Home » Language IDEs » C / C++ IDE (CDT) » Will the debugger show variable values?
Will the debugger show variable values? [message #165809] Tue, 14 March 2006 07:51 Go to next message
Originally posted by: Bil.Lambdacs.com
I have been unable to find any way to display variable values
when in the debugger (GDB). I KNOW GDB can display variables.
But there is nothing in the documentation, nothing I could figure
out from the GUI, that will actually display variables in CDT.
-Bil
<B>(What does the msg board do with HTML tags?)</B>
Re: Will the debugger show variable values? [message #165874 is a reply to message #165809] Wed, 15 March 2006 11:49 Go to previous messageGo to next message
Originally posted by: alexfarberov.[nospam]hotmail.com
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/C_C++_Development_Toolkit_User_Guide.pdf?cvsroot=T ools_Project
In "Debug Information" there is an explanation...
If you only want to check one or two variables of interest, in debug
view, hover your mouse over the variable to see the values or highlight
them, right click and set a watch
> -Bil
Re: Will the debugger show variable values? [message #165905 is a reply to message #165874] Wed, 15 March 2006 18:44 Go to previous messageGo to next message
Ah! That helps!
Now it's just a matter of it being so buggy as to be almost worthless. :-(
I notice that a char* displays as the first char only. And "Step Over"
sometimes
just jumps to mysterious places. And some things just display a popup
saying
something doesn't work. And this for a 100 line program. !@$!$!???
I used to work at Sun. DBX wasn't the most beautiful debugger, but by god
it worked.
I'm just horrified at the quality in Eclipse. What's the problem? :-(
Sorry, don't mean to be so negative. I do appreciate the guidance.
Sometimes "Don't
do that" is good advice.
-Bil
Re: Will the debugger show variable values? [message #165927 is a reply to message #165905] Thu, 16 March 2006 02:05 Go to previous message
Hi Bill,
a few more hints:
The tooltip for a char* displays the whole string. Also, if you select the
char* variable in the Variables view then the whole string will be displayed
in the details area of the Variables view.
> And "Step Over" sometimes
I experienced that when I had some optimization switched on when compiling.
So eclipse just reflects the line number information and what your compiler
was doing.
Hope you have more joy now
Norbert
Previous Topic:error launching debugger
Next Topic:filtype highlighting
Current Time: Wed Oct 29 15:58:55 EDT 2025
Powered by FUDForum. Page generated in 0.04036 seconds
