Home » Eclipse Projects » JFace » adding (horizontally growable) fieldeditor(s) inside a (horizontally growable) group in a preference
adding (horizontally growable) fieldeditor(s) inside a (horizontally growable) group in a preference [message #15541] |
Tue, 23 June 2009 04:33  |
--------------070904010009000603080000
I use GridLayout to place preference dialog elements in the following
way ...
1. Defining some global variables
GridLayout gridLayoutSingleColumn = new GridLayout(1, false);
GridData gridDataGrabXGrabY =
new GridData(GridData.FILL, GridData.FILL, true, true);
GridData gridDataGrabX =
new GridData(GridData.FILL, GridData.FILL, true, false);
2. Define global composite (to grab as much space as possible)
// global composite
Composite overAllComposite =
new Composite (getFieldEditorParent(), SWT.NONE);
overAllComposite.setLayout(gridLayoutSingleColumn);
overAllComposite.setLayoutData(gridDataGrabXGrabY);
3. Define the first group with fields extensible horizontally ...
that's ok.
// compiler
Group groupCompiler = new Group(overAllComposite, SWT.NONE);
groupCompiler.setText("Compiler Preferences");
groupCompiler.setLayout(gridLayoutSingleColumn);
groupCompiler.setLayoutData(gridDataGrabX);
addField(new
DirectoryFieldEditor(PreferenceConstants.P_COMPILEDCLASSES_P ATH,
"&Compiled Classes Directory:", groupCompiler));
4. Define second group with fields extensible horizontally ... at least
that's the plan. When I comment line X (see below) in/out I get the
following attached screens.
// cdo
Group groupCDO = new Group(overAllComposite, SWT.NONE);
groupCDO.setLayout(gridLayoutSingleColumn);
//groupCDO.setLayoutData(gridDataGrabX); ----> line X
groupCDO.setText("CDO Preferences");
addField(new
StringFieldEditor(PreferenceConstants.P_CDO_REPOSITORY_DB, "CDO
Repository &DB:", 50, groupCDO));
addField(new IntegerFieldEditor(PreferenceConstants.P_CDO_REPOSITORY_PORT ,
"CDO Repository &Port:", groupCDO));
Unfortunately no screen is correct. I would like to have the same
resizable textfield (with a label in the same row) as in the compiler
group preferences.
Any hint what is wrong? (BTW: This applies also for the 3rd group -
shown in the .gifs - not in the code).
Greetings,
Ralf
Content-Type: image/gif;
name="withOutGrabXCDOGroup.gif"
Content-Disposition: inline;
filename="withOutGrabXCDOGroup.gif"
R0lGODlhwANYAvcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAADAA1gCAAj/ AP1Rw0dNILWC
AxEeFEjQIMKGBx8qlOiQ4USLFRNmhLhQY0SMHz125EgxJEmQIy+KLJlyo8qT K1GynCmzZsyb
MHO+3Omyp0meP322DEp0qFGaOIEetalTKNKmRZ8qleqU6VSrVZNmhbpU68cp /8KKHUu2rNmz
aNOqXcu2rdu3cOPKnUu3rt27canh3cu3r9+/gAMLHky4sOHDiBMrXlzYD1jG kCNLnkwZsl6H
BDsezDyRM+aQm0En1Dy6s2jPEVGHJq269GfWp2PDnm2a9uvauG/rTi07N2/b v32vFu46+O7h
x4sjN858uXPl0FtL7518OvDn1olnr069efTu2MF//78+XnvsVI8rq1/Pvr17 s9P+HZwWkf78
+vjv66dmn39+//v1J+B/AwZI4IEGJgjgggUyiKCDCjYo4YMTRkjhhRZmCOGG FXKIoYcadiji
hyOGSOKJJqYI4oolsoiiiyq2KOOLDTr23o045qijYP7IR00VMFABA5BCEjlk kEcWiaSRTB7Z
JJBQOilllFROaSWQWxy5BRVYcgnDll1muaWYVIxZ5plmjlmFmmyWuaabbW6x 5pxy1knnnXZu
oeeae/7R5596+hnoFn4KSuihhSKqaKKJArLoFo76GSmkh05qCKWWUnqpo4b8 wamnW3R6qaih
/jGqqaWKauqqqrbK6quuxv8Kq6mGiForrbbmWkitnarCq6+1AmuIsL4W++uw yBqrbLLMLuss
srBAK62v0foaiyHRXmutKtlya0gs3oLb7bXgkqtKueemi+666rbL7ruwlBvv ufPGUm+8+Nqr
b76wVBOLvf4C/G+/A/tbDcECGxzLwQo3vPDDDkcM8cQSVzwxQejtqPHGHHd8 ll70qQCDyCSP
bHLJKJ+sssgwrNwyFSzD/HLMMSMpZMtNKqlzkjxXqWSVQF/5pZZDlll0llUY PebRXyqN5tNp
wgn1m3VKXfXVVOPJZ5176sk113/waejYXjP6qNlon/3opGxXeuilfsIdqqaQ okrq3Xbnfaqs
fM//2neru8J6qyGB84orrrvWmrgqiy9+bLDNRv7s5JJjO63l1F5ereXRdn4u tp/DEvro14pe
uruov5u6uvfK6zq9r+8rO7+z10777bbnHu9BNnrs++/Ar6cXQSPfrILxyLd8 vPJC7pxzz0tG
/7PQQVdvJdJDd6l902E2TWbUaWYdp/hWi691nnh2DWgVZMvZvtppxw8/pZK6 XX/cbnNKt/78
p+o/3ntLld8G+DcCsmpwCMzV4XiFLMIR63ENrBzlJihBZm3ugpfTFue+ZbnS fStcIByXuj6o
uhKuroStg50K9QU73PULXwcTmAwRRjCGLQwWbknPWqbgrxweDGM6DJ4Q/4dI xMDE5yAo+0Mq
nKEKVfyBFFWoQsqm6DIqUjFINJvZy1qGpC3urHnQc570qEfGoGHvjERLGtKc 9j3vQe2N4Cvf
+OYox63Z0Wt3JJTYysbHQQ1KfoCc3/0U1Tb8GXJu+OtfAAH4PwMW8JGOLFzh ErhAxQXLcZDL
ZAQpyMkKbs5YGMxc5jq3wWyBznOnSyXo2GW6E7pyXSlkoSzrJZ8O2WhFjomX jzzkmHPxLohF
DKYwh+mWHhHESKqgRj6YCAgnOvEPYYzmk2AgljJa04xp5J42weQ9N8YxfHTE 2hzPR848qc99
63ufOgU5v0k1yn70i6fcMqVITYGKkfh0pD4hyf83Shrun5R8oCYFuskKdrKT ocScQjXI0A6G
8IPjIiEJX0lRE8Yulq1z4b4CRkOOerRgIG1YDSkWC/k4JWMFQYFKV7rSg6Cn h1ERyEtj4VJg
EvOmOL2pXpA4si04Ix8HUQUp/kDUsEnRZGSposmwGBaZYVGLNusiz8D4vKpK aXrWsx72orTG
rnZTjd38JhzhSD5xyhFO6ftaHsEmtj368VF/ZGcg3znIQiLyrpuam/7yuUi9 7fOv/DSVJBUI
UMIBlHGXHOixDmpQT0YuoZAtJelWSVnTVbaimIXXRTfbwtrtsj8R8c8tqcHS 0tInlyX1j0pD
u1pqoPa0Ns2pbGcLvMv/UKN4qSBINZjoKaKyL4rLCwuQhDtGJoVFmtdMbpXQ uD1uOpeN3iQr
+MpKXTaV83znZB+gDoXOt85VrvGkazztOs/96fW8ee3Up/rKXsC6t5+x8mcC G1gIgtq3sYxF
qOYyKC1T+heiABaXRMs1UYtm1l0Y5azuAAZDGIJ0hgar4Uh3OR2UklY1KAAi TDPT2tZS46Ww
ACJtR0xi3x2RGiRzRjOY+EyicolLJQuLyGR83H+MbCw3ljE1xTLjf6jAxlQY S4/F0jwcB7ma
QhqLVbGq3Os5GUtMA+vSpszGsX6zumc1qznViscu69G7feQueL+bNnfCM1OH lFt66cbXRu7t
/71wBpyoJknYBDZuoJgsaH7xezlQ7leUCiWlB1Vp2UJPtpUGTjTrFJzR1NoS LPxBQYAk7dop
6BI/LL1PL2la6RJ7+tM46tFBiOSMalCDYS+sRrpggaSm7vjINf7HcP9x5CEd twqxFu6tYz1r
XNsYSru2cVie21zoinW64cQy+pZ9XS93V7vdFbPZ4kpmQq7tzPDMKz3Re89u s9fNcQ53q+Rb
Z8Pe6r6KNRbk9szuQP+Zg6bcVrfmHeDPEVjR+H5lgleoUX59FMIh7SjFRgpT q6DUHxm+SMJn
Kh+OrBYiMxUxqCdO8cmADMUjc8YxWmxUGMtsyMf9sY1BTmNai3wstf+GWVlq 7etXH6ksvj4u
k5mc1Sdnz2hglTLOjW3lqSE7y8rGLpezGyi3SpuP1U66teua7bc5nX96c7PU A0t1vxXugHMu
N+J4dedh5fmB7d5zZAEdWVIamtCHJt2BE73vWW42X7sMLWg7fRBK64fSqI07 aVsaEdT+suKA
Dzxihnfb45U61S9ElyqCS+sl3XrHxv3145Pc+JZHibi6/rWtNQ/sakL589v0 0nPbeGygJ3uc
zE59dgUFbe62nmxKr7ZdyZs/9Jo3vVFvc9V37zdyVzJX9EW3nvkcdgu+e3Ma FHQHHUpvAb+r
wGuvaNsT7MIYJl7gALfhwSgcHBHXnTMc1nD/ajlMaQ+DWOKCT7/6+3Jikqki FaTIwx9eLMWP
I9XHJwv5jlEWcv33mGXH9VQBGGtg5GpUBXnFlYA1t4DZ04DMtXOkV2Wld2Wn Z3po5Wxr1VZg
toFj1oHiJV5ohldPZ3u651e8d4KsMli/93tdJ3xgR3ww+EnH11+ltHyig0qX lUrtgmjRB0uM
Fju15Fqp4AdDmAr9cUvTQGkCgneWllp1p4R7B1u+1GnrV4VWOBfG9CNBQgXU 4AxQ1HFEsjyU
pzMyt3liYXk7Vk3ENWtqKGsIqGRpmGtuSGxh1XPgZIFa1mzNtnrpFGbrFHvw BILYdkjbtmaf
sl5TZ4LiJm6+V1iH/+OCEPSCxadfZMdf1oIsg/ZQzmdvnJhvnohgP9hZ/fZv 2FeKEUNwE2NS
H0aErLhLB1damfZhPOSESDFTNXWFuJiLa7FTGCcyf+AMozB/9Xc8VqRUJfNU yOhUyhhVOBNV
YvSMVkJzTbZVaQSBX8VzE2hlQXd6aZWBXhY2RceB0+aB4DV7TZdmt5eI34aC 7JiCWbeCXHdY
LRiJMFh8MliJ+FiDZ5eD/MiDn8h2oeh2uPNZZSFakLYfcldplzZ3+/FaVKiL EBmR8vEPAlE8
L9NEzuAlMJM80LhkyMWAICklzBV6xRaBx0Y1aLKNdZR6QmdHrNc+r4d05Gg2 ZsZ0NnlXjv9S
TzpZKohYgu24e4ODdfD4OPVFj+lWj0jpZ/mIfDQ4aMxXbxF1bz2YWdP3drZj fVj5YAKnfRPG
ikXolV4JFmD5lWQ5i/8wlmh5frIokWyZi+1njHBZjHK5VMqYRclYM1+UgB0Z PSGpVTbnVTpn
ktGVjXlYgeLkjUT3ZUcnjjNZjtc2SGrmdIlEgrlXmW/2k4Clgo5YWPOYWAW1 bknZWPfobkvZ
lDaYdming/94QlXZWVPwmrAZm7I5m7QZm/FSm7U5hb3TlrypfqKmhXsZnNAT JdLYl8l1RqKX
nN1DZYSpkoWph6qnVi+5XbB3dIA4SIJ4k9o2grh3iOoIbpgJlFr/x5mGA4mg KYmhSYmkuVDL
J29QWW/mEp9T6YmtuWD+ppWkGGEfJVIW058k5Z8AejFr2ZsEGngXN5cI6jLK ozJ3CVXLCEbN
