Home » Eclipse Projects » Equinox » Plugins - singletons or not?
Plugins - singletons or not? [message #15560] Wed, 26 March 2003 20:04 Go to next message
Plugins are curious beasts.
The recommended pattern for plugin creation is something like:
public class MyPlugin extends Plugin {
private static MyPlugin theplugin;
public MyPlugin(IPluginDescriptor descr){
super(descr);
theplugin = this;
public static MyPlugin getInstance(){
return theplugin;
Ugh.. doesn't that just seem so vulnerable? I look through various
examples, including the eclipse codebase and the above is what I see
folks doing, of course (some code uses a static 'getDefault()' instead
of 'getInstance()'). It all seems to depend on the fragile hope that no
one does the (perfectly legal by API standards) following thing:
MyPlugin myref = new MyPlugin(whatever);
because that would destroy the validity of the reference returned by
getInstance() (or getDefault()).
I'd like it if the javadocs for Plugin and AbstractUIPlugin at least
changed to recommend the constructor did a null check like so:
super(descr);
if(theplugin==null) then {
theplugin = this;
return theplugin;
Also, this should systematically be retrofit into the existing eclipse
codebase.
While this still wouldn't prevent others from instantiating your plugin,
it would enforce that getInstance() would continue to always return the
instance that the Platform originally created.
This is, imho, a significant vulnerability in the current plugin model
that can lead to unpredictable behavior and instability and even
potential security holes.
I'd love it if someone had thoughts on some ways to add stronger
enforcement of the singleton pattern in the API itself.
I suppose one solution is to use the Java Security Manager API to
disallow invocation of the constructor of each plugin other than by the
platform. I'm not sure exactly of all the ramifications of that might
be, though. Thoughts?
Mel
Re: Plugins - singletons or not? [message #15593 is a reply to message #15560] Thu, 27 March 2003 07:57 Go to previous messageGo to next message
"Mel Martinez" <melm@us.ibm.com> wrote in message
news:b5tii7$ofl$1@rogue.oti.com...
> super(descr);
> theplugin = this;
> return theplugin;
> super(descr);
> theplugin = this;
> return theplugin;
> codebase.
> Cheers,
> Mel
Have you considered making the constructor private and invoking it from the
getInstance() method. That way you retain total control over the
construction process since getInstance() can ensure that only one instance
is created.
Jonathan Gossage
Re: Plugins - singletons or not? [message #15625 is a reply to message #15593] Thu, 27 March 2003 10:40 Go to previous messageGo to next message
Jonathan,
What you propose is not possible since it's the runtime plugin that creates
the instance of the plugin.
PaScaL
"Jonathan Gossage" <jgossage@magma.ca> wrote in message
news:b5usbg$iim$1@rogue.oti.com...
> > super(descr);
> > theplugin = this;
> > return theplugin;
> > super(descr);
> > theplugin = this;
> > return theplugin;
> > codebase.
> > Cheers,
> > Mel
the
> is created.
> Regards
> Jonathan Gossage
Re: Plugins - singletons or not? [message #15745 is a reply to message #15625] Thu, 27 March 2003 14:40 Go to previous messageGo to next message
Originally posted by: kduffey.marketron.com
My understanding is that the runtime plugin that first requests another
plugin (via class variable assignment, typecast, etc), forces the JVM to
call upon the requesting plugin's classloader to find the class bytecode.
The classloader, through delegation eventually finds the classloader of the
plugin being requested, which would then create the class, store it in its
cache, and return the Class. So in actuality, the plugin is not really
creating the plugin it requests, it is assuming its already in its
classpath, and the classloader(s) are doing the work in finding and
instantiating the class. I don't think a plugin directly creates another
plugin does it? I do know of the extensionExecutable method (sorry, forget
the exact name), but the engine is still asking the plugins classloader to
create it then return it as far as I can tell. If I am wrong, please
enlighten me as to how this actually works.
Thanks.
