Home » Eclipse Projects » GEF » Direct Edit on creation
Direct Edit on creation [message #165516] Tue, 25 January 2005 11:57 Go to next message
Originally posted by: spam.nospam.com
Hi all,
does anyone know of a way I can trigger a direct edit request whenever
the creation tool results in the creation of an EditPart that provides a
DIRECT_EDIT_ROLE?
For example, in the Logic example; whenever a Sticky note is added, I
want to trigger direct edit immediately.
TIA
Pat Turner
Re: Direct Edit on creation [message #165532 is a reply to message #165516] Tue, 25 January 2005 15:01 Go to previous messageGo to next message
Override handleCreate in the creation tool, and get the editpart using the
viewer's editpart registry. The object created can be obtained from the
request assuming that's where the executed command got it. Send the
necessary request to that part.
"Pat" <spam@nospam.com> wrote in message news:ct5tq3$9e$1@www.eclipse.org...
> Hi all,
> does anyone know of a way I can trigger a direct edit request whenever the
> DIRECT_EDIT_ROLE?
> For example, in the Logic example; whenever a Sticky note is added, I want
> TIA
> Pat Turner
Re: Direct Edit on creation [message #165632 is a reply to message #165532] Wed, 26 January 2005 03:22 Go to previous message
Thanks Randy.
I guess you meant to say override performCreation(int button) though - I
can't find handleCreate().
Pat
>>Hi all,
>>DIRECT_EDIT_ROLE?
>>TIA
>>Pat Turner
Previous Topic:How to add two or more connections between two editpart?
Next Topic:Problem with IFileEditorInput
Current Time: Sat Jul 26 20:55:22 EDT 2025
Powered by FUDForum. Page generated in 0.04325 seconds
