Home » Eclipse Projects » Eclipse Platform » PluginRegistry.getPluginDescriptors() no longer topologically sorted
PluginRegistry.getPluginDescriptors() no longer topologically sorted [message #165268] Wed, 03 December 2003 10:30 Go to next message
I have code which relies on getPluginDescriptors() returning an array such
that:
if plug-in A requires plug-in B, then indexOf(A) > indexOf(B)
This used to work (unless you had dependency cycles, I suppose). Anyway, I
guess I can fix my code pretty easily by doing it myself.
Re: PluginRegistry.getPluginDescriptors() no longer topologically sorted [message #165356 is a reply to message #165268] Wed, 03 December 2003 11:22 Go to previous messageGo to next message
Originally posted by: meshcheryakovsemen.hotmail.com
Topological sorting...
-- Sam
It's better to view source code than comments to it.
Re: PluginRegistry.getPluginDescriptors() no longer topologically sorted [message #165364 is a reply to message #165268] Wed, 03 December 2003 11:23 Go to previous messageGo to next message
Actually, I'm having some other problem that made me thing this was the
issue.
For some reason, my plug-ins have prereqs containing
"org.eclipse.ui.jface.text". But, there is no such plug-in. This happened
when migrating to M5, and reusing the target workspace from previous drops.
I'll have to investigate where the repreq is coming from, as the plugin
which requires it simply imports "org.eclipse.ui".
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bqkveb$bo1$1@eclipse.org...
> that:
I
Re: PluginRegistry.getPluginDescriptors() no longer topologically sorted [message #165371 is a reply to message #165364] Wed, 03 December 2003 11:36 Go to previous messageGo to next message
Found the problem : "Compatability support misses jface.text". 47463
So, when I went to look up an entry for this bogus pre-req, it didn't exist.
I had originally thought it was a valid pre-req, and jumped to the wrong
conclusion.
news:bql2h7$g9b$1@eclipse.org...
> issue.
happened
drops.
such
> > that:
Anyway,
> I
Re: PluginRegistry.getPluginDescriptors() no longer topologically sorted [message #166660 is a reply to message #165268] Fri, 05 December 2003 19:15 Go to previous message
Originally posted by: pascal_rapicault.yahoo.fr
If you are using a drop post M5, it is probably a bug in the backward
compatibility layer.
PaScaL
"Randy Hudson" <none@us.ibm.com> a
Previous Topic:Eclipse platform runtime
Next Topic:How to Navigate eclipse.org website
Current Time: Sat Jul 26 14:44:27 EDT 2025
Powered by FUDForum. Page generated in 0.33259 seconds