KJxWRZxNhk2fZ42ByTTMaYdWk5KGWV3diIHfaHR/2JiyN4jyJJm2BwiW+Z3h uU9XR1h0xoLx
6HWeeV+TyGdjt54YZHao2Y9qt5ooFJDUZ59G2m9HKjt/V6BMOnGENxzg131S CqVTWhpRSqVY
aqVVeqVamqVc+qVbGqZeKqZdWqZgOqZoaqZkeqZqmqZs+qZrGqduKqdtWqdw Oqd4aqd0eqd6
mqd8+qd7Gqh+yhsZ06SGWmInxjGp8Fk0/9KoMeKoMBKpM/KolCqpkDqpllqp mLqpl9qpmuqp
mRqqnPqppCqqL7Kbh5qqOZWFHOMHu4QVMeUVXcEVVBGrtAqrs3oVslqruboV unqru4qrvDqs
wlqswXqswJqsv7qsvtqstsqsz+qsvRqtUVGoqnqtxMSLihqEoYWQ/5GQ3bog 4NqtDCmu33qu
3pqu5qqu5dqu4bqu8Oqu4Sqv5Pqu9Dqu+Iqu8Wqv/Dqv/Vqv/hqwADuw+cqu /1qw+yqwCHuv
+sqwBquwDXuwEQuxD0uwE2uxFZuQqIqtHDtEttWqDSce2+EdIxse5FGy5cEd JyuyLLuyLmse
L6uyMDuzMluzJP/bsjR7szGrszlrsj2bsjxrsz4rtEAbHtbasUgLPIm6MYsK qqNqqqX6tFLr
tFQbtVULtVg7tVa7tVl7tVrbtVz7tTUSW0lbtjrymyCLrNA6rWxLrGorrW6r rHBrrHJLrW1L
t2sbt3mLt3P7tnart31bt3frt4MruFJxtGabuDpycduKsQnruA77uAsrsRl7 sZNLsZJruZpb
uZybuZ0buaBLuZ47uqGLuaULuaJ7upeLuqabuq7burDLun1Htopbu+pBeGaR lrpLlrvbu0Oo
Fq7ap8ILqINavMMrqMdrvMSbvMy7vM6LvM+rvNA7vdJbvc1LvddrvdGrpohr u96rHkv/Sxbo
gZvkW77mqxdp0bRh67Xsu77uC7bwK7btG7/zK7/va7/0e7/1C6ob+73+Kxms WhZ+4KqKgb5o
EbyFu7eEC7h/y7cNvMAOnMCBq8CGG8EMLMEPXMEQvMEa3MEU/MET7BDd+78k XMA+YhbWWowo
0BcGfBZNq7qbS7qvK7urW8MxDMOfO8M2nMOxu8My3MM3rMNBDMQ8TMNDbMRF 7MM4/MP12r8l
/MSG8bECTMA2diQW2TIrzBctnLshu7NDG7Rg/MViXLRkjLJmjLNEe8ZeXMZo HMZsvMZq/LNx
nMZtPMZz7MZ3bMd1nBAjDMV+bEQnXBYprFRZvBdbLMiMqr+K/5y/jIy/jry/ i/zIkQzJjUzJ
HZIK+4vJkhypTvzHntwXaDvFZxg9mlfIeHHIZBG8HhzCGbx3kmbBsMzBINzK rIzBtnzBuBzL
q0zLvHzLEewjuzwUqhjMetvHn3zMdsG4gpweKTNyMGDKd4HKY6G+6AqLEcF3 T1h+pZXN2OzK
3Xyvq7XE4izESXzESkzOTHzORJzO5tzO5fzO7AzP5cqL6uy49OzO7NzJyLzP coG7osxjSXZy
KgDNyQy8XdylHtZhD5fNe5caq9VaUapS5LemC6292Lu9GH3RGm3RHJ29Hp3R HQ3SHy2oYjHP
Hh0RixoWIy29xszPLt0W4TvNzOxj+P/nzARdF9IsFtQsIeEchaTV0D+tUkko afbx0CjQIK01
1A2t0CtFH7G4zUt91N5M1EZN1N48H1A91B62yVxtyV49yWBdyWGNvzs1kWX9 qU0rFpcxkZoM
qVWAB1NABXFNBVSAApiMS7T70nqNFgGcylQ8XC93JDdNFzkdFghME6slECql 2EAtaYud2ANh
1DIh0Snl2Jm22JGtzZl9zRlWWgj3ynv32Sig2KMN2ZbdEEaN2r4sy7Wcy6zd y65NzLo8y6st
27LaI2GB2xSp1j0BljBR2CpdE2C5FFXgB1Rg3H5g17va0nvd3GShrcvMY9SE VCYz2HMB3C/c
r9Zcdwwd1az/ZdnY7NR2Z9TfzdmRptni3dBFPd6Wbd5bDdRRbXfjvM7zjcTx fN/1Xc/6jc/5
zd/oHLlpfdZmra+tmMgfZtYIfs/jWuD/+tZ0rdyoq8/OPeEqTZGoPMBqiGs3 xkXW3c8GPR6p
fc3dTd4LQeKfAYsEgdnc3FL4kNiwWNqSRn7bnNDtHRovzs1vLMd7nMc5Tsdw vONA/uNCruND
7uM6nuAJjh0EfBsHgeQKrhsEvB3FDeHmwdwU3twxrdM6RN0i98wsrBY7TSDh 3NNWXeZH3dNR
jdRQ+IT3IdT5odBvLt9oft6qdeZWzeYQwnddPdZfLdZ+vud/3udfm1sFgcmG /mEr/2Lg/XHo
qYDJnJHoH1IFd90iEn7lzR3Kfj3KYtThefHhTWHao/3TjE3an60Qkv0TrWUR qR7aIt7imq3a
C13qDAHjCPHYoF3jjM3etr3rtB3bvT7brQ3ssC3stT3LnxHsHnHsw662Vm7p L63M4svMhPzl
6at3DOlhS/2uTM13Sd2tbv7doAXV6j3VdP7d3M7eOL7inI3t+P3f7k7f727f /S3P8b7f9A7v
+O64dy3vovuu7Q7Ele7sz/4PBJG7VDx4nr7RK73wIt3wCu/wIf3wEh/xFM/w E2/xFb+8oQXx
x9vsAr/PWR4WHk/taBHmfH7ygY7ygL7ygt7yKu/yKR/zLP/fkHn98fzc12Ph B8hOqx9e7Dv/
66/t88vO6z9f9EMP9ER/9EYv9Ezv60s/oDZP4dCtMdmd7/b+7/xu9f6t9fee 9V5/9fOO9WBf
71v/9WU/9ly/rwEf9ccsxRqjykFO5HJv5HSPx3Ff93pc5Hav93k/93vv932P 9z3+94LP44Z/
HjXP9p8c8jhi8jIP8zP/+C8/+ZJf+ZF/+ZCf+Sqy9or/x5i+I3D/9MTu9Epf +k0/+qgf9KR/
+qqf+knP+q+/+hIx8p3/xNC+I9Tc9Whv9rp/9r7f+8Av9r8v/MEf9sZP9sWP /MLP+bVv+wQP
3OwB9xl/8Rxf/dR//dOf/Ri//db/r/3dz/3YD/5USvvN/7+MfyOOj/mUr/6W r/ntv/7uz/7y
H//8m/jlX8I4ryOH7fpI3/+i3/oAQQ0fNX/UDBYcWPCgQIIGGyZ0iLDhQogU Jz68KFEhxo0a
IzLsCPJjRY4jM4q0GJKkx5QmVZ5cibJkS5ozbbK8KRPnTp09Y/6EGfTlUJdF a/IEujHVlH9N
nT6FGlXqVKpVrV7FmlXrVq5dvX4FG1bs2K7U/hkkm/Zqqn+p/LiF+1ZuXLpz 7dbFe1dvXr57
/fYF/FdwYMKDDRdGfFhxYsaLHTeG/FhyZMqTLVfGfFkz42nU/DBVG1r0aNKl TZ9Gnbqp2YKq
0/pxHVv2/2zatW3fxp1b927dA5fyBh5c+HDiTqedNZuVL1UUzVGkZeuws8Hp 1Kpfl56dunbr
3LFvB989/Hfx5cmf955+vHrz7NGvh98+/nv59enfd59/vn77/PHvB7C/AP8T sEACD/QvwQEV
NJBB8j4rLkIJJ6QwNH+Q0wq2qDSM6jnRYPNJKKNySmpEpEQ8KkSiUiyRRRRJ fPHEFWGcUUYT
VbyxRRpzjBFHF2v0cccfeQRSRxuHRFJIJY/E6LcKn4QySilX+6czrdhqysO2 pNLyKeey/BLM
qqJzqLwyqzuzTO7SVNPMNd8Mj0010YTTzTjrpPNOPe3kM88+2/yzTT8HBZRQ Qf8LRfRQRedM
lNFF5YQUz0Yj3dNQRy+lNFBMJX2U000rndTTTC0dNVQIp0Q1VVVzM2ugDJ3S kkMvO4T1Hy2f
63IqEAcyiFeGenXIV2GDJRZYY39FdthjlU222GaXdZZZaaOlFlprn8V22mu1 zbbabrf1lltx
wyUXXHO/RXfcc9VNt9x213WXXXnjpRdeeJ1cNV999x3tOLSUs9W559giuNaA cRXY1lrDnIrM
BheE+GGJEYyY4okdxLjijC/WuGOOP7Y45I1F9phkkEdGuWTuTuW3ZZdfzupC V7PiMFYuZ831
VoWtAjFJJn8OEmgjgyZ6aKN7PLpIpJdWumkin/a5aKb/oV5SaqejTppqoafG +kV8YQY7bJjN
+hcrLHfe8uYs0cZ14bXOIlVUuUHtlO5PNS21brzn3tvuvO+O22++A++7cMIP D1VwxQ1PnHG9
EX+8ccgBlxxRlsXGPHNVWUsOK1md+tzLMEc3uLmqdv3o2I18XT11ZFtfSHVn m5O99tedhf0i
1nHn3fbdfXf999uBj31444VHPnjli0+e+eV1fz536Xs/Pnrqm4feee2z5356 4ru/3vrvva9+
e/KxP1/86r/WvH33J/S387X2is3h8wR2iHbraO/Mufzxpw4A7YMClQ1IgCZD YMpOVsAFNjCB
DHygAxUYQQpO0IIQZNDl3rdB/w7y5kJloxDqhkJAgqBgIPrzB+1SeBATUoOE HCFhCpMSQ6sR
KYYtvFrVsta1HG6thzXkodaAqEOuEfGHOzSiEJHoQyUWUSLs62AUpSgbs1ip K2eTjcP0hILp
kJCAX3RhGKsDxjxx0SBgNKP/XKg//00DjGv0YhvheEb95a+LdHyhwPpXx8n9 zY+Dq1zkBEm5
Qf5xcX0EZCETSUhGGtJxjVykIxEpOA1O0ZKXJE2r5Dch1FmrhS48YRjRiKwv 4o9XnzQh7fBB
wlWC8oynXCUBWymQL8KSlWEMJSxfGaxavpKVt7TXu4Q5r2ASc5j1OmYxkWlM Zi7TmcqEZjKl
2cxoUv+zXVDEZDa1CZb4eQWL9UPOANUYRhf2j5zdeaN5AGhGODbHjQHEHzsF xkUSvpOd7Xyh
G8epx3qW0jkVxGBAJShQgA7UoAVF6AUPqtCEMrCS24RoRK8is01KqGc3aWEe aVkQMEKkoxnB
4RkRgoKO4JCGq1QISUFyQ5TmTychdeFIV1jClgbRpkm8KRNzOkSd4tSnPQUq T4W6xKE6sagz
wqZElbpUKoHwSrWJjqHyaM4yedGO5wTPC/fn0q1O9YzkfOdX5QnWcxLwjtLR 6Fj7qchDBhKS
bWXrIyXp1rnGdZJyjWRe4fpWvO61rnztzEOZOliIcg5KncyeSsV6kTyqMoz/ sFMsLReixsj6
b6YnZOMpOcpG/WmWWOt0zmZfmD7zha+04zMt+FC72vKptrWkdS36Ugtb2s7W tqyVLW7Vl9vX
3ra3uj0tQ5JKWOJespvKod9UTKc2tL2Noc8lqIPqCd2FRte61cVuQ7NLXe12 l7vfDY9gizve
KH6wolQJ3T/SKybmbkWETTyiUYk6tHEGdb7yxW989Qtf/u70vvv1b377+9Oj DvhEwyVvgt1X
xfM2zGBpoxXbTPeltjn3rxfWa181fFcO0zXDHbarh/36YRFvuMQgBuyJVRxi Fm9KvAqGMeY0
+aq1NWW9HsLxrNaWK12dxZo/fuY0gwzkag7ZyEVG/7KQk0xkJTeZyU8+spOj DOV7gSbGV27f
cc12MNMVDIs5bq7OFMbjp9gPvNu9rnfTfGY1o9nNbYYzm+W8Zjp7xspYxnPY KEpjtKV3nhWu
8c4ALZWL2lfAAQYwgf9r4AIjmtGLdnSkFX3oSSfa0JYeIoLzvOnNYQhggf5m oMesY7ZZJaor
TnGLMTxiVptY1SR+datRvGpXp9rWtJ41rG+t6zS9mNO/lpJhaUbo9uJ4uRN+ cI9/u2zeNnu3
zw6us6MN7dhSu7bArfa0tZ1tbl+b2db2rbS7HW5wY9vb4j73szUNbHZTSMvz wws45/zmece5
zvam973rvW999zvfbvZ1u/8FXhzzHtbHlL70oxHe6EorHNOQbrikEy5xhk88 4he3+IHvPHCO
T4jB3oRqOGWNalyTnNcnH3msa11ylec65bt+OcthvnKUuyngHcc5q/4xswoh lspSXvKUhR50
ogPd6D9H+tCPrvSkF73pSy/yunM+9dq8+6m0MbO/8b11fv+b61rv+te9Hnay O3TjVEc7bvb8
pEJX3O0Qz/jbFw53uT987ne3e94dvneK011HUk974E9DtgabOuQ0j3nNXY54 xi/e8SZPfOQb
D/nJt5zyjw/xzQW/+dEIu+cH33a6SyvLct+uOegmd+hTP25zr170rP+26ls/ +9jDHvW0v33t
X7//e3IDnvO/J4vVx5RcLlGYYWAic1SyDrIDJiid78Ef9MU+/bKPHezXt372 qY99i2ke+N8H
S8GHvSHlQkXMpebZweM72iGSfkUqrelM4I93vmO87vWPu9/p3/f921//eg8w 3wO/AdyKj/s0
tAm15hK1QVNA5RM5TdGLrzKTf5ojd2qnxYIjc8qntAqrNqIsNiKnD6wjDxzB OsqME9yMFETB
FVTBFmTBF3TBGITBGZRBv6gSD/M+AtTBq5ix8euz9lpABUw+0AE9dAk1ySIl l5IlqyK9UUqr
T0LCVsosX+qVX1qjXQIlK4TCtEqWHfTCX2OLZhLALyRD4/C0LZunLSkY/1EL wpwxvASBje+4
J3PSwDOqw8XyJ9rJJzwyq36Kpy7iJ3jyH3kKqz0axOnivurbPu1TxEZMxEf8 mJ7pvrMrw0qk
irXznAfzswjbMfNLv6dhC5aYP45qiDdSqXRyQoxgv/iToRKiCMUaRZaaCPgj KRoioJBoDgD0
