Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with ScolledComposites and TabFolder
Problem with ScolledComposites and TabFolder [message #15694] Tue, 10 April 2007 07:57 Go to next message
Originally posted by: roberto.sanchez.autonomind.com
Hi all,
Can I use a ScrolledComposite like principal control for my TabItems
(method setControl(...)) in a TabFolder ?
When I use only 1 ScrolledComposite, that is, only for 1 TabItem works
fine, but when I use 2 o more ScrolledComposite for several TabItems It
happens a rare problem, the Workbench never get completed, The others
ViewParts don't appear in screen.
If I run in debug mode the execution (automatically) stops in method:
WidgetUtil.getAdapter( final Widget widget )
in line:
result = ( IWidgetAdapter )widget.getAdapter( IWidgetAdapter.class );
It seems like if there was a breakpoint in that line, but there isn't
anyone.
I'm using the last version of CVS RAP code.
Any idea ?
Thanks in advance.
This is my code:
package test;
import org.eclipse.rap.rwt.RWT;
import org.eclipse.rap.rwt.custom.ScrolledComposite;
import org.eclipse.rap.rwt.layout.FillLayout;
import org.eclipse.rap.rwt.widgets.Composite;
import org.eclipse.rap.rwt.widgets.TabFolder;
import org.eclipse.rap.rwt.widgets.TabItem;
import org.eclipse.rap.ui.PlatformUI;
import org.eclipse.rap.ui.part.ViewPart;
public class TabFolderViewPart extends ViewPart {
protected TabFolder folder = null;
public void createPartControl(Composite parent) {
parent.setLayout( new FillLayout() );
folder = new TabFolder( parent, RWT.FLAT );
TabItem item = new TabItem( folder, RWT.FLAT );
item.setText( "Tab ONE" );
item.setControl(new ScrolledComposite(folder, RWT.NONE));
item.setText( "Tab TWO" );
parent.layout();
public void setFocus() {
cvTabs.forceFocus();
Re: Problem with ScolledComposites and TabFolder [message #15716 is a reply to message #15694] Tue, 10 April 2007 09:37 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Roberto,
there was a bug in a JavaScript file (ScrolledComposite.js). If you
check out the latest version from CVS, your example should work.
Thanks for reporting this issue.
Ralf
> in line:
> anyone.
> Any idea ?
> Thanks in advance.
> This is my code:
> package test;
> @Override
> parent.layout();
Re: Problem with ScolledComposites and TabFolder [message #15734 is a reply to message #15716] Tue, 10 April 2007 09:48 Go to previous message
Wow!! That was really fast !! Good work !! ;-)
Thank you very much, now It works perfect. :-)
Bye.
Ralf Sternberg wrote:
> Hi Roberto,
> Cheers,
> Ralf
>> It happens a rare problem, the Workbench never get completed, The
>> others ViewParts don't appear in screen.
>> in line:
>> anyone.
>> Any idea ?
>> Thanks in advance.
>> This is my code:
>> package test;
>> @Override
>> parent.layout();
Previous Topic:M2 build - source attachment did not work
Next Topic:poor performance in Tree Views
Current Time: Mon Jul 21 21:07:17 EDT 2025
Powered by FUDForum. Page generated in 0.05774 seconds