"Pascal Rapicault" <pascal_rapicault@ca.ibm.com> wrote in message
news:b5v5sc$qu1$1@rogue.oti.com...
> Jonathan,
creates
> PaScaL
> > > super(descr);
> > > theplugin = this;
> > > return theplugin;
no
> > > super(descr);
> > > theplugin = this;
> > > return theplugin;
> > > codebase.
plugin,
the
the
> > > Cheers,
> > > Mel
> the
instance
> > is created.
> > Regards
> > Jonathan Gossage
Re: Plugins - singletons or not? [message #16422 is a reply to message #15745] Thu, 27 March 2003 14:58 Go to previous messageGo to next message
Kevin,
You should look at this webpage
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/equi nox-home/dynamic
Plugins/currentPluginModel.html
It says "When something happens causing the code within a plug-in to be
loaded, that particular plug-in is activated"
You can also take a look at:
PluginClassLoader:internalFindClassParentSelf(..., ..., ..., ... )
which calls activatePlugin(...)
Hope this help,
PaScaL
"Kevin" <kduffey@marketron.com> wrote in message
news:b5vjut$8rt$1@rogue.oti.com...
the
> Thanks.
> > Jonathan,
> creates
> > Regards,
> > PaScaL
> > > > super(descr);
> > > > theplugin = this;
> > > > return theplugin;
instead
that
> no
> > > > super(descr);
> > > > theplugin = this;
> > > > return theplugin;
eclipse
> > > > codebase.
> plugin,
> the
model
> the
might
> > > > Cheers,
> > > > Mel
from
> > the
> instance
> > > is created.
> > > Regards
> > > Jonathan Gossage
Re: Plugins - singletons or not? [message #16478 is a reply to message #15593] Thu, 27 March 2003 16:52 Go to previous messageGo to next message
> is created.
> Regards
> Jonathan Gossage
Unfortunately, that is not possible with the way the IPlugin API is
designed. For one thing, the abstract implementations, Plugin and
AbstractUIPlugin, have declared public constructor. Descendants are not
allowed to make an inherited member less public. The constructor is
public for the purpose of allowing the platform to invoke it. Also, the
platform uses the constructor to pass initialization arguments (the
PluginDescriptor) to the plugin instance that it creates.
The basic problem is that we have two different parties responsible for
the lifecycle of the plugin. The platform is responsible for creation,
while providing access to the plugin is left up to the plugin itself
with no clearly defined protocol. The abstract Plugin class' javadoc
suggests a static 'getInstance()' accessor, while implementations of
AbstractUIPlugin seem to use 'getDefault()'.
It would be preferable if one class was responsible for both creation
and access. For example, a simple factory like so would do the trick:
public class PluginFactory {
private static Map pluginMap = new Hashtable();
public static IPlugin getInstance(
Class pluginClass,
IPlugin plugin = (IPlugin)pluginMap.get(pluginClass);
if(plugin==null){
try{
Class[] ptype = {IPluginDescriptor.class};
Constructor const = pluginClass.getConstructor(ptype);
Object[] params = {descr};
plugin = (IPlugin)const.newInstance(params);
}catch(Exception e){
//handle exception
pluginMap.put(pluginClass,plugin);
return plugin;
The platform code concerned with initial creation of the plugin
(PluginDescriptor.internalDoPluginActivation() last I looked) would do
like so:
IPlugin theplugin = PluginFactory.getInstance(pluginClass,descr);
Given that, all other parties interested in getting a reference
org.example.MyPlugin would simply use:
MyPlugin myplugin;
myplugin = (MyPlugin)PluginFactory.getInstance(MyPlugin.class,null);
And of course, for convenience, one would expect that each plugin would
be recommended to define a static accessor like so:
public class MyPlugin extends Plugin{
return (MyPlugin)PluginFactory.getInstance(this.getClass(),null);
This seems like something that could be shoe-horned into the existing
codebase without breaking anything. It would then give us a starting
point to migrating folks to a more stable model for accessing plugins
without breaking the existing one. We would have a cohesive class
responsible for creation and access to all plugins and one could finally
start to rely on singleton-like behavior.