v/7LP168P/7TxV4Mxl9UkjAsojG0RC8kvKtDwPIjtfMbQqc4Nb25qOzQqrIS IyZEJ1HCRrOq
qqy6Km7cKrE6q3LiQK7CKkScOcxbx8tzR8uDx3aMR5mjR8VTsWpEnBxMRmX8 h9bwwadYLy4T
SNGJRiJcNjKBLP+JpVNEwjxcrIUkRdYBpspSof9boixfUcgbwqMSOr05wr3S y72QBMmRlD3d
c72T/MiSFEmVJEnba8nWCcXeo8R9pEnho4rlcI3lQ484VKA9hMRFBEpHZMSf FMqgJEqHQo5J
pMmlhArx+zyiicmbcj/8I0ZhpMr/u0pfxEpgzMph3MpdfAmElBpkZMrvM0Cu SMDU0CIITMp3
lMe3rEfJY8e4rDy4tMd5vMt1bJkp8IwbVCR9LEuz3LnCGw6f8xYyebrEZLrF dDrGhLrHVMzG
lEzIdExpQY7IhDo/8ANqMEZlIsvA5DybfBusCyf84MmjHEp6q0EaZM3VdM3W hM3XlM1pFA+/
TM2QWYq+9BjABE3Ow8T/EAonG4nJr7RKrgyipfiM5JwC5WTO5XTO5oTO55TO 6KTO6bTO6sTO
69TO7OTO7fTO7gTP7xTP8CTP8TTP8oROslGJfuxKh9NMzhzMHPrM3gy8Zbyi wyOcapRLt6TL
xeNN+owxwjOTtsTLyMtNfKyc/wRQtPM84DxI5OC9lHRJlqRQ15rPBSUvAWWd y3xJlPyt94zK
b7tQDMU50ZQKnDS/hIGO0syP07zNonwuBSXR4iKb77BNozSQAyVQiZHRGeU4 p7yK9NrE0Xiv
FAnRoLrFokjSmEhS4wTLj/C9gowSKSUNKm1A3LBSsFFPlGDPGVJIrYwREIXQ sZxJHwW+sxzN
/2bkRFg5tmO7UqhYS0uRxOaLnOcDlGu8QJ+0NT2SQLvR07+qJBV9MEFVjSy9 ipw5vkFNtqxA
VCAktUdlQ2e0iluh1Kog1NQwVB58QOrY1DIqx7rMGx1FpB4103brwUwMND8j HUV1U/QqQm4h
kxeyJlmdnc9KwqLTqGCi1SRjnyGExtjIVEuFVE4MVkhdLk8UCypVVjZlVuZY 1NMoVqrQ0GDh
UE+yJVe6SFyKoyXsSCQTUzEs01LdPBN1wDT0skXtEp05vxNl0f2IQ3XUpzTS Q3kFwT60wAvs
IuywV3nirH0FxOnyRnMU2DkyRI+kLHEMwZ28MzITs3RFPjYFNIRBGP+IRT5j s9gUtVhKPdYG
HJ0JQzZBVdFVFTSIldiA2bFVNb62udiDedhRG1mVRb8gZNmHVVePpdiB7Nho PQu40Y4b9Q7Q
skM7tKqBpUMxGhkd3c1wFdfA+830S1UgdNhOjFSADE4cCUWYwiVubEUwIsVR CqUkbdJRfCyG
4NqNcqmvLYklrcUrrKla9KhShNuO1ChWFImvYdjSwRm3YdUai9hSW9ebUVd0 bVWX9Vu9JdxA
A7PAfdnCjVqT9cRfPdYcg9l1dVjFRdyRJdy+/Vuv2FKKYM+jMKmYMtuYSqUV qkWwxR/9+tZj
VNqlZdAzTFMtSUA33NuplUaepcaz0CqqEkf/bcRDfMLGAGqTbS2l/0GneMJT rfqisAJe5UXH
dBrYTLmcggQzqT1cxZXchLHcjSXZwrVdiUW2y91ex71czHVZyWXcX+1eyNWx xLXeNjRc781e
CjNc7i2LdkULupmqXLUnUWJePYQ8pAUkUnXdTWtQp4UKVc3ZlrVSxCKf6Iis UOpakULYVNyI
XEXCCx7bJoTFsgWWXERH052ly6LgPuXClBph6rHbSYXf98Xe9/XeZhXf+i0/ 2o3hvmWvjA3f
8+3E7cXhG45f913cR9XcZ8RcBrRc9uLccNpQ4oHFEbbC4I1brkIlFBYfMU23 ES3gTSNXOCU+
tcTfnbzBgO3GcSQj/25ERaMl4z1MY+HdRgwuRDXuqnwV2u3wxjs+p6Itp/TQ IB5rWLx1Yb1F
X+tlwDCj4c0l5JgtYpmt3sw9YkeuXEVN5EAWwmf9Y0rmYUiOX9vFihrt2ftY pzHiHzmO1391
40KEV+8QYKXcYuADUk5SvxuJytQNrcdiwoO9xVpeyCXlSABOoUPc1oSo5fq6 QJqiSNTlVjwK
pcmaRZ6AopDFmeNjmJytsMQdXGObWYLEYUIF2cjF5m1O2bwtHfpd3MCd5kEL 2ZV1Qxv2Y2n2
5ox95Jlt2JIFiy2tiC4FU0sT067R4lbGMjRlxix6QDnd0b/507zsz0Da3UbR R53loORz6P/b
iMaIjhABPZNO5U9YE1UcbF1/5rhTdVB2QUxk2lXKnEwig0JY7ehhjahEZWkK meiwmdZeqVaT
zszN7Mxj6mePhrEudjDShEOfRU0cTSAC5mkp8mTwEOoXHZBVzqCVPmpga1qL qtoSGc58bk8n
Fc4n1eqq9Gri/GqsTpGzWE+vxLvVlU+ojmpOs0+0xM/G0U9QRei5Xpy1xrM1 KWi67isBbiuj
tmviOmBg7QoHVuExldAINcnD9tCVnNDGRmzGfuwOVezJTuzK3tDYxGwslsm/ pjqflsYvTra7
deugJmoYHWrTZurULu3TBo8pcO3Xhu3Ylu3Zpu3atu3btm3djET/tebsK3vl 0yG2NRVt94pl
I/1crkbu4kzusDbr5s7q5Qbr6BbrSRPLo9np3mYqgB6TB5vd9nXTS3UwRprN 8c7s8ibv8zbv
9Ebv9Vbv9mZvxbDNP/Jr7FYqkEZgm+mQNDTnZyU/YaLv/7ZEcAXwgfPspmAL c1XD0OYymOXk
20Xt1VbtB5dw1o5wCodwsZvvAdemqXbVpxXuSkbkBK7q6VbuEmfu5zZx6Xbu rlZxFD9xFr+I
69ZwbWrr2L3dD9/vBjdw3LXL/SxQufbxHgfyIZ9LvS7yIE/oH3+8DJ/xSwrs DhfxD5fngfxE
yF5sybZsLLdyyt7yLK/QyP7yKw9zLtfy/zIfcy+HHhlvcuOCXVMDba4wVJ2c 8Aqn8wufczu3
8DvX8wBh8jWXot+WDUMtUugm8Rcn9BU/dBdvcRhH9BQv9PtScz9H6hsEOaBO ciE/ciLPaCQ3
8k3XdCX39EwX9VA3Fd6W9PoeTIOzacxk9cp09ZN+9VWP9VaH9VqXdVtXzEg/ dQ4qcDg9vDwf
j1EG9jrfc2Ifdjw39mR/EFPfdYji8OJouyVC3o5MKWr/HxCuialkdEV/9G5v dEN39G9f9ESX
NF1v9gVr8wMUaBO7RgyGY2wklGscdVCnd0wn9Xq/9HzvdHzfd3vv83NvnyeH 9iJ84LvI4BDu
JRb64CnOZbnt1/+HHGY1+uWMKsEkde+Lf2+Mv/iaBnPHFnOPJ/Mz73JnM3eA z5xeR1GCPNSt
kPP1CJ2gtWPxoKesGiMlTKM3ft41Kto0DlhCVEeTH+ylRvahL/aC+negFxtA 7zHyc9Smd1Wo
PG6Z+oiwbcWUkgiBIUXRAmA+LNt5ytqy3eXT9XZuF/exd7SrLvu0J/u157+S R3otpfQDlF1n
7GZ6tt8yG2iGLmh13ECsYl6jNWE1weNv7FPehV51vMJ5t3d+5/TGL5y4Vnx9 d/zI7/dIOfq3
H5tU90H8jrAkFvRXPcyazqWcD/yFx8icb0KyleKPSqdZcv2sxfVZl/3Yp31p Gunap/X/W9f9
3BdwzC8ulF/wBP8y8aXcaGz59nDR65h2RFSjmo95U85jCux5EJRAEdyfe1X2 otd+lUn+7c/+
Y6euy/f9lnn24P5BtYHGH376IUF7tif39w9394//qDlScLf/cZ9/5Hb78eeX Gjc8UAOIfwIH
CkRRcKBBhP8SLiTocGCqf9SmUatoceJFi34kZqSYEeNHjx0/ghwZkqTIiykt rqzYsqRKlDJP
0jRpM2ZNnDdZztzpsqfOoDxzDvUJs6jQnzU3KjX68ilQpFKbJj1KdarVrFCJ Xu2qNarXrU7B
YvQz5SHatGrXsm3r9i3cuHLn0q1r9y7evHrTUvvnr+/bjQ8F/ztEYbjhQcMM Dy9kiJYpPot/
K0auOJlaRMsWK1O7zNmz5M2hKY+m9lm0ZtKpTZc+rbozativQa92zbp269y4 d8u+3ds2cN2/
hdMezrs48tjJZytv/jqz7+XRnU9nbr069uDHqWs37l16d/DEuY+/Hl50qrN7 17Nv7/49/Pjy
57edxhFuKj/59+unD5FjSSIJSM1GAzZlYIBFIbiggg0e6GCCD0oYIYUMTmhh hRBiuKGGHV7o
YYYfihgiiRQVCCKHI6ZYIootqugiiy/KGCONK5rlH4456rgjjz3i6M99Ps4F WW9/RXbZXxEh
ydqSR4bmpGZQwialkUUy+aSVVF4ZZf+WXTbpJZZfihkmmVyOaWaZU4KJJptq nulmmlW+KWec
W8KJppJ20tnmnnf62SegegqqJaFr/jmooYEWOieijC5aZ6HpCTkppZVaeml8 fVFEV0Q8QoeV
SExNpBgK1JCakWIfnQpqVKWWypVVq5qa6liwilXVrazaSlauYfH6667B1pqR qLgCO6yxwiaL
rK7M+qpss8tKK9WNmFp7LbbZWttXZNo+JhFn4cYG3auslRrZuaaa61u55Yr7 2rvsxhbvuyhU
Zq+66PpG77z9wuvvvgDz+y/BARc8sMEJI7ywwA0f7HDC0DH8MMUKQzyxxRVj vPHFHWvsccYh
iyuptyWbfDL/ynfZVxGnPX7KYYGvilTuNK4KKLO6FJWqs2EVncpzuz272vOs r7qqrs8s4Xx0
0qau+DSMUM8odY1RWz311RmeiDXXVXdNNdhZh/212DBWmzLaaaudMpDdplys orApie9l6frj
qpyv/lXq3p3RjbdpKNxtmb2CW3R0330TnW65dzs5tGGTGf4on41CmqjllVN+ 6OZxO4p555lz
bmWemoN++uepX6666ayP7rrnq8veJslr23477pP2xfJcne6YWa8ESlQuRsSj UDOqMyvmEanH
t+t00j3rjDT1RzOP9PWHV/8VtM86y/33wYt/7LTelw++TqKO3z360bpv/vvt wz+///z1rz/W
2bnrvz//7fX1F9qItJ2KZMZwpOGbz/ChtwRqz1T38ozeXPVAnx3tedG7jeBe NcEL9u085ilP
dkDowRAOkITfIU8JR6hCEbKQgBxZYQpbeMIPxrCGMzSheGyYwxvCkIe5qV3/ gijEIbplZYBx
C3+SmBbFsOdlHTrRzhq4vaYVr4rIGxX0nCazpakril6k3vRu5hKjNfB4ZSMb Gr2mxrGt8Yxt
fNDW3ihHNtLRjXVM4x3nqBH1ELGPfuwjkHjnFsIQhJAPcUxeiMSo0p2KVHmL 3JUQqMC99UyB
qaKk0Qyjr1kFbnGRdNOp0KUYIxnwdbMzZetOGbtUshKVrv9c5StFR6c8ha6W qFOlLHNpS9jp
8pathCUwWQPEPxKzmLfT1BHb4juG+A4tCWEiYhADTbV8ynvqI1+0cMa+lphx m9ik3/3OF874
jROc37QfWYpFznOWE53efGf42ClPeFYkf8a8Jz5Nxq1ksoUwDDFkYQK6mICq RYAhkxjINqbB
hPoLXx97qMgYClGOTVSiEa0oRi+qUc4gNKMU3ahFPyrSkJLUoyW12DDzqdKV WsqI+GkMEyMi
00MWBJoGWcw00eLED8Uxjz61I1DxGFQ9CrWoRNVjT4f6U6Mu9ahNfSqI7MnS qVJVR23j51r8
ORCAEuSmCmnIM7+aFrhZjpa+jOX/LnGZ1l/2kpdrRetZg/lWucZVUKWDq1vr Ote2qlWvfs0r
YC2S0qoStrDu2R1WqSnWZtJ0oAd5bDR1KpHgqdOc9FznZS0bz8y6c7OeFec8 PXtNzraztKEF
LWlPi9l4StWwrn2tXf6X2LF+65CMgalja3rbb+FQsBzZIXBR6EMdCje4NBwu co3b2+Mqt4fN
leFzXcjc4lJ3utZdLnadW93sQne72iXNYGEr3vGyxaVvSaJ++oOjnWrtH1Bl qlLjC9/5OlW+
9SVbUun73vvyd7/+zVprySvgAQskkLPNliLrpKT0orfBDH6wgyMM4QlLuMIU vrCFM4zhDWu4
wxz+sIdD/wziEYu4xCROr0TMGli27rXFf+3rivEK48uFl8A2hi0yW+YpAFkz xVP4MZCDLOQh
E7nIRj4ykpOs5CUzuclOfjKUoyzlKVO5ykbeXWU7i9rPrnbLXu4ymDU7rQDf uMyF3WcAwQWx
zPiBq2Z+MzF311GQmrTOdL7zSO2cZzyfNDI1hjOg8WleuTB2vQCCmXv/HOhF 6w/L7rXvf/UL
6UlLekZkZjSmiXjVNMtuwW7ONKjVJme/zJjFLzZ1jOmaar6i+pSKDjWsjxkk Qrtssun0MU1j
rWtvOVrMYdbyr02b2mFz2ZyX3jWyUSZbSyGStthlM0CbTRdpJ7vachn1db/L Xf/iZru73eb2
tpPrXRa+2trmxtSglUlhZ+KULdR2CHsZVKCUvhsuuz03vtvi6Ej3l9L9rvS/ aXTsfBPcRwaG
C1e5ett757qfal6kX9pMUK/CVLc4dUy9C07wUau61DJuNcg/LvKOh5yu5dY4 yumT4/Mu1plg
lebCbbqWaoKPKcN8ZlgTo5DcZjzl5u51sYHt66ELvejCDvrR68lHnzNdR2gO jFgV/nKKv1zn
