Home » Language IDEs » ServerTools (WTP) » Installing via update, requirements error
Installing via update, requirements error [message #165311] Wed, 29 March 2006 14:01 Go to next message
Originally posted by: lmajano.sandals.com
I am trying to install the WTP through the update site. I installed all
the requirements in the update site, however, when I select the WTP I get
the following:
org.eclipse.wst.server_core.feature (1.0.1.v200602151554) requires
feature "org.eclipse.rcp (3.1.1)", or equivalent.
Where can I get the rcp feature??
What Am I missing? Please help!!!
Re: Installing via update, requirements error [message #165336 is a reply to message #165311] Wed, 29 March 2006 20:28 Go to previous messageGo to next message
> get the following:
http://download.eclipse.org/eclipse/downloads/drops/R-3.1.1- 200509290840/index.php
middle of the page - RCP SDK
Re: Installing via update, requirements error [message #165435 is a reply to message #165311] Thu, 30 March 2006 15:49 Go to previous messageGo to next message
Luis,
It thinks you are running an Eclipse prior to 3.1.1 which is the minimum
level that has the update site functionality at the required level.
Click Help > About Eclipse SDK and check what release you are running.
If you can, I recommend starting with a clean Eclipse 3.1.2 and doing
the update on that.
Chris
Re: Installing via update, requirements error [message #166040 is a reply to message #165311] Thu, 06 April 2006 06:44 Go to previous message
Thanks guys, I will try this today. I am running Version: 3.2.0
Build id: I20060223-1656
Luis
Previous Topic:methods in dependent package, WTP 1.0, Eclipse 3.1.2
Next Topic:org.eclipse.wst.tests.feature is enabled even though org.eclipse.test feature is missing
Current Time: Sat Jul 19 10:10:08 EDT 2025
Powered by FUDForum. Page generated in 0.19579 seconds