Some points to consider: In the 'dynamic' world, one would need to
flush the plugin class from the hashtable when it was unloaded.
Alternatively, one could use a WeakHashMap so it would go away when
there are no other references, but I'm not sure how well that would
work. I would prefer an explicit removal. Thus the PluginFactory here
needs to be a listener for plugin unload events.
Thoughts?
Mel
Re: Plugins - singletons or not? [message #16589 is a reply to message #15560] Fri, 28 March 2003 11:14 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
I agree that the singleton pattern is implemented weakly but disagree that
it is not specified strongly. The following is from
Plugin.Plugin(IPluginDescriptor).
* Instances of plug-in runtime classes are automatically created
* by the platform in the course of plug-in activation.
* <b>Clients must never explicitly instantiate a plug-in runtime class.</b>
As for the getInstance(), getDefault(), these are convenience methods that
various plugins have chosen to implement. The Eclipse runtime cannot prevent
or control this. In most cases I doubt that they are API (often the plugin
classes themselves are not API). The Eclipse API way of getting a
particular plugin instance is
Platform.getPlugin("<plugin id">);
We could have implemented an explicit singleton mechanism in the Plugin
hierarchy but in the end, we need to keep the plugin instances in the
registry anyway, and have API for accessing these instances so why
duplicate?
Anyway, I missed the problem that is being addressed here.
Jeff
> super(descr);
> theplugin = this;
> return theplugin;
> super(descr);
> theplugin = this;
> return theplugin;
> codebase.
> Cheers,
> Mel
Re: Plugins - singletons or not? [message #16638 is a reply to message #16589] Fri, 28 March 2003 13:06 Go to previous messageGo to next message
This assumes that all developers will read and heed this specification.
See, I personally missed that one. It just goes to show how developers
like me miss stuff in the docs, no matter how plainly written! :-) Even
so, that is distinctly not mentioned as the recommended form of access
as documented in the documentation in AbstractUIPlugin on how to create
and access plugins.
From AbstractUIPlugin:
* For easy access to your plug-in object, use the singleton pattern.
* Declare a
* static variable in your plug-in class for the singleton. Store the
* first
* (and only) instance of the plug-in class in the singleton when it is
* created.
* Then access the singleton when needed through a static
* <code>getDefault</code>
* method.
I suspect developers descending from AbstractUIPlugin often don't
realize they need to also look closely at the Plugin docs.
And even though the Platform.getPlugin("<plugin id>") access is
mentioned in the Plugin docs, the example in that same doc still
recommends using a static field set without null check by the
constructor to access the plugin. That would be fine, so long as you
ensure that the field is only set once.
Also, to nit-pick, the Platform.getPlugin() method is not strong API for
access to a singleton instance of a particular plugin class. Rather it
is a weak reference to an instance of whatever class is associated with
that string id in the registry by way of the descriptor. This may be a
descendant of Plugin, it may be an instance of Plugin itself as place
holder.
> duplicate?
The problem is that the Platform has one reference to an instance of
MyPlugin (which can be retrieved using Platform.getPlugin()) while other
code use a different reference maintained as a static field in the the
MyPlugin class. Again, that would be fine if the field was set only
once (such as declared final or with a null-check. But if some code
(accidentally through incompetence or intentially through malice) does
instantiate another MyPlugin instance then the Platform.getPlugin()
would point to one instance and the MyPlugin.getInstance()/getDefault()
methods would point to another instance.
In sum - it is possible for some code to be using a different instance
of the plugin other than the Platform's instance, without being aware
that such a switch has occurred. This seems like a potential security hole.
The still weak but simple way of addressing this is to improve the docs
to better reflect best practices to prevent this problem (such as simply
using a null check in the constructor before setting the static instance
field). Or they should simply recommend using the plugin id to get it
from the Platform.
