Home » Newcomers » Newcomers » Project Configuration Tutorial
Project Configuration Tutorial [message #166370] Fri, 18 August 2006 17:35 Go to next message
Originally posted by: sunil-x.gupta.db.com
Hi.
I'm going through the Project Configuration Tutorial in the Eclipse 3.2
help files. In step 4 of the first section, "Detecting existing layout",
it says "and choose the Product directory on drive D:", but there is no
"Product" directory, and I don't see when we were suppose to create it.
Did anyone else notice this?
Sunil
Re: Project Configuration Tutorial [message #166388 is a reply to message #166370] Fri, 18 August 2006 20:43 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Sunil Gupta wrote:
> Hi.
> layout", it says "and choose the Product directory on drive D:", but
> there is no "Product" directory, and I don't see when we were suppose to
> create it. Did anyone else notice this?
> Sunil
The "Detecting existing layout" tutorial assumes that you already have
an existing project where the source code is in a sub directory called
src and the class files are build to a sub directory called bin. If you
don't have an existing project, you won't be able to complete the tutorial.
Re: Project Configuration Tutorial [message #166555 is a reply to message #166388] Mon, 21 August 2006 14:17 Go to previous message
Thanks. I'll simply create one as specified and then proceed.
Previous Topic:Additional information of Content Assist
Next Topic:How can i unpack the launch config file while installing plugin?
Current Time: Mon Jul 14 15:46:00 EDT 2025
Powered by FUDForum. Page generated in 0.07675 seconds
