Home » Language IDEs » C / C++ IDE (CDT) » Question about Make Target pane
Question about Make Target pane [message #165835] Tue, 14 March 2006 14:18 Go to next message
Originally posted by: andre_oriani.ig.com.br
In the Make Target pane I can create new targets that are combination of
targets from a makefile and even define a diferent build command from
default.
But these targets only work if I tell Eclipse how to perform a full build
in Project>Properties>C/C++ Make Project.
Is there any way to build the targets created in the Make Target pane
without having to set up a target for rebuild(full build)? Is it possible
to prevent Eclipse to do a rebuild after making the targets created in the
Make Target pane?
Thanks for your attention,
André Oriani
Re: Question about Make Target pane [message #165881 is a reply to message #165835] Wed, 15 March 2006 12:30 Go to previous messageGo to next message
Originally posted by: arne.anka.ginguppin.de
for some reasons eclipse sometimes and unpredictable uses the "full
rebuild"-command rather than simple "build" and thus without warning
cleans your whole project which means you may have to wait hours to
re-build the stuff ...
i did not notice a relation to the targets but i changed the settings for
a full rebuild to the same as for simple build and made an target to
rebuilt (make -j4 distclean all) in the "make targets"-view.
so it may help if you do so as well and change the settings in your
project's properties.
regards
On Tue, 14 Mar 2006 20:18:28 +0100, André Oriani <andre_oriani@ig.com.br>
> default.
> build in Project>Properties>C/C++ Make Project.
> possible to prevent Eclipse to do a rebuild after making the targets
> created in the Make Target pane? Thanks for your attention,
> André Oriani
Re: Question about Make Target pane [message #165889 is a reply to message #165881] Wed, 15 March 2006 12:40 Go to previous message
Originally posted by: ddaoust.ca.ibm.com
You may wish to look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=62772
I have been attempting to clean up this behavior....
I would suggest that for now, you remove the "clean" part of the Full
Build target of all standard make projects. For managed build projects
there is currently no workaround.
- Dave
> for a full rebuild to the same as for simple build and made an target
> to rebuilt (make -j4 distclean all) in the "make targets"-view.
> regards
>> of targets from a makefile and even define a diferent build command
>> from default.
>> André Oriani
Previous Topic:CDT error parser doesnŽt understand wrapped messages
Next Topic:code completion not working anymore in "standard" C++ projects
Current Time: Thu Jul 24 17:16:59 EDT 2025
Powered by FUDForum. Page generated in 0.03855 seconds