To me, it seems that the problem stems from spreading responsibility for
the lifecycle and access of a plugin around. The plugin docs are
recommending each plugin pretend it is a Singleton and provide static
accessor. The PluginDescriptor is for some reason delegated the
responsibility of activation and actual instantiation of the Plugin -
that may make more sense to me later. And then we are given the
Platform.getPlugin() method as recommended external access to the plugin.
I would like to see things refactored so that plugin creation and access
to instances is managed by one party. I think this could be done
without breaking any existing code.
The comment about how the Plugin implementations are not always API (and
not even required) for a plugin is true. However if they ARE exposed as
API, then other code has access to the class. They should have a
reliable way of accessing the installed instance of that class.
I hope this doesn't come off as overly critical. I'm simply trying to
understand the eclipse platform and some of the design choices and make
recommendations when I can.
Mel
Re: Plugins - singletons or not? [message #17539 is a reply to message #16638] Mon, 31 March 2003 03:48 Go to previous messageGo to next message
Originally posted by: Peter.Kriens.aQute.se
I am a bit confused. If we have dynamic plugins, we have the problem
that they can go away. The patterns described to handle plugin creation
are therefore not applicable anymore, isnt it?
If plugins come and go, we need a service registry approach where the
plugins are registered and unregistered. Access to static fields and
getInstance()/getDefault() methods seem to be not sufficient?
Kind regards,
Peter Kriens
Mel Martinez wrote:
>> that
>> class.</b>
>> that
>> prevent
>> plugin
> and access plugins.
> * Declare a
> * first
> * created.
> * method.
> holder.
>> duplicate?
> hole.
> from the Platform.
> Cheers,
> Mel
Re: Plugins - singletons or not? [message #17605 is a reply to message #17539] Mon, 31 March 2003 09:58 Go to previous messageGo to next message
"pkriens" <Peter.Kriens@aQute.se> wrote in message
news:3E8800D9.4050203@aQute.se...
Right. In actual fact, the plugin registry already provides this function.
If plugin A is deactivated and reactivated you can safely reference the new
one via the registry. Same for uninstall, install, update, ...
For my money getDefault/getInstance should be
return Platform.getPlugin("my id");
Jeff
Re: Plugins - singletons or not? [message #17629 is a reply to message #17605] Mon, 31 March 2003 10:51 Go to previous messageGo to next message
I couldn't agree more with that last statement except that it doesn't go
far enough to address Peter's concern. To remove need for access to the
class one shouldn't even be using a static getInstance() method.
Instead, they should always be going directly to the
Platform.getPlugin("my id") modus, and probably Plugin implementation's
should not even be providing a getDefault()/getInstance() accessor.
Since this is not a strongly enforced convention, we may have problems
going forward with unnecessary coupling arising from this. I guess this
dependency is flagged broadly under the <requires> element.
Mel
Re: Plugins - singletons or not? [message #17680 is a reply to message #17629] Mon, 31 March 2003 14:12 Go to previous messageGo to next message
news:b69nv7$ie2$1@rogue.oti.com...
function.
new
Yes. I am a little unclear about the need to remove references to classes.
While this may be a good thing in general, clearly plugins are going to
reference classes from other plugins. Clearing up this one case does not
solve the problem. So what am I missing here? Are you proposing that all
cross plugin class references use some sort of service registry mechanism?
As a point of interest, how does that work for subclassing, implementing,
casting etc style relationships?
The <requires> elements tell you that if A requires B and B is shutdown,
replaced, ... A needs to do something. The straightforward approach is to
shutdown and restart all the dependents (or the whole platform) in these
situations.
In OSGi (at least some older versions) the old bundle (B) would stay around
until the framework was restarted or all dependent bundles were shutdown and
restarted. Is this still the state of the art in OSGi?
