| Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #166 is a reply to message #156] |
Tue, 29 August 2006 04:16   |
Dear Peter,
I must apologize for the delay.
So,
For Linux building, please read the install section in the
README-en_US.8859-1.txt. as attached.
You can find it on download page.
http://www.eclipse.org/dsdp/nab/downloads.php
I am happy if I can help you.
Sincerely,
7.2 Linux Installation
Please install the Linux(GTK) version according to the following
procedure.
(1) JDK (JavaTM 2 SDK, Standard Edition Version 1.4.2) installation
http://java.sun.com/j2se/1.4.2/download.html
(2) WideStudio/MWT installation
Unzip ws-v3.94.1-src.tar.gz and execute the following commands on
the
console to install it.
It is offered by http://www.widestudio.org/EE/download.html.
$ cd <any directory>
$ tar -zxvf ws-v3.94.1-src.tar.gz
$ cd ws-v3.94-1/src
$ ./configure
$ make runtime
$ make mwt_java
$ su
# make install
At the end, please add the "/usr/local/lib" path to
LD_LIBRARY_PATH
environment variable.
(3) Eclipse 3.2.X (Linux version) installation
Unzip eclipse-SDK-3.2.X-linux-gtk.zip and install it. It is
distributed
from www.eclipse.org.
(4) CDT plug-in installation
Unzip org.eclipse.cdt.sdk-3.1.X-linux.x86.zip to the folder that
Eclipse
was installed. It is distributed from www.eclipse.org
(5) NAB plug-in installation
Unzip the following files to the folder that Eclipse was installed.
nab-mwt.linux-gtk.0.9.5.zip
nab-mwt.doc.0.9.5.zip
On Aug 08 2006 01:40:49
From peter.fodrek@xxxxxxxxxxxx (peter fodrek) wrote:
> Dear conference,
> I would like to use NAB as GUI producer, but project can not produce
makefile, Can anyone help me,pleas?
> Thank you for any help
> I look forward hearing from you
> Yours Faithfully
> Peter
| Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #222 is a reply to message #213] |
Tue, 20 February 2007 20:54  |
Hi Mike,
> Is the compleate GUI Hello world source code package includng make files
> available for download somewhare?
First, directly answers for your question is "there is no source
packages of Hello world.". Sorry.
The makefiles is modified when it's generating.
And, make.win is makefile for WideStudio oneself.
It's not template.
So, I am afraid of incomplete installation now.
If installation was completed, the install directory have about 600MB.
The default position is "C:\Program Files\WideStudio".
If you send file list about that we can check it.
Please get the file list in DOS command prompt as below.
C:\>tree /F "C:\Program Files\WideStudio" > tree.txt
And please send it(tree.txt) to me.
I will analyze that quickly.
Shigeki
Mike wrote:
> Thanks for your response.
> I have just (a few weeks ago) downloaded the WideStudio ver 3.96-1 and I
> don't find a match for the directory structure you refered to. The make
> file candidates (make.win) referes to mkfiles and a build results in
> +17300 errors ;). There is a large number of make_xx files to chose
> among (dll, nsp, exe, ...). Pleeeese help a confused beginner who realy
> want to get going with nab.
> /Mike
| Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #568652 is a reply to message #156] |
Dear Peter,
So,
Sincerely,
procedure.
the
$ cd ws-v3.94-1/src
$ ./configure
$ make runtime
$ make mwt_java
$ su
# make install
LD_LIBRARY_PATH
distributed
Eclipse
> Dear conference,
> Yours Faithfully
> Peter
| Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #568773 is a reply to message #203] |
Thu, 08 February 2007 03:38  |
Hi Mike,
NAB's makefile is copied from template file at WideStudio directory.
That place is
$(WSDIR)/sys/data/$(LANG)/make_xxxx
Please check these two environmental variables in DOS command or control
panel.
The WSDIR is set by installer.
And, if LANG is not set then NAB pick up that from Windows.
Which language version is your Windows? I guess your language is
Swedish, that's right?
Shigeki
Mike wrote:
> I too have folowed Tutorial of th NAB GUI, using my windows mashin, and
> also I miss the makefile. It was not produced as I folled the Tutorial.
> My problems started at section 2.7 Building and running ....
> Where did I go wrong??
> /Mike
| Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #568794 is a reply to message #206] |
Tue, 13 February 2007 15:14  |
+17300 errors ;). There is a large number of make_xx files to chose among
Pleeeese help a confused beginner who realy want to get going with nab.
/Mike
| Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #568825 is a reply to message #213] |
Hi Mike,
It's not template.
Shigeki
> /Mike
FUDForum. Page generated in 0.05250 seconds
