The report file of version "3.2.2" is not supported [message #165862] |
Wed, 31 May 2006 00:51 |
hi,
i am trying to generate xls file in birt.
i generated test.rptdesign using birt 2.1RC3a in eclipse 3.2.
i am running this porgram under birt 2.1 RunTime plugins.
but i am getting following error
let me know the cause of these error.
Error Details :
Report Name :d:\test.rptdesign
May 30, 2006 6:22:01 PM
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
SEVERE: invalid design file d:\test.rptdesign
org.eclipse.birt.report.engine.api.EngineException: The design file
d:\test.rptdesign has error and can not be run.
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:110)
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:219)
at com.Report.generate(Report.java:118)
at com.MyReport.main(MyReport.java:49)
Caused by: Error.DesignFileException.INVALID_XML - 1 errors found!
1.) ( line = 0, tag = null)
org.eclipse.birt.report.model.parser.DesignParserException (code =
Error.DesignParserException.UNSUPPORTED_VERSION, message : The report file
of version "3.2.2" is not supported.)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:111)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:171)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:135)
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:208)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:174)
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:105)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:103)
... 3 more
regards
Venkata R
FUDForum. Page generated in 0.05819 seconds