Jeff
Re: Plugins - singletons or not? [message #18453 is a reply to message #17680] Mon, 31 March 2003 15:47 Go to previous messageGo to next message
Plugin subclasses are a special case compared to other classes in the
plugin packages because they provide 1)based on the lifecycle, the
Plugin subclass provides a logical starting point of initialization for
the rest of the plugin and 2) a platform-defined API for accessing a
variety of plugin-specific services (for example access to
Plugin.getPluginPreferences() provides a very plugin-specific service)
without need for visibility of the particular plugin's classes.
In other words, (1) provides reason for subclassing the Plugin class and
2) shows that cross-plugin utilization can happen without specific class
visibility.
Once you go beyond that to utilizing discrete classes and interfaces
from within the plugin, then you become coupled. The acts of
subclassing (extending & implementing) and casting all are compile-time
relationships because they require visibility of the classes you are
subclassing or casting to. The distinction can thus be generalized to
say that if you depend on it at compile time, you will definitely be
bound by classloader visibility during run-time. If you can compile
without the class, you _may_ be decoupled during run-time, depending on
whether you maintain stateful reference to the other plugin's objects.
Thus, a best practice for a component provider is (as Olivier has
mentioned repeatedly) to put the public interfaces and abstractions in
one 'B' plugin (which would tend to not get unloaded) and put
implementations in separate 'C' plugin(s) that can be unloaded.
And a best practice for a component consumer 'A' is to 1) only compile
against the 'B' plugin's classes and 2) never retain stateful reference
to objects pulled from other plugins.
The difficulty is that in order to hide the classes in 'C' from 'A',
they can't be public or exported. So you can't have them directly
created by 'B' since to support that they would need to be public.
Thus a third best practice is that the implementing plugin 'C' should
only export (a) public factory(s) as it's only public api, keeping all
implementation classes internal. 'B' then uses the factory in 'C' to
create implementations of 'B's interfaces for use by other plugins such
as 'A'. Now, 'A' _is_allowed_ to use 'C's public factory to create the
objects, but since the classes are not exported, it would have no way to
use them unless it uses 'B's interfaces so it might as well rely on 'B's
factories to build the objects.
> situations.
Yeah, I think that the straightforward solution is that if A requires B,
and B exports any classes, the assumption must be that A requires class
visibility and must be shutdown as well. That supports the current
model. As an enhancement to the relationship, though, we could extend
the plugin.xml so that when A specifies that it <requires> B, it
optionally can specify that it listens for events which would allow it
to clean up. In that case we would try to unload B without shutting A
down as well.
This is a perfectly legitimate way to handle the problem (multiple
instances of the component), so long as this is clear from the start and
both the API model and developer conventions have this potential
scenario in mind. Otherwise, there obviously is the potential for all
kinds of problems such as resource contention.
Mel
Re: Plugins - singletons or not? [message #18480 is a reply to message #18453] Mon, 31 March 2003 16:31 Go to previous messageGo to next message
news:b6a99d$28t$1@rogue.oti.com...
classes.
not
all
mechanism?
implementing,
> visibility.
Agreed. Relating this back to the original topic, we should advise against
using MyPlugin.getDefault() and recommend Platform.getPlugin("myPlugin").
Generalizing this, one of the tips and tricks for writing dynamic plugins
should include "avoid references to classes from other plugins where
alternatives exist or can be designed in".
Do you have a common usecase for one plugin to reference another's generic
plugin services (e.g., preference store) and have no references to any
classes from the plugin.
right. This is the service model. It gives you finer granularity for
talking about changes. We can think of each plugin as one big service that
can change in various ways. See the registry delta discussion. It is still
possible to have finer granularity as complementary function.
to
> > situations.
> down as well.
The registry deltas allow for this information to be transmitted but
currently there is no way to say that A should not be shut down. Imagine
that as a result of being told of B's shutdown, A could respond with "shut
me down too" or "B? what B?". Default would be the former. Smarter
plugins could do the latter.