WVVzxaA9cYSQKppUz23TC45tPuu5z2YvO9rJrvaRnjzsbsdLutkSkeb9Y6bL fOzXvd6YmR/6
iYleujTFCtm8Q/bt+N63v/mt+MQznr4DNzzk6bJpqEP/VuqBHyjmHd7piBsy 53rP/OAjf/gU
k7rkrB756UmOehevmvWCBbzoY18XxL4UsoWObNVzT/W0AO/WmFk62G06zeEz XPawBnrSg61a
oief+cs3ukweb/zpP2TZlHeI5b9KfMbU26DS0brg1dJz6ld77No+v7fDHV1x f5v96h93DNtO
furHfebrNnSL5g18t4x//rtGPMAtXgA2XsDtl/T53/Qd3Ns8nIJxHgLOH8el ngS6nulR4Oqd
2gV+jvw9oOitHK3t2LDYXPNBH7F9mfOVoPKh4AkiXUZIRJaNIAw+XwyqIAmy 4EUcIAd24D+4
DcoYFMJkRg76H2a80NmtXRHu/xkSHqESpp2fwV4Qzl/9IVGt5d+jDaAVFiAB CiAWXmEd5dcW
fqEWhmEWRpUTPiH1TV4PAkjsqJjHqZ4bTiAGvqEFymEcwmHrkU7pZWAb2uEe ziEfViAGbqAZ
hh3t9c4UUhaPraAJ1uAizqANPmIjyqAk1hNHOGIk0qAlpiAkKh8ODiIhkhqn jRB0rB8pwp/7
oR+4oeIppp8qlmL7rd+cueL7vaIpymIr1iIu0iJ4laEnxl4U8t79FUZO8R/f UaEYcuEYIqMy
gmEylkUVMuMyHiM0TiOCdGIv+pwCDlJtERTuudvV5dJd0eEdjmMf1qEfnqM5 pmNgsSEgkmM7
lqM76v/hO3KJIF4jynmgMrVcw+HcTV1c4T0EzYnFaG2iImriJRIkIxqkQhYk /bzgJCJkJjJk
QkrkOFmjPWrc02lj5bkc3nUk6DkbxsxZEjLhEhohSZ6kSabkSKokwIhkSa4k TL6kTKJkTNbj
RRLcL0oW3dkd1y2cR+5cMb7I1jTS8iiNYQzIqrCR9USNrCyINlFjM0qjVFqN F05lNEYlVjoe
L96k26FhW2iVQFieY4XVR/JWKuUJAiXNJuUL9SSOurxhWr7S3/AJ3cCjXc6j POalOOJSOP6h
XvrlXuJlYP6llNgkV55bIUqh7XFk4F0eUCpW/TAF8UzP4VxRZUpR0OyMrND/ StF0kfTQSgVp
T/ZAD2giD2g+5EGm5kJOJGsKZCWi5mpGZGvCJkX+ikUeJmKC4vUVEmNWXc7J XEFh3Q0VEGik
ZeGkhkNNkQEdp984kM8MzrpYkGfqSwc9ZwJFECeZSt2wInemYneuoneGJ3gi Vyzm4iye5y3q
Inp+py2S21bips/lJEAGI33EW4PETFPQjM0ozU8kZfNkkfOMUXZ2kRURqIB2 06iUps9cEYNm
JVReJYRWTVU6qFU+qIXm0W3CZ7Vl48kkWOXMDZc0TuEgSV3yzVxOyXI6TnP6 TWi65dEcCeDA
aJSk6IkOpo0CJo6iYzyuIanp6F0Spjr+6I26mGFq/yiy4WPt/U4iuiYVJQ1l 5gz1UJHRXM8W
Vc/MGOj2EE+ULuhFVGm7XGltYiJtzqaYso9DlilEjqlsrqlqZaiR/t8OHhi2 +GBLvhBREs29
4KkUKRAFnctmVpJi6IsldRK+pAsV3Yu4gCZneBJNziRLNiqkPuoQRmpMUqqj VqqkJmGRvmms
yadigaBQPuN7IahPPWWFniqFpip+iaqqXmiroqqlvSen5ptXmgxZPQo7yuPk xGFdCmaOBqmv
+miw1lVfCiuQ7uivIqux9smmziqoJWZc3F592hqsnGmaoqlqhum1bmu2kqnw aGu3sim2xqaa
EoisOuvP6WYaPttvmWd6rv+neLZnvLore9LrvKonRxHhvcLreMprv9rrv+Lr D50rulabp/Ke
uw1jW9SbfcIRq0YorLoqxL7qGE7oxF6sxGasjRBswSIbh64H2C3sN4ZOsQLr sQppsqLssqbs
sI5Jrg6pycKsssYsy6pJs3ZsoCEpy63FWB5GzHmeZIXga44ruJIr0XpruJYr Z1lr0h6tuHKr
0TKLm+LsomUke4zlT1odSK6ZC5qY157Y14Yt2I6t2JYt2Z6t2aYt2j4Y6Vmq 22bqpcatpd4s
1b7ZwUoWTy7T8GVt7gVtqE5DeliZ4A4u4Rau4R4u4iau4ioZAGosxWJsxGLI 1NYtnNXqXnje
b37/3jeepQNSrq5FYMuqLM2uLOmaLN16ro1Ba5Iukfbx7e4BJLUahc1xLOqm rgsOLdQWre4i
bdRG4uTWru0CkHtgXGPy4z9in3B+nwt+GvC+mfnVq8Du67tOL/Ty63OdbvOO 193CLqiyiP5l
b6Y1buQ+ruNCblH8LviO18eWjIceiqf1ZvoKWASW7szWr+jaLyBib/wals4q ppIK7e/Z1v4S
GNA1be7y7u4+7Zeh7wDzb5yGItcSSOd1YwO71vO+LaZmsNzCLQajB+1W8IBt L7yphdgEpff+
XVcdLwif2e2Or/m+cPlSCAOv8FRZLl6k3uaa0vv2ZPHR8FSB7smGrhAH/zER D6b++nA+qe7O
osVmFSMiBnDDITFhIZ/SHrAC9y4WG9sHS7EFq+tegOfIghD4cSMXU9UFB6z1 Aqy/rrEat/EH
HXEZE5MIE4S0csTPzArzZOZEmDCiAa4T9l8c95H4kq8Lx3DEznAgE9P63rB2 Bg4lkZLRkBKQ
BCc4dm4id/EQyuz9bvIQa/KwwvElD1H/5iNfWCYZhaaWMuyS9sTshjImM20W I7AsX3ECRwUi
u7IoPzB7BA5lnDKBuouphHHWLS8us/CkcjAya3AHL3MyQ3Exk9cc/0fe2nGq hJEvzwwf+x3g
wnAhdzMhf/OEtDA4G/I4V+gtPzP/2PBdOPJbvv+lL9dNDvPoJKPzFJcs/hZx zXoyPr8VKNMz
7iix/1Yf9pBRfzYN8jix71lxFRswQ8cyLc8yK+NuQ9ey0y60Q0ffFvtznHmx XqyovgAzAtGK
MA/n2qqtSZc0Sp+0Sqc0S6+0S69b9KIx9Upv9c60TLunRsNWNAtEHZcwZL5I Tr+WN3NzOTvo
OQf12izyOqNaGN+zPj91Pkc1/XLyPo+uVTu1VF91X/UzUqPNKMsdCZeTCVO0 Qle0WZc1Wk80
RJ+1Wj+0WxNLRne1EFltR+fZSCtzMzMzXu/1BvO1Xvc1YP+1YOc1SHG1XJ/M TtfdFBI1Y5Nz
Yw+1Y0c2ZE82GR52Van/M4KpYVZj9VR38mZTNVR3dlVztlZ7trEatmXz2qxF 6yFaNFm3tWuv
dVpfNFvT9my/tm3HxFGntj5xNKV0X/K6cRrHNBsTt3DbdHEPt3Ij93HXtHPT NHTfNGrzNraI
cISxWw+LXzY/dlFzt3dLdneD93ebc1xTN+4o9Tby5j7GBXB/ditpUmmPNmi7 t3ybdnyH9n3T
N35/yXSbN6Z8NfdG0+1hbWLs7Vhr2VPiSlOihJbKNmzXNm5HuIPnNoVL+FtD y277N7bQ9dVt
5HprbkfedUItlMZoEInvy4n7NWGrOIsH9oq7eIsPdoy/eNn1t4ZXinXjlkHw pMWJFeFlXMMm
/8iEcekYHWWfRhGAmibQ9CmTK3lnFo0XLQ7R1IyRY0ZLX/lLZzmWb7lKxy5l j3d481uG3zim
YPZgRB1H8pzeUTBvbp5DWOdaIk47T9Jz9gx0Ok6KOrKdz+XkZJBmhDRbToY/ MwVpF/p8i/Z+
p4mNk7mQADTCLuaHfyTQBu0Td4TxVJF0QrmUNlKRp0o3NY8pZxGUD82D3/aE W/g8sVepr3qF
nzpEjzmjV4r1aSTyRjE/5l3PeR91jOJmLBDjTJFHW6dzEk4vI+cG8XJzJicw U5BxN/tyP/dN
R3d0FQtzO3u1P7u0N7d3Lnqs84h10+dd9FyQD0h+IejzfBHziBEWYf/Rp6d7 lbK7uxd0GBG5
eNf7l69R74G5vtu7v8F6twsJeu9IrjPgh+YhJO85JGm65OTNny9OlVxSiQLq wj95oHZmotu3
oWM8PBK6fnc8ont8fjfhv/sRgH/q/y7LQC4LzcT2hZt6y7P60NEcqkO4q7+8 Qvr7yPMIh3sL
nRaMSx5Mxcs4jA+90Be9SVI70dO40s840zcMt+e8fyR2HcvHuPOExfL7vt+7 1kdNvmO912+9
VkL9EJn5tdwqmLwsyGd8fa/9xbM9x2s83LN92lP104u9fDg6WINgpVdFg6MT 0cy8y7O84NO8
R6h6q9s84MM89OG83fvHrHdocF/HKMrKdg7/EK1A0HYYqg/952lofnVmu7VD e3JfOyoiPehj
e7Sn/uiLPr3WfeO/x7c3GHZntyEaI5Q+CJJnSO6nO4Ss/Ij4fkkAP9h/fZiz RNcPP/IXfxox
/uvLR8DXOvRHsV60b6CAKChBkolif1u6c6pYUibFpd10pihB0lpi0vf/MqES jva3PfvPPcZz
/MfHf8jPP2m7fvPv8qMlKTNpd0/2f8UdOEBMozaQIDWBA/38o4biIEEUBhdG fCjwIYqHEAde
ZJgxosGLHSkW3Chx4LSPCy1qdNgRZciPFQuyLNhwZsySNjHGpElw502bPXPW /IkTaFGiR4cm
1Yl0qVKhTQumUuiU/yfTp1erUvUJFevWrkGzcg371ahWsF7HpkW79mzbsgT9 TPk3l25du3fx
5tW7l29fv38BBxY8mHBhw4cRJx5M7R8+xn8TzkVBNzLeyZLpXs7877JmvAmp OR4oOjRB0lIX
knb8cDXJ1h9JaxSNAt/F2qNtR5y923Zu1is5/haOMiVK1aaRj05eWnlz5s+P O48Offl069Wx
S89OXXt37t+vew/PHLT47ePRn1dvnj349e7bp4//Xj58++lTyVW8n39///8B DFDAAQ+bZirA
pErJon+katAuzRTsLCXOMNMLta0aypCahEza6iWSgssppA49WuigkUZiicQO UWzooxFBZP8J
Jg0t0hDDsGwUEccdb+xRRx9zDJLHH4kUEsghjSwSSRxRS9LJJY+MUkkpn6QS yimxrDLLK7Xs
csi4CAxTzDHJLNPMM/fyp7HH/KpMs8rugvDBzTrbqzxq/Cktz4HydCxPqfJ8 aE/dSBpOUD0j
8oc2PCvqE4U9Hy3tI0X9bDS0SDnyM9EYDcVz04UC9ZRPREfVtFRRPTU1VVT7 ZJXUVQdtNdZX
ZSWo1lNnVfVWWG2l1Vddf3UV2GFZBS1XYZE9VtleiV0WV2aThdZZXp+tltpr d8022Gm1bVba
b63dNT80yS3X3HPRLZexgRDcbC6p8pITMznrtFChtwq6U8GMLOL/iDh/Rer3 JRL5PYk4jfql
qDiIIpSRX4dN6vdfgPFVyy2rLK6YLY0vNovjjzHeOGSMLuxYLJE9HhnklFk+ 2WSyVI65ZZhn
rgrMdHHOWeedec6LsTwBg5MyvTybULIJ680LNNIGZZqgC5vu1bmoR516OapR dXrq3Kp+Duuv
rw7b6rG9FrtssrU+W+202ZZ6bbfb7jrurOGuW2676d5wqrfv7jvvv8FGG+/A +Qbc7LkJR/zw
wRf3O3HGBR+358kpr9zyAA1k969U/ODc887JLPlJDrks3Uopi/Py9C1XV531 112P3XTYZ4+9
ydpxbz132nXvnfffZfddy5svL97445G//0tNzYtfOtpRAQUX222l7/b56b0N l3rts8f+euu5
3d778LsHv3rxzcfVWPTZL7/9798nH3736Z/ffvnxP98xyZPv3///ccYYgRAG XmYqGcr0hkCa
uWxlDJSZA2umwIw9cIEVnGAEX3ZBCG7waXuzoARBmMEQNvCDIjQhCTVYQhSi hXgAdOELYSgg
xjjmeM5rz4Xqk0P67HA+PbwPD3/oQx0KEYhDDOIRjRieOyWxiE0k4hOR6MQo QpGJVFQP/2KY
RS1uUTCZY1NgClgm0S2JdMLbXfCAd0Y1mpGNaWwjGuHIpdu9cY1utGMc6ZjH O9axIS3k4h8B
GUg10dB4dzJf9P/qlz/u3U9/jFykIsfXSEimL5KPlOQlLZlJbK1Pk5T0ZPww WUlRfjKRoSSl
I0f5KiwGkpWtfOG6vtiuM83RZaAh1xRWeEIKppCXI9ylLzGYS2H+smNjDCYx h3lMZXKwl7pc
pgpj5kdXTpOaxftZLCtnQ8MNBDX/eJzjGuep/ChOcOAs5zYL9010kjOd4VTn O90Zz3PCs5xL
hFw75ylPfO6Tnf28pz/Nyc9/DjSg+9NPNRGa0J55EUGdc6jnLFOXySzoaJnx jL1Kx6Gp4BFL
cdEjR0HKR5F+dKR7fCMtQ0pSlZqUpSltaR2lqVCZzvRMy8OmXoQ2l5xSiE4Q 8mmbFOL/PkBN
5ZSQHCcqi2pKUHZyqaksJVOf6lSkbmt9UU0qVKdq1aZeVaqT3Or7VklTsY51 QAK8aV4KqJkw
umteFJpohS6KlwOazJbJdKBHm2lXaD4zr8j0K1+ByczAdvCvgnWmYfXaV8Ae dq+IxVhMyRpZ
ySJmhmf9DFt3WjS3bpancb2LNsfTzSpG8ahWNO0UUTta1UpxtadtbRDt6VrW zla2tU0tbW9r
2+OEdbK99S1gGLo5ziiIQcVNq0Q7C9cK7cWYStLoSnOEV5dOt6TUhW51sXvS e2X3pdf1bnfB
