org.eclipse.ui.internal.commands.KeySequenceBindingNode.add( KeySequenceBindingNode.java:174)
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.v alidateTree(KeySequenceBindingMachine.java:223)
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.v alidateSolution(KeySequenceBindingMachine.java:202)
org.eclipse.ui.internal.commands.KeySequenceBindingMachine.g etKeySequenceBindingsByCommandId(KeySequenceBindingMachine.j ava:72)
org.eclipse.ui.internal.commands.CommandManager.calculateKey SequenceBindings(CommandManager.java:270)
org.eclipse.ui.internal.commands.CommandManager.readRegistry (CommandManager.java:688)
org.eclipse.ui.internal.commands.CommandManager.<init>(CommandManager.java:229)
org.eclipse.ui.internal.commands.CommandManager.<init>(CommandManager.java:192)
org.eclipse.ui.commands.CommandManagerFactory.getCommandMana ger(CommandManagerFactory.java:41)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:736)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1358)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:237)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
... 8 more
I can still run my 2.1.2 build...
Anyone have any ideas?
Thanks.
Re: problems running 3.0M5 on XP [message #166576 is a reply to message #166568] Fri, 05 December 2003 15:31 Go to previous messageGo to next message
What VM are you using to run Eclipse?
Make sure that it is at least a 1.4.1 or greater using the -vm arg to point
to the correct install location of the JDK/JRE
HTH
Darins
"Mia Stern" <mia_stern@us.ibm.com> wrote in message
news:bqqp69$5d0$1@eclipse.org...
to),
> !STACK
> at
a:861)
> at
ngNode.java:174)
> at
> at
> at
dingsByCommandId(KeySequenceBindingMachine.java:72)
> at
> at
java:688)
> at
29)
> at
92)
> at
erFactory.java:41)
> at
> at
a:858)
> ... 8 more
> Thanks.
Re: problems running 3.0M5 on XP [message #166600 is a reply to message #166576] Fri, 05 December 2003 15:55 Go to previous message
That was the problem. Thanks.
Previous Topic:Clay Database Modelling
Next Topic:Windows Next Editor: Ctrl + Tab
Current Time: Mon Jul 14 10:53:16 EDT 2025
Powered by FUDForum. Page generated in 0.30840 seconds
