Home » Archived » BIRT » Chart title at runtime
Chart title at runtime [message #165829] Tue, 30 May 2006 20:45 Go to next message
Originally posted by: dtsjunk.fastmail.fm
Hi I am using Birt 2.0.1 and I have a question about setting the title of
a chart in the beforeGeneration method.
I have a table that is bound to a scripted dataset and a chart that is
also bound to a different scripted dataset.
Table has 2 rows first row is based on object from 1st dataset and second
row contains a dual axis line chart that is populated based on the
value of the 1st row. That is working fine. I want to set the title of the
chart to the value in the first row and i can't seem to
figure out how. I have tried setting a report parameter in the expression
builder of the first row and accessing it via
context.getExternalContext().getScriptable().getParameterVal ue() and it
always seems to be null.
Also tried using a GlobalVariable and that to is also null.
Any help or pointer to where I am going wrong.
DT
Re: Chart title at runtime [message #165855 is a reply to message #165829] Tue, 30 May 2006 22:40 Go to previous messageGo to next message
Update:
When I view the report in pdf it works fine the chart title gets displayed
correctly. However when I view as html the title remains blank.
Re: Chart title at runtime [message #166035 is a reply to message #165829] Wed, 31 May 2006 10:17 Go to previous message
in the beforeGeneration method of chart scripting, you can access the
dataset inside the series and get the first value, then set it in the title.
David
"dt" <dtsjunk@fastmail.fm> wrote in message
news:7150eb0abfb5a4bf53116ddcbefc2f47$1@www.eclipse.org...
> chart to the value in the first row and i can't seem to figure out how. I
> have tried setting a report parameter in the expression builder of the
> Thanks
> DT
Previous Topic:How to create Bar chart using Chart API
Next Topic:Running Group Counter
Current Time: Sat Jul 26 06:03:36 EDT 2025
Powered by FUDForum. Page generated in 0.04185 seconds
