RC3 and JDK_1_5 CVS branch [message #165281] |
Mon, 21 June 2004 08:41  |
Originally posted by: igorf.ca.ibm.com
Does anyone have problems getting JDK_1_5 branch from CVS using RC3? For
some reason RC3 does not "see" JDK_1_5 tag for most (or all?) of the
files in org.eclipse.jdt.core. Command line cvs seems to be fine.
Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165812 is a reply to message #165322] |
Thu, 24 June 2004 21:00   |
By the way, is it only me having problems with
/org.eclipse.jdt.core/search/org/eclipse/jdt/internal/core/s earch/indexing/IndexManager.java
in JDK_1_5 branch in org.eclipse.jdt.core module?
The field containerPath is defined in an inherited type and an enclosing
scope
org.eclipse.jdt.core/search/org/eclipse/jdt/internal/core/se arch/indexing
/IndexManager.java line 574
regards,
Eugene
Igor Fedorenko wrote:
> Never mind, deleted local copy of org.eclipse.jdt.core, got new one from
> CVS and everything is ok now. Sorry for the noise.
>> Nope, that did not help. The only file that has JDK_1_5 is .project.
>> Can you check for example branches for build.properties? The real
>> problem is, when I checkout sources of JDK_1_5 branch I get a lot of
>> java sources from the HEAD. I'll rollback to RC2 to see if it helps.
>> Philippe Mulet wrote:
>>> I can see it, after forcing to refresh branches.
>>> "Igor Fedorenko" <igorf@ca.ibm.com> wrote in message
>>> news:cb6l10$2ek$1@eclipse.org...
>>>> Hi,
>>>> For
>>>> Regards,
>>>> Igor Fedorenko
Re: RC3 and JDK_1_5 CVS branch [message #165849 is a reply to message #165812] |
Fri, 25 June 2004 06:08  |
Everything compiles fine here. Did you check that all your sources
actually come from JDK_1_5 branch?
Igor Fedorenko
> scope
> regards,
> Eugene
>> from CVS and everything is ok now. Sorry for the noise.
>>>>> Hi,
>>>>> RC3? For
>>>>> Regards,
>>>>> Igor Fedorenko
FUDForum. Page generated in 0.10621 seconds
