Home » Eclipse Projects » Eclipse Website » local style sheet file
local style sheet file [message #15689] Fri, 13 January 2006 12:12 Go to next message
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
In the process of converting all our web pages to the phoenix style, I'd
like to know if it is possible to define a local cascading stype sheet?
We find that the links (<a></a> tag) are a little too light and we would
like to have all of them bold. I'd like to do this using a css file
instead of modifying each <a> tag.
I don't know if this is doable. I don't see where this could be inserted
in the templates files.
Thank you.
Olivier
Re: local style sheet file [message #16123 is a reply to message #15689] Fri, 13 January 2006 13:36 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Phoenix doesn't provide for a local CSS file specifically, but you can
add your style changes to _projectCommon.php so that they are applied to
all the pages in your directory.
Outside of the <?php ?> markers of _projectCommon.php, add
<style type="text/css">
a { your style here }
</style>
Olivier Thomann wrote:
> Thank you.
> Olivier
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: local style sheet file [message #568351 is a reply to message #15689] Fri, 13 January 2006 13:36 Go to previous message
</style>
> Thank you.
> Olivier
Previous Topic:local style sheet file
Next Topic:Add some indentation inside the <div id="midcolumn"> section
Current Time: Sat Jun 07 17:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.02641 seconds
