inject/extract ATL-0.2 file/ATL-0.2 model [message #15617] |
Wed, 07 February 2007 08:59  |
Originally posted by: kehrer.hdm-stuttgart.de
I'm working on Model weaving and on traceability, and I would like to
use a HOT (Higher Order Transformation) for this.
I've seen in 2 tutorials : ATL2Tracer & ATL2WTracer, that there is a
feature in AM3 plugin that allows to inject an atl file (.atl) in an
atl model (.ecore) and vice versa.
Doing the following "roundtrip" sometimes works, sometimes results in
incorrect or empty .atl-files
[atl-model_1].atl ----------------------->
atl-model].ecore -------------------> [atl-model_2].atl
Incection to Ecore
Extraction to atl
I think [atl-model_1] and [atl-model_2] always have to be identical (Despite
on differences in format).
I'm using the eclipse-bundle available on
http://www.sciences.univ-nantes.fr/lina/atl/atldemo/adt.
Can anyone give me some hints?
Thank you for your help
Timo Kehrer
[ATL] Re: inject/extract ATL-0.2 file/ATL-0.2 model [message #15649 is a reply to message #15617] |
Wed, 07 February 2007 11:07   |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
Hi Timo,
Maybe you are using elements of the ATL metamodel that are not yet supported by the
injectors/extractors from the ATL bundle, just in the newer versions of ATL (e.g., ATL2006).
It is possibly the case of the entrypoint rules from the ATL2WTracer use case.
Marcos.
Timo Kehrer wrote:
> Hello,
> Incection to Ecore
> Extraction to atl
> Timo Kehrer
Re: [ATL] Re: inject/extract ATL-0.2 file/ATL-0.2 model [message #15708 is a reply to message #15649] |
Thu, 08 February 2007 11:55   |
is there any documentation about which elements are supportet by the
extractors/injectors and which are not?
Would be very helpful...
Thank you
Timo
"Marcos Didonet Del Fabro" <marcos.didonet-del-fabro@univ-nantes.fr> schrieb
im Newsbeitrag news:45C9F929.6020603@univ-nantes.fr...
> Hi Timo,
> supported by the injectors/extractors from the ATL bundle, just in the
> case.
> Marcos.
> Timo Kehrer wrote:
>> Hello,
>> Incection to Ecore Extraction to atl
>> (Despite on differences in format).
>> Regards,
>> Timo Kehrer
Re: [ATL] Re: inject/extract ATL-0.2 file/ATL-0.2 model [message #15729 is a reply to message #15708] |
Thu, 08 February 2007 15:22  |
Hi Timo,
Normally, all the elements of the ATL metamodel are supported by the latest version of
ATL: ATL2006. It can be installed through the sources (the installation guide is available
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/gmt- home/subprojects/ATL/doc/ATL_Installation_Guide%5Bv0.1%5D.pd f).
Unfortunately, concerning the ATL bundle, there is not a documentation about the supported
elements. The main reason is that the plug-ins are being constantly improved, and we
intend to release a new bundle soon.
Marcos.
> Thank you
> Timo
>> Hi Timo,
>> case.
>> Regards,
>> Marcos.
>> Timo Kehrer wrote:
>>> Hello,
>>> Regards,
>>> Timo Kehrer
FUDForum. Page generated in 0.95423 seconds