a92cQPa35TVvXQZp2c9iNqJ0Um6EPFsXQ1JvqKaC733xm9+U/7QqP1j1qlYB nFUB/3fASg3w
JDnZVQMX2L8LJvCDHRzhBnPzoOe18IVhKUueFjdOyL3oW9mK1u2axZYzQQEN dIBiFaeYxSt2
cYthTIOTxCWxg1WsYxdbY8beuLE9zkpzfWxjIe94yDo2cmGhSd4LLzmy1wza ZS1jtA9vmMqX
3Wc3m4aCGG/5xV2G8UX+NAWArpOgZC5omekp0DOv2cxtTvOYvxlbN+sTznRG s53Z/OY755PP
aqYbb5kc6LEG1y+fM3To9ja6f3jxRF52NJdjnCLpcle8lab0pb9baZRiOryc tnSmPf2lCgua
1GK1aQ2DCr+hlkrLj3Y1pDFFjaNCeP/CCq41V3H91QNL2NawqiqDe53rXd9a 18AWtoABXWpl
U9OsBETTXN9SV5G8mtqRvglei4xkHm872znWdrdxfLK5gjvIRDb3kb2d7nBj RcnLdjcgK4vq
I4rWNK2GdLVfnJvS5pbfr/U3bv+tW4APvDlyDni/CY5wgS9c4Q036LshTk1C g/HZiSbjojea
EXzfO9J9nAKoQd7pkH9a5Hfc9MhDjXKVl5yj7Y74y12YXnlbsr6isvfGXx0p gxJ72MEuNq19
3vNjAz1bCR46r4/Oc2P/HOlMt1ayYR71/2V4MGsdEy2/UmKe6JfrXc8XLr99 7rCje93cFru6
9wpks5O93Gz/X/vY4Z4yl0ud7tb0pnp3pk3CYRnPc963nvPcd8DPuc91Lvye /Tx4wMtZ8YJ3
/OEDD3nCJ/7xlI/cqOueeeRNXMPx8vBPK9qX5grpuSyHy8dNv3KSrz7lqS/S yV3PetW3Xva/
m7vmca+zU/9HsxQdrkWByr5VB/16s2660J1OfKInP+nKl+Svl4986S99+tGn vv2gnnvt56zZ
VedL7zdbr/jWBdpMkTbabYZ6cr8d/et3/9nL/v6ejBv+bY97/OvPfvwn9vbb 9z+a4o33PCz8
lIsvQGs7usnQHmoBFbABGfABPUfMEu7gKHACLZDhKrC2DO4CHY4DM7ADMdAD ZQ3z//6vBM+F
84TLQRxkuThL/FhQxDJq0aZgBmmwBm3wBnEwB3Vw9ngw9mjvBz8K9mpvCIHQ B3swukjQBJWw
ptYEQMAvueDLAPfmkO6u+o7v+qwvC69QC5WOCzdJIbyw+cSQ+cjQCrtQerJv CdWwrA7E+/bi
Cd0rxORqxGrJg+Tv/uyv/fLvDvXQ7YBJ7fhw//BQ//JQEPtwQ5JwDRVRhu4u QIirykDsBdfr
yoiq8gzP8jDxEjUR8TYx8jKRE0GxbxjPEkNx8jrRFEux8SRPFd8mDRfxFRUD BQut4mKQCI+w
CG3RCHURjoQQF33xFoERvPoPFolxMHaveVItfKLnDJnR+f+acQzN0BmlERrx BPq28BqfsQyx
EBunsTRcsRjBMTC6TzCsTkzKTynKww/3cB3VsR0HMRALsSvozx0PsR4N8R7j kZeGMRz5US8C
EBnnbSo+cCBFMAQNEgQRkiB7aAMPUiETsiAfsiGvKBH7sSL7QhZFjxatpIyU ZCJ+cRc/MhdF
kvZ6MRhH0iRDcnf20SJZUuYKaQrpqwr3pVYOpVkiJKp+Q34aRlVyciWikRrD UBuD0qqMTii5
ESiP0iizMaq+kSWdUiHakBxpkWPK40VwwmDWIkWgyWAqxiOHgivfkR3Dkh7x UbEAUSztMR/h
kRDZ0pdW8in50clekhJBJTkWBmH/VOJQUsNWKuI2IuUuFUU59PJfAmVhQiU2 UmI1BIYkFMUi
ZkNiJoUUPfEUWZEyJRMVE2gVL7MyU3EzPVMzQVOgmhIuKxIj+aIckaungC/0 TtPijoRDLsJF
VgImgiNFIgYyESYjTiRicuJFYrMidtMhUgJGaBMlQsQlqsIrQRIlmbOlSnI5 ofMko5O73pI0
i/EY+6P3QO/3+sJ5lNGbwExSZtNhBpNSbM5RIAU9w7M1+GRRAlPnYq0nD6U4 DWVfJAYpl3Ib
83Mok8Ua9zMpf1IpuzFAiWU0rTMcx5Hi3nAA38oFW3ODQEMrIwI5PbI4T8TE gINggDMmvHJg
PoRhOHQ8/0MiRGxCYtQSLctyLVX0LOZxLF00LdsSRU90J6rzQF/xH7OTQVtQ EiexPi4ENggF
JjqlORYFN4z0Uoy0SMVzNzLiNpB0SYHDNYLUYY4USCXySiMySzOQIbUUIh3y S71UBA3URonR
NJnLuNCUBUHMQcePLkZvR8poX25zRIZzQrfOPoOzYEqkN+t0YQ7GRewTRHnz Q+8yYey0OaUz
UfnoORUVUVPSUbeiRsl0DV3SP56wTqLQTmDSWxBJP51R5zwVPwc0VAVUVP2h KAmUVFOVP1mV
G8d0UheR6qRyQeOwVqvsLrDOYu4kRhPLT2f0RVNURnn1Rc+SLH8VRlfUWPtK Uv9hVQnlkvek
bE40S1PpEjOtlTMnszND0zK3VVs/MVtFcW+49Vuv9TPJFVvLtVvv5lWbVQ3N 1F5myTWda9Ee
dToh1V7xdboYtV4bNV/5VdTalTSx03K883yWcVRb9T8VFmEBVFUHzD8ZdmFN tVQpdvrYNWBN
MEE7D9EgNOOQVViTFViPNViVdS1a9GNLFmRVNmUrhlkxdvtwlGBT7YYEMkyx FExv1ma7NGe7
g0txdmeB9meFtoku9mX9711FLF5r8ZbutV+d9l+1y1+bFmqltqMo0mhfsVIv Z7441ZvWhD/7
K2LFdmJXtWET9gsd9mzJNm3N1lWvFmsVUVYV1IDoMOv/oHJkEQLsUFZkh3Vv /dYQi5VvQ/Zv
8bZv7+pt4VYNn3VrZxad+E5dDefvzHVcKddbKxdc0/Vck2MUIRddPXdyLTd0 MfdxijZxNQ9p
55BW52U7fe9MlzbkJm1qZbdqnxZI9nV2a5d2i9BlTZfuBnY/tHM1uVMKhc9r F9b4JLZi2TZ5
y3Y/IXZt1VZ5o7d5vad0e5fuNFa4VJcA15RH7eIcoeL8SBYRC3dwx5dwDbd8 T/Z82bd8V1Zw
d4x3rxfmYhZ4dbR7b7VH34PecKPr/Pe+lGPfhpZng1ZnBxgEfdaAFZiAD7iB R3B+ixF1cRVN
V5DK8NdBXXcjMc4nUIAbPPiD/0E4hEV4hD9Y0lAvd1GYalOYSm5Xd3FXhVtP fiEY4rSWPy51
dR8RpzY1WmoOUkj4h4EYhEE1bKG3bZl3ece2VFEViYv4iKeXiVUJcWdY++R2 YzvMVjnLe920
bnX1brcuiMGYhGdMb9s3fc3YfN2XHgMXfdH4jN93b2V4ipdtcbMzWgdQDvU3 oB73UsK4j4UY
eiRwdEFXkDt3kDP3cg8ZIcRVdBOZkDW3kCH5kUVTiuX4dKNybsVIXklvgzGi g/3Yj034hUXZ
hUl5Glp4hUsZhmGXkiu57n6XcgpWe4bPUT4ZlAcFeZOYeps4l6H4wJ5Xeo2Y l594mKHFelt5
junV2f+UdoHEdyFquY9jk3zdmGXhl5rZWITWN42reZuv2e3i+JgDrX5huXFD CypVw5OfOYj1
LZALmIEXuJ3hOeAS2J3pOZ7fGUyNGZxJTYK/VyO3pPRO5H8Fuk7zdpRR+aBV +JRVOZUNuqS+
WZ8vrIazaYeXpYcbloiB2YmDeZc5equWmJg1OqSFOZjzGaKZrIq1l25NSOvW ksa4uYzbOKbf
GMfWGKZnWpu72UUf2qTNi44nmi7vLpKdRnKFmpE/t6gdGZGPmm84V5KV2pCX +qmRmsxKmqct
jJ/J7/s+T3hbF6M0mNE4LXYZeqwRGlEVuqHRmqyvZKet2rdeOTGClzW7Wmn/ ktFgvdYB8RoC
9RqvJRCkR1qkO1qXqQoMM/qvDTuwe/mB25qKk9kNieZ+kyt/+7ljqUEHLfuy MZsGcdqmrZmz
X/qDsnmaP1u0cxr92HqxJUuc4RqyMViHA7KeHRi273m2ZbvgFrm27Rm3Y/sh qxq1fQurt1gF
OcyCI7u1YfCrF7qs1Tqt9ZUOlfu5kzusWdm3SU2iFeOG3SpCiJfmqjCx/Rqx v7uwOfqjN1q8
zVuwqbe3qTu1L9mK5wSLI1Gyt3il7fCmSduzSxu/9Vsoanqz/fu+//sOT3u9 acqngdeObbVN
/0HvzAZqoPrBpzqqjRrCnVp0m1qqKzypJzzCKbxt/9SbwAetvVM6k2sxupnb xJfbOZ0bxaH7
xNtowEFcod66Z2J5eg4WvMsbvb07x3dcfQhbx8MbyHkcbKc7xi0se2dxmTUo HZnCKvM7wO1b
pjs7yEJbykfbyp9cH4vcyHu6CefSRwVyX5zDSrnjJlmLa+6jYaADzZ10t92c tnN7nnN7zt9c
t2frw7lcoYD7XfxZ0WDkRpTTSGwzdwY9Sgq9k1s8xRPdlFfcxRWdxVVyy/Pc rb0cILnbPGNl
vxJF02HCvtRTTwuTNQzzUjLdIiClONJTT/alNgSGUv6yXxRTUNxzyGkdsJWY sG1dyHO9x6UR
zye9mlA6yVWaKhXiJEa0UP9mEys1VDklQjYBBiTIM0pvUyMu9Dfzsto5GMqn HMD7tr+5Hcv3
+9vFDsZ/vZUMfHIYnGxQI9ZaI1Rgwt3hBsx8oziUVM0ZRTA9hT7rrWqK9FF6 oz0Pxt9/Q8MJ
vpENXsLB9cI3PMMPvsMXHsMfrtzdjZ/xur20WCprMZoBRkhFNCtaRDd1M5oD HeQ33k47NEN+
00RIniE03iNG3tEXndLO+tFhHtIjVdIlnqxmfL14/r0vPjBqXFuipyaj/UPK k9QzAj2Tftbn
8zzFM0RCRenbs1LqsjbS0z3DU9Z3Pch5feh+WdcP+7y7vth8PedZCcmTdsPK cVqlzPeM5riX
fKP/xPwu9VRFRKIkTmLuE8ZXp73uDyZg6N0hFAYk8NLlB+bKozzx/bDKFR/x tx3cLYjczZ6L
VBvKNiyz7rjDFFynyBkBa9bO24PM65zO4Xz0lei2SR/0U3/1V6vsJ/+PKH64 JkS41XR4ZT++
vfqf6VWUFybma565Z973aX74Pe71q7vSu5O9rni5FoRegu/SxZ7rpb/Ww/4n yXvrqR/HsV+T
XN/4tSjY016tLJ64nT8j6TvLIV/cH7/x083b0//92T/cRUbyvR+Gzt3y5Ste 2t6nKOrtrYyd
ACLVP2rU/BGkhu+gQYIJCS5EqPBgw4ISIzK0CNFhRY0XOWak2BHkx4cT/0li LLlRJMqQJj2u
HJmypcqTNF3WnGkzJ86dMnvG/NnRz0CWQGESPWo06culN30iZarTqdKmRaHy rEr1aVaIqab8
+wo2rNixZMuaPYs2rdq1bNu6fQs3rty5dOu+nTaUbSo/e/vytbtW4MFpgwsT JCyU8GHD1BQ3
Zuw4MuTJiys/tiwZM+XLnDN33uw5NOjRmkt/Ni0aNenTrFO3Xu06suDYsGur vv0aN23dtnP7
3v27N3DXfrwCPo48ufLlzJs7f57WX17oalFYPysU4kODCbdTE+i9e0TxGslT NM9dZPrw6rWP
b4/efXn49Nnbf39/fv7z9fH71/8ff/utFyCBAP8eKGCB8iWoX3YGMgjhgxIu OGF8FvaHYIUY
RkhhhxcO6OGGGoL4oYIJdUVdiiquyGKLLqZIzT+EvQiXYAdxdqNj2b04RY43 MubjjzgCSaRl
Qf7o2JFKFjmkkUwm+aSQTU4JpZNWUilllVgKqWWXWQppI5JfcjmmmGSeaWaa S17pJZprbqlm
lG7KGSebZb7Z5kHF0chnn37+CWhzMSYUaFrZTYRoSoL9k2hIjX70aKTfTSGp oylVCumlmlrK
aaadYgrqpp6OGuqnopZK6qmqmspqRtm1imqsq6YK66yy1oorrbreuqutvqJY aLDCDktsn3gR
VOxYYdKW2FDDCadnj8H/8UbttNY+Wy2210KbLbfbdnvYbN5qS+645oL7bbrl orsuNXsmC2+8
8s7rlnSEzvsqh+KBx6iIIZI4aYb/muhviQIbrG/BCgPMMMENH7ywwwU6KDHE Dyd88YgVY7yx
xhZ3PPDHIk9Kb8kmnxxvjMjOK+6cBO2I5510vjxFnjG7DOfNdeY8c8924myz zzz/vHPQRAe5
rMxHC2300E43DbXST0sdNdBUX/0uylpvzXWLMRpE76FbLSqVVWVH1JXZWEW1 9lVasf2221PB
Pbfcasd9Nt131513vnv/vRXgegdO+OCG21044ofnjTiwXT8OeeSAHRsjy0MF 1yy7vRWneefq
/577ueftjg466ai1HHrqpqteeuuiu5561pLPTnvtZkm3srxig8hvedb9Dnzw wg8v/ENpRzyy
xxwnH/LyzisPffPRIzw98gJSTL302mfPvfXVZ7y99+GD373jtp+PvuQxzmh5 0XoOJOONKPyh
Cv3214///frnz/8fKCzGOaZdzWoEdF8BdYZAAR5QgQZsYAKtFKYHTm2BS6vg BB3IQAlWDYMW
DJrs0gfCEJpsUJXT3UBQtShEoUAVgGChC1sIwxfKMIY0VMX/uEIpX+WKVzzU Ya926MMeAnGI
PyxiqfwWxCQSUYhGVGITl+hEJkqRZCKsohXhRTl6JU01mbvM/PoHxv/9iTF/ KNCRtFaHRtil
