Home » Newcomers » Newcomers » Eclipse Visual Editor
Eclipse Visual Editor [message #165252] Fri, 11 August 2006 12:04 Go to next message
Originally posted by: matthew.tyler.young.gmail.com
I have recently noticed that eclipse has a project available for a
Visual Editor project. Is this supposed to be a drag and drop GUI
development plug in similar to .NET??
Re: Eclipse Visual Editor [message #165302 is a reply to message #165252] Fri, 11 August 2006 14:41 Go to previous messageGo to next message
Originally posted by: ali4ever4.gmail.com
yes and it is much better ( just as i see it)
but you really should try it its coool
Re: Eclipse Visual Editor [message #165318 is a reply to message #165302] Fri, 11 August 2006 14:48 Go to previous messageGo to next message
So I have downloaded the Visual Editor through the Software update in
Eclipse 3.2 but I cant figure out how to open up the Visual Editor or
how to interface with it. Can anyone help me out or point me to a
tutorial on the VE?
-Thanks
Re: Eclipse Visual Editor [message #165410 is a reply to message #165318] Sat, 12 August 2006 08:14 Go to previous message
> tutorial on the VE?
> -Thanks
Start the wizard with
File > New > Visual Class
or, if that's not in the list, use
File > New > Other... > Java > Visual Class
Choose the desired entry in the wizard's Style list (Swing/AWT/SWT/RCP &
application/frame/shell/etc.).
< http://www-128.ibm.com/developerworks/opensource/library/os- ecvisual/>
<http://www.eclipse.org/vep/WebContent/docs/doc.html>
< http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. ve.doc/topics/cve_designsource.html>
Roland
Previous Topic:Plugins
Next Topic:programatically create a directory and move files
Current Time: Fri Jul 18 18:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.09815 seconds
