| How to generate the diagram of the subpackages in a metamodel desribed in ecore? [message #165477] |
Fri, 14 December 2007 11:25  |
As we know, we can right click an ecore model in the navigator of
eclipse to generate the diagram file for this model. Open this diagram file,
then we can visulize the model. However, only the classes in the topmost
packages will be drawn on the diagram. I also hope to visulize the classes
in the sub-packages. I don't know how to do it.
Thanks for your hint.
Michael.
| Re: How to generate the diagram of the subpackages in a metamodel desribed in ecore? [message #165683 is a reply to message #165660] |
Mon, 17 December 2007 11:15  |
Sorry, DND for Drag and Drop.
Michael a écrit :
> Hi Jacques:
> Thanks for your help. I have no idea of Ecore Tools project. Anyway, I
> will try it and give you some feedback.
> However, would you please tell me what DND stands for?
> Thanks.
> Michael.
> "Jacques LESCOT" <jacques.lescot@anyware-tech.com> wrote in message
> news:fk5kv3$5fs$1@build.eclipse.org...
>> Michael,
>> Do you want to visualize all of them on the same diagram ?
>> - If yes, you can try to DND the expected class from the Project Explorer
>> view.
>> - If no, you can probably double click on the Package you want to go into
>> : this will create a new diagram and will populate with the EClasses that
>> are contained inside.
>> A little advertisement ... Do you know the Ecore Tools project ? Feel free
>> to use try it and give us your feedback about missing features that you
>> would expect ! ;-)
>> Regards,
>> Jacques
>> Michael a écrit :
>>> Hi,
>>> file, then we can visulize the model. However, only the classes in the
>>> topmost packages will be drawn on the diagram. I also hope to visulize
>>> the classes in the sub-packages. I don't know how to do it.
>>> Michael.
FUDForum. Page generated in 0.04289 seconds