8XVsZF0bR4e6NbpxjnKsoxrviK4PXnGPfOSTvUoYr3xpjF/kWWENDznDRMYQ BenpCvO6Rz7x
QRJkk3ykJC8ZyYxRzJKZpCQmPdlJToJylKIkiPn6iMpUwmg68kLdm2A2mC+O cZZhJOONirNB
DQ6QgxfUJQV7mcFgdnCXSLtcLoUJzGH+8pjK5CUzkzk1PapymtQ8ztcACS+x 0Y1sEjGkIr+J
yEVq5HiLaxvjzmnOdOJNnXxjp+AUB090rjMol3unPNs5T3zq057uTNw9+ZlP wJ2ymgQtKFyy
2D7edFExsqwlLWdZxmi9EY90pKgdJ4pROsb/0aIczehFK+pR2EnToCQtaVlw h81k7U5BvTuP
N8MJzm8y8iDHC+XzxkfKm1ZSp58sJU9tuh7s9fSnOf1eUXHqU6MmNXwDNalT n7q+lBYrgnDa
UZKIh9WsCg+A0mqmL51JTGQ+c6xh9apYy0pVs6oVmmRdZlnZ+ta2YnCkT61r QUkYthPOKoVR
/FUOoQjYJwp2ioEl7GD7WthVITGxjD1sYw0LWcQ69rBNtatlqYnQVhpzNAvt qLvO6NmPija0
pA2p6DZqWpCqdrSpZW266HrZ2PLxj3mVGCGHqiFHEnWpO1Xqbn/r2+AiFbjS 2yRxeztc4SJ3
ubhNrnMRVlnZSteK/yqTKrFcySRYrtWDNYurd90KXrCG96vkPet4DbNF8aq3 vNv97nrN+972
wna69EXfNWu7t0X5Zb986S9//+vfAP/3r/HsZzkD6k8DFxjBB95nghmsuMUu 2MENBiiFJ2zh
DD/4wv+kYn0/LMLMxiu9oknMFE6M4hSreMUsbrGLW1va1cbYtTQWDmplDOMc 43jHNbbMfEEM
5MehFL/+As9RmQvU5zYXyUdespOT/CGhQvnJTZ6ylauMZYhFN8hc5lpUtXg5 or1KruyF63nb
e2Yzx1fNZWZmWtkM3za7V85pJnOcP9vlPKuvX0RulY0i+1jJAnqygy60oA8d aHoimtCLNv90
ohn96MhuWc+UlpeI4UXiySRmxpzWcY953GlQY+bGny51qE3t6c38uNKsHhZt 8XW5Qf5DuVTm
ba2Pe2taX9nWmhzIrnH9a11nGdjDVt6kW43sQlUXzE7L153RvGY7Q5vO0Z7z s82cXmpr+9rS
hvO0uf2lVSd73Hy6L6z1aaMOV3jDGl63uzHM7ni/W93wNpyE6Y1vBecbwvvm sL7/jeBjk3vg
Lrp0sjKtmU2r5n+kY/ipH57qiIt6taSG+MRRfXGLm5HgHA/UkM+dPSNTA3jt +d+ASA4gk29v
piILXnhY7tJgK1nmTOZ1sbUj5ZvXnNg27znPf55b43R86DT6ckL/6fSqG6ZJ 6W1SekSFpHQE
3hBqUTfS1K397ax7e+vdNtqbu451rocd7HUeu8zETfS0JwevIN/rQFDQqN8R 5IZyH7ndGwL3
g9DdOnP/XUL+93eEoFzwHak7PgZ/+MLL/fDWSTzc9w74kfN95I6GtOUrj3kl SjjzkW605zsP
ekYLXO2knxwrR7xZLsro6nPXu92dLvnIXP1/sHc47V1vey86pvaPcbjk+T6N qdOeoXQP/mGG
H0uJY3z5M6648jUO/ednFO2lr35cXm1C28467w+J/O29b/f13NAgtCe5ym8f +PODZKaBb736
uQNzf3Cf9vBfCCODJ/mZ6zzX+vd5cI0r/2z+139AN4ABSIDQJXTWp4DIsWzt 0zTZEXWEwXu8
9yNP93qcQYEX2HrHJz+9Z3cbuIEMpXfGF4K3ZxiTJ3Zlp4LVtoK+lG3g1oIw yIIzuG3ylYAL
iIN0YW7Zl19DoXSBR34XGIRKZ394F4Tph3sUYYIfSHhKCBFLSIQ3ZIRzl3gF IYX0R4WuR3ny
Vm9d2G/t5oUA5yr1xIVfWIZiCIZmOG9oSDijl4NvaBYGN1Wp9xoKR3LBZx0S 2Bi/o4eyV3d7
mIe/J3x1d4d9B3x8aIi+FzwkSIJ893QRRYiTx4jRl3HSx2POV4mZyHyW+GnU B4efCBYfx4NF
Nmv71zAqlz0qJ/+AO2eArViAr4hkObeK/MeKsEiLtwgwbgiKu2h0mtVAY2Z2 B4SIQPOHKUiD
MliDxpiMVfJ1wXiMWkd2z6iMweSJuwiHbDeKfjYUnHd5n9eNoceN4eiNR0SG 4DiO52iO6fiN
vaKL1giHcnhddFhi8cOJlLiJmmiPzTcQ98iP+ViPbVSN7oiD2BdIsTYwRlaL CYmLpsiQs0hz
uQaAtviQE9mQB7iQpnSDAqmRX9GAvviAYQaNzriMIomMJRmSMVgZL3iS0hiN I4mS02gnAbmR
1beDBYluQ6GGYchvbLiGO+mT/vaTaciTOHFvQ5mTR2mUSRmUZxhwGTmT7giP w4Jwn9H/LC4C
Wv+Ij1jZj8qHiVuZlV/ple0ik0+pdqJokyE3azgpkTSVQxTpkBXpigrplj8l ixY5l3F5kXa5
f+1IlqXXi6j3i/DTkoURQCvpkixJkoZpksnUjC85mIoJmTA5jWPZl0OHjWfp diRkjuS0juKo
jp7ZmejoWJsnmqBpmqWJmonFl5WZdlEpLFMpGZ2VWgEUlv4IlrZZR12Jm7up lZRImaxJcASZ
TQZZIrf1kLqFl3e5lm/JnHqZPBEpl3C5nM5JncnJlsDpjh0JmB9ZXYqJS4kp mY8ZnuApnlWj
kuPpmOSpnulZdr+JneNWk8N5k9fEEFpln1k1TgSGlEvZk0Dp/59CyZ86+Z8v U44CCqAD2p8H
qqBMOaCr+Z4E55rBApuEKSPOMnfo4A4YqqEZyqEb6qEdCqLoYIG0yZu32Zsn qlH7WKK1iaIs
yhnu+aCtZpbyiZYoBX8hiqMfqqMgCnM1JZ3R2ZzWGaTTOSJ1KaTVSaRJCqQW 6aAxCp/xw2w6
Y1Xys6NVmqMhenWFiZ6IyZ5c6qWHuSaN+aWLWZ7rOaZmBaNOSmmXSaOZ2S/1 eaVWKqfuIIWT
cpqfmZqhiad7OoZ5eqd6Cqh/amhNqqatFqGFMqEAVKGVgQJz6qhYakYtuqKT Kqmno6KVaqKZ
6qLAkaaF2mXCqVLE2R/GOXdxaqpWyv9+AYOkS3qkraqkeSkh0Amrr6qcrEqr G0Oonrqmp4dp
l7oz2rWHjyqsGRp139mlYEqmZoqskakY51mmx5qs0MqsWOOUupp28Rmq81mK cDqsjzp+dsqg
C5qg4Uqu42quBkqgSomg6Hqu+7mu7ipQ1WqtQ3eogZKojyGb96mvwhOpmkqp /oqp5KKbAfuv
m+pZnTqvHzaj2VqjarmkPjqktiqxszqxE2mktxqxFKuxtephCat2f9mrgRlV 6amlz3qmW7qs
KPtsYpqyJtuyyhqtcYKwHjtdbMqwbiqOnCmofsqzfLqzQ0SaPtuzgTq0P5sp uUqzIFavgHKv
iLGoE0eiBCv/tQBLtbExsFVbsFk7ffKatOMGqsUiSAeZlgBGtgJmtmXbF9Li qhX7oxvbtkAl
qxwrt29Lt82JtF1LX9oZstzpYn3rt3+LYi4bsy8rrSqLZs4Ks9NauIKruGIy s3hrWdgKtnq1
TWoZoPBaruyquZjbrurabkV5uZ6buZy7uaK7bncLubK1tH/StO5Cj1g7tQYb u6d2tbILu7fb
iVybupW2sJOrPSK3qm6bsXM7vHWLMRfLtsWrvMHLsai7u5ELpUcnZha6uIlr uNfLuNirNCw7
uN3buIQ7po/7vCZls76LQttYtOkrtOtLtOx7K0HbvvFrtPObvs47vk+1un7S ugqH/7ta27+z
21q167+2S8CgI773a1BfSyxhW5ylmLzMa7xrK7wQ/Jy+FsEYS8EZLMHGo7sI HGR6e3C++kog
SSUoeCVV17hMZ73Zy8Ir/F2IW70xfLItTLId7MEgJrkLTLlyIxgk9xJEWBS3 RxLfijd1ejg/
OLqmW7qhy8Tvujag68RNLK5LHMVVvKD2e8MGlb99sr+rx4Gf4XuvsYQMhS0W +CxhXMAA/L/X
IsBqnMZrLJY2nMX01bs6/LvbpxEm9zvkN3l+x4Tfx3f1pxB7nIjrJ37WEYSJ TMh6/MAbfMGN
PHPIO8GOvLyUzKRyPMfSBbIhLLIWeHt6qMLu54Gf3IEeKP/KIEiCrQfKSXjK EejCMgy+sewz
3Pu93qu9sHxnB5zJqVS+dny+W+h+5tdNcgd+6NdNF1HMWtiEf+fDtMfMxKy+ 8hvN9AtY8EvN
0uy+0+x5WLzL07TFfNLFkzjGdteHGniBoezJSVjOI7d7J9iIhYHGAyzPbtzG cDzP9lwtutzN
s8Vn5/Yx4DF/rYeEiXyBSBh59pcevEfQh9d9T+h67SeE3wrJEz3JGAw9cfvI FU3RxPtb3LzP
qATCc9hsbyd3xEd38hOJjth3sZTSeleMKFd3eujSJ83OrzzDNi3LygTDN43L tezTYqfPH01d
pdhnPGy5VrwVQCzFSbzUndvUVPz/uQVKulOtxFT91Jjr0UK9R99MI+EMcTF9 z28s1hZVz2Pt
xmHNGEGt1SFUx8OyUgIDvJYs1xZN1xud0f4gyRw913ZdyUqW1WtdRZss0lJK vTxt2Dl9y4ft
vbSc2IhNw4qNppgM2CXVy269w5jyZ9qczZuNzZ1Nzdas2Z4d2tfcQ3892SDE 1S/i1WfN2vjs
2gLrq2b92midR5J92gWlwJatfXut0b2t13UNkRbc13ytwcD9a6Z92+cT0vE4 0j3d2Lb82I69
njst3c4d3dBNrclds0TddpW7Tf3lrn5h1Ukh3lXdNn4xxT3hX0w9FX7Bn1Cc 3uZ91fKN1E6N
Q9otXant/yKrzRp8kWJ8IUf+jWIAHmoCfmIEbokGPgUIfonFgWJ7wWkKzhen Fdu0Pdutzam2
jd+q1NbC8tYcEtfy4QeysycDY8z5MeIJWOLJm+JhseIKA8TL1eJgUeIfg8hM teBhkeNBOuNf
UeIgcuM33h15fddFPty+/R7IveF7xj6+SNhsMlDdyagZCOUZKeWACNZ1FuUg iYcoCCVhTF5b
jiPDKD/HpEcjO9MmjG1WToe/J4Jzx4wk/Nw/fd10bm1qveSQU9keftmiktkh 4TjXwZFvmhEo
aMydUlmaWeiVl+iEXoWPXhGRF1iNniiSvuhBNOJl0Z2BN6jVig/oC4J0h3eN Av/anE3ao43q
lqLkef44+t0i/B2bxgE8X0E57VzT45xw1VrrybeHt27ohxiIXKTr1JvOv5eI 5cxwg1diw24Z
kJfsgfiHqdHoGAjP52yIokwc1Yrmk8jOfEjm01DWFi7bso3nrM41uc3nu90h wDLraTkfdDeE
LFWtNqod4xfIg8zQD82EE1JZ9J7vohzvA23OB+0f/d4vDf3v99cd9m4wmU4W KtN9izxTQe6E
kxd0mu7AVug78ucQ3KcQGH3kv03cvH0xq27uW7PcUinC2UXCG/cVgi6YFdjr F5gnI4XmIwiC
gviBEliIaGLzr7vzryfMp0zzTHglP+8jNG18TvfmVY7/8dVeyn+szmfH7GXe gY9YTNht3Tit
9dVW7iePMjms2z0YFQ4fFipTElt16Dxh9mCB9haRdyNXhHPH8Q59Tm0/6CNR p0sIhAN/d+FX
FXgPPzOhx/Up91l4+Fqx5SahilIf6n8PN4LfnXPf8cAMcw0B3+wd3/PN+fUN 1R0L9lrMq5ys
UK+bGanQ5HnhzkkYyqeB+oCELJAhfF+89LbOhNKe+rHPqGRMzn6fe7B3G69/ 9t1p64/IiLPv
G36QO/tY2Cqce8h++6CRCss/I2Dsgcc/ahWO4eLO/TQT+ibV4cHy4fy+rRDy FeLxFQaSqt/X
POdPEelPIQGthC0tf0K+Ie4P/zYZb39yt/95BzzwBxAoBFLzJ3AgNYLU8CVE 6E8htX//GkL8
53AiPoPUUDjEWHBixosMEy70F3GkyZAGB6JIyJIjSJYkEY4U6TCiRYoyL4Is SJIlTX9+JHKs
+RAn0aNGZyJdqjRkUp1Am0Zl+nRqUapOpVrlutVr1a9awY4VWzbrWazUUk2J 2NbtW7hx5c6l
W9fuXbx59e7l29fvX8CBBfeFOI3iYMR0U0mcSc1wY4SPqQmNDLkyQreSG2ue yfkyZMmZLTse
7Zm0ZdOpZ4pGXdp168YsVVt2u/k16Nu2Udf+rBs37N/BMbcF7ts4wsW5Oyvv vby4c+HQjzen
fjp69f/Z161P3y7dO3bm3cE/98M28Xn06dWvZ9/e/XuT/xbCR0x5IcL7D/HP TK7ff34AZwpw
PwL/E/DAAgc0MEEEF3RQQQgbjJBBAkGa8EEJM6QQww0v9FBDDkP8kELKOgRx RBFPVNFEFlNs
EUUYV3RxxhhfVMs8+nLUcUcee/QRvWkY+5Gv/qyT7MjJ/kHysyWNhK5JKJ+U kskpnaTySiuz
jBLLLbWsskswvxSTyzG9JPNMM41MLkw02UzTTTjLjLNNOeuk88437cyyvCH7 9PNPQANNrKT5
BKWrxLBkWowstKBKy1FIr4q0K0YflfRSSs2yNNNGMU10008nDdXTSkUtlVT/ ykzVVNVOOQX1
VFdZfXVVUmmNtdZWR70VORwN9fVXYIPVEaLhhG1rzfAQ/U48ZrPjztlloR1P O2mbDa9abK/V
