Home » Archived » BIRT » Chart with dates on X axis
Chart with dates on X axis [message #165407] |
Mon, 29 May 2006 13:28  |
Hi there,
Why isn't it possible to get a linear axis with dates ?
I'd like to show up a series of dates that are not day-to-day but want to
see the "not used" dates within them.
In my precise case, I only use hours and minutes and would like to set the
X axis from 00:00:00 to 23:59:59
It seems, above of this, that the formatting is out of order ; I have a
Long in my DataSet (say "foo"), that I put in X series with new
Date(row["foo"]) and then set the Format as
"Date/Time,Advanced,Pattern=hh:mm"...
But the columns show the entire date (that is "1970...").
Last : I thought I saw somewhere that a chart does not support multiple
datasets ; despite this is really sad, I'd like to now is somebody has
workarounds for this point.
NB : BIRT RC3
Thanks, Thomas.
Re: Chart with dates on X axis [message #165972 is a reply to message #165407] |
Wed, 31 May 2006 10:05   |
Did you set the Axis type as Date/Time?
David
"Thomas Escolan" <thomas_escolan@yahoo.fr> wrote in message
news:f632d90d4c1427ccad0a1fc7052e47a5$1@www.eclipse.org...
> Hi there,
> NB : BIRT RC3
> Thanks, Thomas.
Re: Chart with dates on X axis [message #166323 is a reply to message #166252] |
Thu, 01 June 2006 07:37   |
Sorry, I missed that, now I understand the issue. Did you try using a
scatter chart? Linear X Axis can only be used with scatter charts, since it
would not fit a bar chart model. Then you can try setting the format as
date/time on that X Axis and see what happens. I think it should work.
If the scale doesn't adapt well to the axis format, you can file a bug, but
I thought it was working?
David
news:3397ed6025f25c7f745537a85b89a806$1@www.eclipse.org...
> Yes, David, as quoted :
> [set the Format as "Date/Time,Advanced,Pattern=hh:mm"]
> Thanks for interesting
> => is the scale dialog adapting to the axis format, anyway ?
> Thomas.
Re: Chart with dates on X axis [message #166601 is a reply to message #166483] |
Thu, 01 June 2006 11:37   |
Thomas,
Here is what I managed to do (see attachment).
Is it what you want?
David
news:cc1145ccdd697dff568b533d7c3fae18$1@www.eclipse.org...
> OK, I tried the scatter chart :
> As I said (?), I have three values in my series : a Long corresponding to
> a java.sql.Time, two integers for the charts to be shown.
> Then I've built the scatter chart with X axis' scale (-3600000.0,
> 82799000.0, 3600000.0) in order to range from 01/01/1970 00:00:00 to
> 01/01/1970 23:59:59 on hours.
> NB : the scatter chart would refuse a Date or Time for X axis.
> Then, I specified a Date/Time format with pattern "HH:mm" (without the
> quotes) on X series (the Long values)... but the Long value still stays as
> a label. There's nothing I can figure out to work this around on scripting
> the beforeDrawAxisLabel chart's method :
> var value = java.lang.Long.parseLong(label.getCaption().getValue());
> label.getCaption().setValue(new
> java.text.SimpleDateFormat("HH:mm").format(new java.util.Date(value)));
> does nothing, thought this would change the Y axis' labels too, isn't it ?
> Sould I wait for the series format to work ? Is it supporting automatic
> conversion from Long to Date as it is declared so ?
Attachment: dates.bmp
(Size: 153.05KB, Downloaded 199 times)
Re: Chart with dates on X axis [message #166902 is a reply to message #166863] |
Fri, 02 June 2006 04:41   |
If you see a compatibility issue with RC4, please file a bugzilla entry.
Here is the report. You will need to create some data for it.
I guess your problem comes from the conversion from long to date?
David
news:1e57095911516a36d4ea90606802c4b8$1@www.eclipse.org...
> Sorry, David, but I'm browsing the newsgroup with eclipse.org's viewer and
> your attachment is ASCII translated...
> May I see the XML report file ?
> Beside this, I got RC4 this morning and one of my datasets works no more :
> => org.eclipse.birt.chart.exception.ChartException: The DataSet bound to
> the
> chart returned no rows.
> => An error happened in data type conversion.
> Can not convert the value of 1.147789487E12 to Date type.
> The only date this dataset is dealing with is a string report parameter
> that is imported, as explained in doc, with Date.parse(params["date"]).
