Eclipse 3.2 startup problem [message #165236] |
Fri, 11 August 2006 15:54 |
Originally posted by: schjen.nith.no
I'm unable to run Eclipse version 3.2. The task vanishes as the startup
progress bar completes. I've tried the JREs from version 1.4.2_09 and
1.5.0_06. I've had similar problems running Eclipse v3.1.
I suspect theres some issue running Eclipse on ADM Athlon 64 X2 (Dual Core)
in Win32. Can anyone confirm that this should be a working setup?
thanks,
Jens Schiefloe
my eclipse shortcut:
H:\Java\Eclipse_win32\eclipse.exe -clean -vm
h:\java\sdk\AppServer\jdk\jre\bin\javaw.exe
..metadata .log:
!SESSION 2006-08-11
15:15:16.609 -----------------------------------------------
eclipse.buildId=M20060629-1905
java.version=1.4.2_09
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-08-11 15:15:36.953
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-08-11 15:15:36.953
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.swt.browser.Browser.setText(Browser.java:1321)
!ENTRY org.eclipse.ui.workbench 4 0 2006-08-11 15:15:36.968
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
FUDForum. Page generated in 0.04182 seconds