9rlpn92W2teKzJZba8kdF1xzv/U2XXbRdXfdd5fj01h667X3Xrsgssle+5oq EKdU/Ah4YIEL
JvhggxNGeGGFG2b4YYcjhnhiiSum+GKLM8Z4Y4075vhjj0MOmDH/cMrPZH9L bhDlif5d+WWX
Y1ZZ5pNhnvnmmmlOOWecd/a55Z6B5nlon9fC92ikkwY2yGLpFVdMpaOWemr1 8sRzTquzxnpr
Pbm+umuw8ZyXarLLNhuwkpo2tl9Z28Z11lxh1XVu/7nrtpXuu+2OO2++9/Yb bsDd3hXvvwUn
PPC3Ddcb8cErNfpsyCOXPK7CDnOa5G6jVVfzduH1nPN4Mxe93NBJ/3z0c083 HXTVU2f9ddQ3
j71z2FefvXRox558d96phqjQevu1cXgaZayxeOKPV9545pNvHnnol3d++uif l7566q/X3nru
s8/w8d7DFx9fpi039umv09c67PXV97p9+N+Xn/353af/fvvzjx///fWvv/80 6W58AySgoQhl
PmEhanGK6xvjDsfAwiVOgo1rIAQduMAJPjCDGKRgBDt4wQpuMIQftKDhwFdA FKbwR8RCYLCQ
RbvbtU52tqOh62JYOxvWcP+GOeThDn0IQx0CsYdC/CHuiijDdAlQhUtkYnv0 1UJgCU8kRBPa
z6ZoRZZdsYpb1GIXs/hFm1HRi2HEIhm5CEadndGMY0wjG4PmRjGi8Y1yjOMa 6VjGNt5RjXm0
Yx/5+Mc5+rFnJ2xiIQ2JmPLdC30A/F8j+edI/z1SkpGkJCMnaclKQhKTm9Rk J/WkxEOGUpR5
SRsUf8U2EXpQgyRMJQhVycFVxhKWsxyhLGtJy1feUpe55KUrfWlBQo5SmMOk nJJM6asi3VCZ
QTQiEZ3ZTGgiMZo4PCI1nylNbFpzmssc4jaZmc3mgJKY4xTm745pKCluz3vr xF471enO7sGT
ne//pGc86zlPe+YTn/uUZz8/FExyBjSUibTXIj2ZyUselJMJZShCHbrQhypU og2FaEUVKk6B
ZnSJB7yXAnf5y1aWMKQjZWVJbdlLkZoUlyBV6UdTelKWwvSlcgOoRm2KQhYq UiLdBOc3tdlT
nv5UqNysJlGvOVSfGtWbQVUqUIuaVNJg9KZTDd8TOyqROgIyq4HUKh65+tWt htWrYt0jWMd6
1rKSFY5oXWta2arHtsYVrnMVpFrp2lW35vWKNaVqX3dH0HoZlKITjehgDVtY xFr0sIpNLGEZ
+1jHdkmqfqWs2Up5VZeSVKaaXelMM9tSlHL2s5sFbUw7K9rQltazveRr/2Vd 6ztj6nSpT2Uq
VGt7W9rm9qhNRSpud2tb3c72t76N12Rfe1ykmROz9/SnPpvLT+ZG17nShe50 rVtd7D5Xu9Td
7vd6hVzwRg2wl1tsZMt73saiF7LqNW963bve97Z3Mt8Nb33xxVF+key0qkWt aUe7X9IGGMAD
/m+BUytgA/v3wABurX0d/KucFnSnwXXqcCnc2wvzVsPAtXCHhfvhCoMYwx6W oXEffOI/WTW/
ZtXrXVks17q+NcYtnjGM8WrjF7vYrjXWsYxv3GMa/5jHQxZykR/SYBQneUjj PR/J5Ptk9kY5
vlKGb5WhPGUsW1m9JlZyl3V02RUvOMGrVXCZyf985v6imb9rRrCY3WzmNMfZ VUj2cp3hUznZ
hljPIxbxhom7Zz9nmMN9HjSgC81nQ/95vnZm9Arlc05BpfO63c0udy096UtX GtOb1nSCVDgF
ApnNDwaic6NNfR4mC0uwWb6ylllN5VbHGtbOMear01ueIzFG1ulbC3S4fGpg Bwa/wdPvmOXc
ZjizmcBvVjOym73sihx72YhbC1IYM201+2HUUSl1sL1NGCFJ+NCBJjGizU1u Qisa3YmmsK4F
rW5mlQcytU43bXttm19/W994UTGxc0zkfxt5xwL3ccANPvCDFxzhC1d4wxvC GIYHOeFlvbdF
Hi3xiOMYH9reK333/fH/vqTahU6eta1dffJdo7zkKr8MvVPuSVx3xt0mn9O9 rZNvkOf8LWD2
N7OlbWxlA93ZP/d50Iu+ymgffXEHYdRGalXtpTz62Q/5yUk5HpJu61zr8TFM ns89brDDW+zv
Jnu51/11bGFOIyCJVtVrpxLj/MRZLEFBduR9GsylbiDQks0Re80ZnG8958oN M6cpffhMI97w
iWf84h3/IogjBAX3mfyJfnK8qlcdQJe3vEYudO/7XDx6A/lQTKbL8QBlXfA5 FzmwVs1y2L98
5bKn+ezD5nK5514gj8kITPZOd8OwPfinqfvaf+J72eReI9MwSPAPEtUp5Np+ yZd8841/fI2Q
/6bvvAb1ZwK/+n0Pm14eVbrQsU30ZA/d6Ok///qhEu2GVN4j2V8I3UfidI28 pCAukf9PHOIS
yesJgqC7qtiI/su/A5QKqCOJawsh/qu/mbC//8s+AARAD0I9kVA98Nu3CAus CTO7sCu7egPB
sSNBEWQ3Eps5uHO+3su8yHDB4ru+GMy+F5RB5ouN3ovAG8w8t5uJu1uNHMK+ 7Bs+GJS85dsh
m6uM79tAb+s33nijUSsQypCPBtQZoZgLKQIyjXO4LcQ4LtRCMAS4jAtDgvNC M+xCL4q8/KO/
7EMZgZg/jIg/zwvABtE8AhQQ/7u8O/S8PVSIgQCY7rO4gVOJlaA6Gv+kwAGc Q4zjOJTRQCb0
NpGDtH/otbegRGKRiLtordejvdizvdr7xE4ExS3BvRo8xKrbQd5LReVzDLkb wiFUvhiMxRtk
xeVrRSNUwuiTOfdpRfszwr7rxUP0GpuTjCV8xFPjudrAqkfhOGUMCqEglGgb CrPQtkNpRvSb
uvLLRvYzP27URmxkqaRLxJYYwDc0vgisvIwQwP8jvZYwCJnIiI44x3JUiXh8 Q4NICqh7uFeS
Pwq8x+uDQCPkpaujCUc0xlPDM7hgoe+wRP4ANUy8xNzQRLUrwRGsSBS0SLQ7 wYw0QSFSuxDk
yOC4u8fIOx/qwR4sRWz6O8goRoNkNMJ7C2L/2TwCYUb9oMbfERI8TBBqxEJl 7DTF88nGA8rH
+0miDEp/UsOiHMr8AD3MqCfTu8X/4LzswcD9KMiWZLRIJLnd6wyGdAxLfMgP fL7HkEhPDEWz
5ES0LMu0bLm1XKiYi4yZO8sxGUYf9LirzDnxIw798seGoMm+fEZMtAmGcEeG 2Em5IL9t9MZr
XEz3Y0z1e8z2Ixz4g8xuTIgFJIgGVMySwkBAvEvw68Bk1D6QGEuHPI2vhMgX FD6ypMiLbM2N
xMizi82PhM1vikvXlM0fxAzW7K0khD7PXD0n1Ev9sBCEoMn7sEkqxAw8LEf8 MMy4yEIx/MLo
PEMynDg0rM4xnM7r/9RO7HwrpOxO6gS4imtK6SxDOGLEA7HK31SyrFyOrYyM rpyG03xI3jtF
XlEMkhNFtdxP/exPubS1fxAZAQUZAg2ZXITLAU3QAr2Y7rs5u1zPb0NG4dQJ pyMJ4yQIaoRG
wdS/qXBOuEClxgxRytTMEU1ME/1GFMWUKSgPFl1RF21RGH1RGY1RGp1RG61R HL1RHW3Ro9hR
H81RIP1RIcXRq1BPCD0xhITJibSMrrwRiHzI4iDL25zNKd1N2bRSKn3NKtXI K+XSLM0cljzS
B3vJ0JyQC52MKcQHnOwQD30LSRNKOE3KODVKOlVKO53TO5VTPa1TBjFSMbWv 9uSS+JxPYv/Z
Ein9T0RtS0Xlz0Rl1EX1T8cK0z+tr7w0CYwZNYQBzCe61Gp0zMj81MpMUREF VRIl1RP11FBF
1Vzx00kFL9BsiymIVVmdVVqtVVl9UlvN1QedxA+kTSz9VS8FVpDc0mHVUmPt 0mIlKkltVeTa
VAV91gWFVmmNVmqdVmutVmy9Vm3NVm7dVm/tVnD9VnENV3INmYVgVWZ9rdZL V3Zt11Eqzl11
1yQrJVMV1RK113pV1VMd1VTl11Lt13vVV0dBV3mlqspJ1i9NWGH11WBtWIRd WGJl2Id12Gla
1oI1WNHj0z3NU43tWI79WDwN2Y0VWY8l2U0j2Iu1qfJ51EaFVEf/fVmXjdmW nVmW/R+LTVmb
OiB8Bdh89dd9DVif3dl/Hdqf7VmgDTCUxVmBUkiFpdiIfdpjbdqJnVqJrVqo RVarpaabVdql
nczsNE/w3E6w5U6yHVuztc6wTduyRdu1/Vq2PVu3jdsb4VovW1mYpdm7rdm8 3VuZ1du+vdut
pdtxoleeLVyiFdqiNdzEPVyBbdygddyjJYqkFdxhOtisxdqrldrL1dzMhdio 9VzM/VynXTTK
RTFzMlnUHVnVLdnVBdnWTV3WjV3XbbzJLV1Rsls8SYVC0II/4N0/UAW/xdu/ HV7hLd6UI0Tk
TV7lXV7mbV7nVd5cK5sGbZLAtV1R0tkJ//pdy9mGVPhdxn1c8I1cxUVc8oXc yEQBsvED/MPM
7yWcgQSL2rVeQ2JaaVGFUTOJbYDI7hVdqu3c0Q1dAOZc/mVY9PVfdlkLWyTJ /mUdlWyN6pXf
+fXaMlKFPzgW3e1eWKAIWPgDuC3Pt/1guQ3PDhZhEPbgEBbbEnYr9FXbEdY2 qZRgEj5hZxyk
eIXgvsLdAMLEP9jhQvADHqaI/SXe4B1ivjXeItakAjZi+JyCGcRhv6VL76th G54qwm2VK5zE
QtBeLP7dtiiE8TXfLw5fox3jMBbfXkpiMi4cF7Y2MR4hzixSKZ5im7Jc7kiF xZCIP/ADL8ZE
38XEVFAFA95c0P8V4AAeZEP+3+5A30PmFgSeN2F1O2zpTcCLYznOqNMNEUDm DeLI4lQ4DD+Q
XdidXVEOZVJ+XVNeHvS9JwvRw31y4VCTHriDZeWhSlKj5EoOKCeWEi0Ay0vc YN5NDjzOYCIW
4iMuZmI+ZvhJ4v9xwSPcPkZCYOlL5keyRauBYge95ePC3kypYL2MCArmYb30 YjNeXHIu3zZu
3zQuZ81KZZaq0EQ0wAVb46jzIHe2CMJUiZc4iHT0v755X62IX2wmIPq9jV1+ Umro3T/oZP1V
aEFG5EVu6AUuZIdu2CTmJpNkvh4cokbGu9Y5ScmwPyLsDBhMnQbGjQcOaIGG 4S7aY9T/9GFg
vsQ/yN8YNmGanmmbRmEZbtuaxumdZuESXmEx5Gc+BMAydGX9UGk6Emo/zEEI tEO4q7wWo+VG
tGWUFqZcphIOftLu1QLlfMisHmYlDmuwHmtjzhJlxp8mBj5qlh9o1sX2aWJX BEaQlrwjWeu5
nF5fo+qqvt7M3JRC6GZeJg61QOcyTmdzHufDNmwwRgs0/igXrEeZkmcG/KCq m8AJND0J9EN7
VscJemOs0+u9PiQ6jhYO5uUdroYnzeoBDmTWXm3XluiIJmSfUuSiYrtVBKeN BkLZgbvrM0VW
1Gd9bh1JXknQDu1CumQPUYVOFmyX1ks7PuVRhu5SBmXprm7Z/2Xn6V4Row49 6oYRWk694jZu
JrrqLEnoS6Rgrj7vPyBrZGZvsS5r9z5rIW5ruGxvXqmSkxbv3dHmUCmE5Y6I bahEL07swi5w
wj5wdT7nBNcIqVvsV5FnfVxwvfFnbgtv/U6hgSaX7gVmk4AFgWlt2IZoEQdx 2X7oLa3oEt+W
jR5JEneWksY3C7/wAnqirtrgP/BvPU6F/PXpnB5hnr5pHu9pnQbyIf9xI78j oPZx8NxuzAhy
IJfq9IxxGR8g8g6TDGZo985y+N5y+0Zm9B1XMB8YJo7mYbZmYpTyKRefKpZw A2dzBCfwN3dw
OAccFBhSOw9SPL/zF63nSQxzP9+2tP8A6DQ3m9EO8Raf6Ng28ddO8UTfnOd9 dEiPdEnvQV2t
dEu/dEzPdFuNjvwe9LJB7uju7lAf9ewudesm9VM3dVF3HkH3dKqpci5/7y6X dVrX8lm39Yrq
dFefGv5WbAWfc2CXc2H/9WFH7GL39blp9V2Pmgwf8UVXdEN/dkR39mivdkan dmvR9WVXGhpP
4SMvcif/diUHd3Ifd3P39nBP93JH93UnGmXfdqSB9VuPdVyvd3q/93nP9z1B c3g/mzUPdmIP
eGMXeGQv+DYH+IFPeMnl937/dHo79EaPeGyH9muH+ImfdovfM21v+HsBdVVH 9VVPdZEPeZIH
eZP/eDx9d47/rxd5r3V8d3l9t/eYf3lc3/iVp5deP/hj13mC53mF93mDj/Oe PzCVv3lhafaM
l3aJT3prp3inx3ilv3gisnmjD5Zu73F2P3es33oh1/quz3qw53oi9/qxD3ua Lvqq/xX59PNy
bXu2f3u3j3u4n3u5r3u6v3u7z3u891aGT3ukyXPA1/PAH3zBL3zCP3zDT3zE X3zFb3zGf3zH
j3zIn3zJr3zKv3zLz3zMx3y/73zP/3zQD33RH33SL33TP33UT33VX33Wb33X f33Yj33Zn33a
r33bv33cz33d333e733f/33gD37hH37iL37jP37kT37lX37mb37nf37oj37p n37qPa9+679+
7M9+7d9+7u9+7/9+8A9/8R9/8i9/8z9/9E9/9V9/9m9/939/+I9/+Z9/+q9/ +79//M9//U//
gAAAOw==
name="withGrabXCDOGroup.GIF"
filename="withGrabXCDOGroup.GIF"
MHO+3Omyp0meP322DEp0qFGaOIEetalTKNKmRZ8qleqU6VSrVZNmhbpUa1Ss X7125Uo1LFmw