Jeff
Re: Plugins - singletons or not? [message #18522 is a reply to message #18480] Tue, 01 April 2003 01:45 Go to previous messageGo to next message
Jeff,
I would go as far as stating that in order to allow your plugin and any
dependents to be properly unloaded/reloaded, a developer MUST follow the
guidelines or own up to the problems that may occur when his/her plugin is
running along side plugins that do abide by the guidelines. I don't see any
reason why plugin developers can't follow the guidelines, what's the point
of developing a plugin for a framework and its engine if the plugin is a
renegade.
Assuming that the result of this project is an engine that can be used for
other UI based applications (outside of Eclipse), i'd say that each person
using the engine in their application should specify a best practices
guidelines for plugin developers.
"Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> wrote in message
news:b6abss$4c3$1@rogue.oti.com...
> classes.
to
> not
> all
> mechanism?
> implementing,
> > visibility.
against
that
still
shutdown,
is
> to
these
> > > situations.
> > down as well.
> Jeff
Re: Plugins - singletons or not? [message #18539 is a reply to message #17680] Tue, 01 April 2003 02:01 Go to previous messageGo to next message
In release 1 some frameworks refreshed "eagerly", restarting any
dependent bundles, other frameworks left the packages lying around and
resolved the problem lazy. In release 2 we mandate the lazy approach but
provide a special service, the PackageAdmin service that allows the
Management Agent to initiate a refresh (and expose the current status of
package sharing). The refresh can do a global refresh or for a set of
bundles.
The idea behind this is that a management agent can install several
bundles before it refreshes saving time and some error scenarios.
BTW, what stayed around were exported packages not the bundle.
Kind regards,
Peter Kriens
> Jeff
Re: Plugins - singletons or not? [message #18600 is a reply to message #18539] Tue, 01 April 2003 13:46 Go to previous messageGo to next message
Just to recap then.
"eager" = restart all dependents when a prereq changes
"lazy" = wait until an explicit framework restart/refresh to hook the new
packages into the global namespace.
Is this close? Assuming it is,
What happens during the refresh? Is this effectively a framework restart
where everything is shutdown and restarted? If not, how do the dependents
of some updated bundle know to drop their references to old classes and get
new ones?
Jeff
news:3E893936.8000104@aQute.se...
around
and
> bundles.
> Kind regards,
> Peter Kriens
> > Jeff
Re: Plugins - singletons or not? [message #19325 is a reply to message #18600] Tue, 01 April 2003 14:03 Go to previous messageGo to next message
Yes. your recap is correct.
A refresh is not a framework restart (though it might be implemented as
such for simple minded implementers). The parameter to the refresh is a
set of bundles. The implementation is supposed to calculate the closure
of all dependent bundles and restart those. So -at least- the affected
bundles should be stopped and started again (which effectively creates a
new ClassLoader for each). Good implementations minize the set of
affected bundles though this is not a trivial calculation.
Kind regards,
Peter Kriens
Jeff McAffer wrote:
> Just to recap then.
> new ones?
> Jeff
> around
> and
>>bundles.
>>Kind regards,
>>Peter Kriens
>>>Jeff
Re: Plugins - singletons or not? [message #19371 is a reply to message #19325] Tue, 01 April 2003 17:31 Go to previous message
Great. Thanks for the clarification. Makes sense.
Jeff
news:3E89E264.5040302@aQute.se...
> Kind regards,
> Peter Kriens
> Jeff McAffer wrote:
> > Just to recap then.
new
restart
dependents
get
> > new ones?
> > Jeff
> > around
shutdown
> > and
> >>bundles.
> >>Kind regards,
> >>Peter Kriens
> >>>Jeff
Previous Topic:Plugin (or Feature) Activation and User Profile
Next Topic:Repository content
Current Time: Thu Jul 17 06:32:39 EDT 2025
Powered by FUDForum. Page generated in 0.09401 seconds
