web/WEB-INF/classes/ shows up in "Open Type" [message #165547] |
Fri, 31 March 2006 11:58  |
Originally posted by: dserodio.gmail.com
When I select "Open Type", I'm offered two copies of each class, one in
my source folder, and another one under web/WEB-INF/classes/ (which is
configured as my "Default output folder" in the project's Java Build Path.
Is this a bug? Or a hidden setting somewhere?
Thanks in advance,
Daniel Serodio
Re: web/WEB-INF/classes/ shows up in "Open Type" [message #165884 is a reply to message #165763] |
Tue, 04 April 2006 16:02  |
K.C Baltz wrote:
> This sounds like a bug. You might be able to fix or work around it by
> marking the classes folder as "derived". Find the folder in the Navigator
> view, right-click and select properties... and select "derived". I know
> that will keep the contents out of the Open Resources and I think it will
> also keep them out of Open Type.
Bug #134771 filed.
> "Daniel Serodio" <dserodio@gmail.com> wrote in message
> news:e0jn34$url$1@utils.eclipse.org...
Daniel Serodio
FUDForum. Page generated in 0.06371 seconds