> Then, this parameter is no longer used, as th scripted methods won't
> access it (as seen together earlier).
> Shall I remove these or is ther something wrong with it that could be
> updated ?
Re: Chart with dates on X axis [message #166998 is a reply to message #166910] |
Fri, 02 June 2006 07:54   |
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.1.0.qualifier
Build <@BUILD@></property>
<property name="units">in</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Data Source" id="4">
<property name="odaDriverClass">sun.jdbc.odbc.JdbcOdbcDriver</property >
<property name="odaURL">jdbc:odbc:chartdata</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="5">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">Time</property>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">Value</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<property name="queryText">select *
from "Time"</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" id="6">
<property name="height">3.166in</property>
<property name="width">5.333in</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["Time"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Value"]</expression>
</structure>
</list-property>
<xml-property name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Scatter Chart</Type>
<SubType>Standard Scatter Chart</SubType>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Scatter Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value><undefined></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Position>Right</Position>
<ItemType>Series</ItemType>
<Title>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>383.25</Width>
<Height>227.25</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>01/01/2006,03/09/2006,12/31/2006</DataSetRepresentation >
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity/>
<Axes>
<Type>DateTime</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:ScatterSeries">
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["Value"]</Definition>
</DataDefinition>
<SeriesIdentifier><undefined></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Above</LabelPosition>
<Stacked>false</Stacked>
<Markers>
<Type>Crosshair</Type>
<Size>5</Size>
</Markers>
<Markers>
<Type>Box</Type>
<Size>5</Size>
</Markers>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<PaletteLineColor>false</PaletteLineColor>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
<MinorGridsPerUnit>5</MinorGridsPerUnit>
</Scale>
<Origin>
<Type>Min</Type>
<Value xsi:type="data:NumberDataElement">
<Value>0.0</Value>
</Value>
</Origin>
<PrimaryAxis>true</PrimaryAxis>
<Percent>false</Percent>
</AssociatedAxes>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series>
<Label>
<Caption>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["Time"]</Definition>
</DataDefinition>
<DataPoint>
<Components>
</Components>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
</Series>
<Grouping>
</Grouping>
<Orientation>Horizontal</Orientation>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Font>
<Alignment/>
<Rotation>45.0</Rotation>
</Font>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<FormatSpecifier xsi:type="attribute:JavaDateFormatSpecifier">
<Pattern>hh:mm:ss</Pattern>
</FormatSpecifier>
<LabelPosition>Below</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</LineAttributes>
<TickAttributes>
<Color>
<Red>225</Red>
<Green>225</Green>
<Blue>225</Blue>
</Color>
</TickAttributes>
</MinorGrid>
<Scale>
</Scale>
<Origin>
<Type>Min</Type>
<Value>0.0</Value>
</Value>
</Origin>
<CategoryAxis>false</CategoryAxis>
</Axes>
<Rotation/>
</model:ChartWithAxes>
]]></xml-property>
<property name="outputFormat">PNG</property>
</extended-item>
</body>
</report>
news:ec47d81e73030612e9faa71d931f27e1$1@www.eclipse.org...
>I don't know if this is a bug issue, my previous setting was a workaround
>because the default dates value was not correctly parsed, if you remember.
>Maybe the JavaScript function I used does not support this format, now ?
> I'll dig this a bit.
> Sorry, again, but your report file is binary encoded in this web viewer.
> Would you provide a copy and paste of the XML Source view ?
> Thanks, Thomas.
Re: Chart with dates on X axis [message #167053 is a reply to message #167029] |
Fri, 02 June 2006 09:31   |
Hi Thomas,
The series formatting is useful when you display the value of the category
series, it doesn't apply to the values on the axis (which can be different).
For the scale not working, it seems to be a bug, can you file it in
bugzilla?
David
news:233ddc8fa90f342342f8ad7e71e8d9ec$1@www.eclipse.org...
> OK, understood, so you directly get a date type from your resultset and
> the format is on the axis properties, not on the "select data" tab. But,
> then I wonder what the format button is for on X series there. Anyway.
> Last trick : I don't succeed in specifying a scale for the X axis since it
> is datetime typed. I tried 1970-01-01 00:00:00, for the min value, but it
> get erased when I leave the field.
> How do it works ?
Current Time: Fri Jul 18 13:39:12 EDT 2025
Powered by FUDForum. Page generated in 0.28137 seconds