Y68m9POvrdu3cOPKnUu3rt27ePPq3cu3LrW+gAMLHky4sOHDiBMrXsy4sePH kCNLnky5suXL
mP+lmpK5s+fEfx0S7Hhw9ETTokOWVp2QdOvTrFFHlL3aNe3XqW3H3q27N2zf uX8LD058Nu/h
xoEnR16bOe7lxZtHfy4duvXq2Klrv839+PTuyrOD/3c+/rv369vPi1efPnx7 8uzLo5e/3j39
9+btx/fuh+3n/wD2Nc0/B00TkYEFHqhgggxSg6CDC0LY4IMURljhhBZmiOGG EnZ4oYcagsjh
hySGWOKIJqaI4ooitniiiyrCyOKLNMZY44w25ojjjjL2eKOPOgLJ449EBlnk kEYmieSSQjZ5
4mYBRillXf4QSE0VMFABA5Zacrllll92CaaXZI5pJpZlovmlmmyu6WabcL75 5RZzzkkFllvc
CUOeeOqZJ51/7knFn4MKSuifVRw6aKKLIupoo5BukeikjlJqqaSYXproFphy WsUfnnIqKaij
ekrqFqeCqqqoq7aK6quuxv8K6xaAzApqrbe+iiutuvYKqiG87gpsrcNuUeyx fwBryB/EJmus
s8sqC22y1EobbbXYXqttttxu6y0g3hoSrbjJkivuuOj+ocq556p77rriwmuI vPS+O++96+aL
77769svvv/4GbAgs9xK8rsED3xtLwQonvDDBsagCscSGRDzxxAtbXLEqEXe8 cccchwzyyCKX
TPLJJnMMS8crq8zyyy67vPLMsdA8czU33xxLzdXsDEvPPPvcM85A/xzL0Ecb jfTSRzfN9NNO
Rw311FIf1N+UWGdN4D8GqgCD12B/LXbYZI9tdtlhZ+m12jCw7TYVa8PdtpZ0 tw1m3WLmHebe
ZYr/qabfcsYpeOBu0onnloVWkfjihhcaqKKADio55JMzeqjlmD+KaaSZN3pp qJSGKnqnnf6x
qemcpsrq6qnb6rqssL8u+660+2rsq8D+ivvuxNIK7e2ATGvts8NHS3y3yHub /PLKG1JItM+X
m2671Iv7vPXxXq+K9vbG2/2/3gssPsDkj38ww+enn7D6BLc/MMcOv/8w/LDQ b//8+JdcP8r8
p3xyyyMDoABhVjMC2qyAB0wgAheowAYy8IGwcBCUtEZBAP2FIF/TUgbbpgIN dpCDHtTgl+Zm
Jr31jW8lJNzgVqjCwsmJT4LqkwxjaKgaQs5Qk8vh5nbYOR5q7lKey5QQ/zUl qk2RzoifMhXr
kti6Jr6qdbGLouxWtSsq2q52ucri7XTXuy4+y4vLalbxhHc84zWPeWg8Y/PM BS7pubF60+ue
9O7lvTrS8Y7mK58e8ygwhOkLYYBEX8UYBrH4XWxjh9SYIk32Mf85sn+QFNkA Y1ZASk4SggjE
GQOLxkmheTJooFSaXvyDFz/8bJRHG8jVKsjKzgzoIGT7QyqcoQpV/IEUVagC 2s7Gy136kpdv
i5sw5xa3u9mtbl5CZgpPyMwzoZCF0NzTC+ukuMZFzpo21CEOKcdNHXLuh+D8 JhGRWMRyig51
5zwd657ITim6c4rwdBUWt8gr3dmTnsfanfGCN//GfhKvjGkMqBoFGj3nxfGg 2rueQefFPTvW
K3x43KNE+bgvPwoykOwjZMLct7/3te9+8gtpR/env0eaNJIGTKklI2alJ3Fm RZupGddMFFNV
HGSCrcxpZapEEC/ZNB+0BIQtbfkHFJpwmV9ySwujyVTCGU6aM4ShVP3kuKp2 83Lh9OE3xenD
cQ7xq6NjIhJJJVbVOVF170xrPWc1z7barljC4lU+wcisL/7TjGT0FkAHyleB JquNhgCsuQZ7
UDfKq10PjahD7UXRxk5Ujxhdn2QXpr6HDTKRFFskZjEmskai9KSg/Z9KK0na ATpQZzxDrdFC
2UmieXJpSpOa06zElKv/HQQFuM1tblXph6P9Ayv9SSU+VqnT4kbmL7D82hac kY+DqIIUf4iu
6XQpNrj0Umxqawt25RZMYpKQbmtLJlKPSl45Aa6p6KUmVBmHOGxWM5uH2qY3 r7pVrdq3h0D8
KjnTaU50+nedZo2ngNUqK7dqMXdrzScXgXc7ZfnOn3jtp1/7SuFuFbSghH0j YRVaru1lz6EN
jai+IOrYEkP2oijOKEcvu1GQjtTF9+vsZ2d80kvaOKWnnWlEIkQNKBlIt0C+ 6RRkGhHcSsjI
PR5yBJNs3CY/JjTUyGAqCFINWjIrup/K5QfbgqW2KNOE2m3mUdNLZhe2Sap2 iipVrylf+mqu
/3JZxa8Qg+jVzx3RnKXK8xOZ2E4AD/jP8nSdgdc6TwTPlcFhRHRdI3xX4VVr rxOO9BrDVVg4
zhFel/5eYutl4k5L1KIZDfUgz1fIUiPy1JpFNSNpzOoai3alMistJn+WQE6q tpNBc22uZ1ue
qxEEBbABtj/6c8qO4PbXKDBIcKtREOI6+dmIeSU1wOaMZtCSqNG9053C1hav dVu7//jaW8Td
bRi8xdv/UEG4qXBuc79FbuNmt1vW9hbxllfMRl2qvln41H5Tk73vfe/jtOnm +c5XzvWVM6WC
GFY8n26//z2rnwkM6NkJ+q0Yv6eh5cpxRns8r46usMglXa0LV3rD8f+SXkJB vFgSM/axnvYX
qCUb2ZobssX4EymMc05Sj/U8tEAf7Y1h3VINQem2EQJ2kmVKId0eKKZLxim0 p06YKh2ES85g
NtFoXY2QwQJMXna3vMH9Dy15Oczalbe7uYz2cHPZ3VUI85baDvcW+lvNeIdv m9scKTgnPM5z
1q/giRhWshaRrIifeJ8pLsUqXvHxWoxrrSSPaI6L0a4fl3CEST7yb1Fawydf 1mHJtWlNmz7m
ME+9zSsrSMu6PrOwx2zGYD8yzwb99pAcuqxXetrU+n61wMe10oIvtdgu7R9c 8TU1lC4RpS/7
tyHBbUWWbTVSUv36gPlL177mjGNge7rblhv/upWq7nCPf95eLv+7065+t6hd 7doFO1zirtR7
I/Vv+84/v//tXoBbde8F92aA93d/Z2cG6HD99XASt4AVx3gCNmhxpXG7s2DD 8jsVCGEgZy2c
t4HNY3Kg94HnolArx1Atp1jgk3qoNz6rR3MoxlH0c1k7p3M8lzI/12r8A0CS JHQ6mEBW0iA7
Ng1Ht3wdgnRAqGRFt3y7hSBQJ0GcgX1OyBcXFGUdlHVcR2sgowpbVnZ2Q3/y RyZ05yVhx4Vg
+A9dRoZyJ4ZrMm7p9VRqMlV5N1VsdkNuhnD3BU4LN3h42HCFp0RNxGcBhlYN +GeOF3mQR2gT
WHl0lYiNhoHaAmmd/8eBbyRYoQd6dJRpJVh6KYiC5DNzK4gwlLVRLPZ6m6Vq nOUxNoh7/qN7
qvgyDaRJNiN8sPhJxFcNyLccpjFcbPFrr6GLuFhsCXFsSDga1IeLT1iMeSFt YKMKqUAKefAH
2qZL4ldd6TY22oVuZFON1SiNYBN/8DaN31Z29BZuxmR2Wqg3X5Zv+JYmz6R/ TjVNhxNw/ydw
VjU5fBeAOkSH+FgpgqeHd4YqEKdODAiIDjiQF3dgGYdPvIOQ+5SBi7iIkPiI fOWBlgZHI7hQ
HmaCmChimoh6nJhiLEhqoPhR8yOSMliSNSgxqMhqq0h0BZIKfuCSLikhQch8 D6J0UKdjSP/m
IEZWhBEjZMb4k1RSi1xCBdTgDLgEflzyQeSYN2k3d/XWlNb1dmWoVG9XlW4x lWQnlerVb1T1
hv9nj3VIgHV4h3WGh/uVZ2PFh37oZ1AUiLEziIZIiHLJYJR3aMjSLJeXeXvl iA+ZRoAliSCY
YYjFLqRnepf4cpmYmB4ZWZ/oiTeXapAZe7Y3e6dYmSazkrs3a5skNLcmi601 i05jfLJFiwvx
kqaZCtBHjLcFZLuFi74FXL3FbMQIlLQJF8g1bWLzB84wCs4IjR30S8DpXRwk nNxVnMUEXm1j
b+g4XuuojmXWVHfnf/0XhwRncAGYj2KZOWQJVv2ITqWjgH0WkG7/OZ6BNpcR mGAcR4EdBzwM
qZcQ2ZcdCD2TSJHVc5H2+S4hxmkaqZgm1omLGZIsRpIvNoMEKmMpmZKYeWM5 9iBxERE+tmM8
dpMQOoRCVjM+WZsYujUCsUFZUkvOoCdwE0JbeEzMmY73x47PqV5t6CdpRkNw CF/WeXCQg51d
VaNlGTr9eESJ14d/qHgE+ZYFGZdCep52KVeLZqR52Z7ZwpfvCZHmUi2CGaXo UonsUnqHyZ8b
KUh/9J/r0piP6TCSGZmlCD+WWaY4qIOxZloQ5IqZxJms5ZlJ01qzBZOnWacu yRZ0mqd1akq0
qKd+Sn3DZn0Z+pPIeF3BeaiGel3dtajF/3lMx7k352ii9pei+/eOULVe09le MDpwYGmdNJqP
23mWopo6/yieEvejgQiXhXaQG6eeveOeSqqBTQqf2SKRUqpyKReCH4ZH+YmY voqlKvgv/qli
AWqSMTig8tNZJ1mml4mmmdkyUxCt0jqt1Fqt1jqtNXOt12qhTDaotGl1V1Ki 4mp/5+VMlIqi
W9mibuiiX1mdM/qu2WmHNmqW3JmWOqqWPboqbYmqVlSeQ1qIcJWQRZqkScqI jzarCAtYUDqf
GTZ6omeYGPmrWYqlwzpqk/WYYZqxszemlHmgzPqsztp7OfN7sfimuiaarkU1 KjuaLLuyU1N9
3kqb2oebiFqziv9qnMQ5TG9jTN9lTJK6nPh3rtDJf5oKj9jEqfQIlpbjd2HZ tNopRKCTo6Pq
j6RqqotHnlgLgYfYqgjZRRb4YA0JqwhLqwaVLBjGsAtlkSNopfspscB6YqLm ny7oesZKoDJY
Uh/brHoLsrCmmSLrt4ArskwYs0AZhc1xi7aYuIeruLvIuIi7uJDbuJH7uJJb uZR7uY6buZOr
uZbLuZi7uaDbuaH7uaJbuqR7up6buqOruqbLuqi7urDburH7urJbu7R7u66b u7Oru7bLu7i7
u8Bruc5GuE4obcWFmkriJMl7JMrLJMz7vMsbvc4rvc1bvdA7vdhrvdR7vdqb vdz7vdv/G77e
K77dW75HInXEi3089Rc6xRZmoRZnIRZlkRZbAb/2W7/4+775S7/627/8+7/z G8BoIcDyO8AG
XMAIHL8KfL/+S8ALvL8OzMAAfMAP3MAULMEOPLzpS3W3ebwE8iA/OKEU6oM8 VsIkfMIjnMIg
bMIqLMIrjMIv3MITGsM07MI2PMM3DKE1jMM8rMM5HMI9DMQ+HMQsvMNDfMRC nMRF/MNLTMQw
zMRP7MQyjMRNTMVRbMVTrMRXrMVZXMVcbMRfDMVdvMVeXMZbjL4bPHVQVlzu ex9uvB/6Ecfw
Icf5Mcd2XMd4PB9wfMd6TMd9zMf1Acj48cd5HMiFPMiGTMiK/5zIjIzIjvzG ftzIkCzIk3zI
lUzIGpzGz2a8OoW84/vJ5ku+4AvKoxzKpCzKqHzKqmzKrFzKrpzKrQzLr7zK sxzL3arJVAeu
bEwgFTzBCYzBFwzBwWzBvyzMxUzMvRzBxpzMw+zLzHzMzgzM0KzMyCzNz3zN 1pzNy6zN1SwU
mYzLxjWzHozFYGzGY3zO5UzG6ozOYpzO7CzF7hzP7TzP8EzP5GzPYVzP+nzP +5zP/PzP/hzQ
5izP/TzQ+GzQBb3OBA3QCE3OaAzO4VyLcmGnFP2nFl3RFG0Xbey7HB28v9u7 Ht3RID3SH13S
Im3SIZ3SJH3SLK3SKL3SLt3SMD3TL/9d0zJt0x79zRCdU5wMF5uhrUAd1ELN vnThybZ81LWc
1LK81LTM1Ejt1Erd1FL91FMd1VR91Vad1Sry0DudU+s70YIqGUQ9F+4bzdt8 1t2c1mat1tS8
1m7d1nDdzHE9zXJd13R919iM1m9t13nN1nzNzXuN1zrd1RXUwXGBU7+EAqBh F8i70AKt0AcN
2Qn9zgwt2ZVN2Y+N2Q2d2Y692Z5t2Zwd2ZoN2p892qbd2aSd2qct2qiN2VxN 2IUNfWCtVCP0
QW2j2Igx1hPNy3tsyb29yI/825Is3MEdycVNycR9ycNt3Mp93L7N3Mkd3dA9 3chN3c9d3dh9
3doN3JU82LD/nTU9/RaIfV24fRi6fdg9qNVVDdXsvd7ujdXtDd/vrd7yXd/0 fd/hmwpXrd/z
bXRN+N06pctxQVxlEm5YUt6Gcd5wsdF6PdcLvFt/3eAR7td4DdgObuETHth9 reEYXuES7uEU
vuEXnhUE8uEkcZsmLsHeDeBSIs6H/d9lY34wgOCFoeDi3YMnzJpFlpNIqHQ6 3uO7teNO58U7
ydpGPtmtneRHftlKjuRLHtpOHuVM/uSl3eRTLuVQfuVans84buVA3OVUrtCv zeJTEoWzPW9m
p34qQOOEYeNusdGQm5NI1pqrCWw5iQ9GhmSIC4xI6LlGhtM0fdOCHtOEHuiF DuiI/z7ohr7o
iX7oit7ojJ66bsHfO/bSM+wWjj67K07mABLekw7j6eaNYsPmg+HmbWHUJFLk uPVjfS6Eq17k
fb7qSad005Dndu7juvVjQR5ksY4Cup6Etg5sv07rvF7rQW7f8Y3f/b3syM7s yt7s0P7sRYK8
W4NcW6Pf0NsWobE12i69VTAFVBDu4D4FKOAHW/3fnE5BXz3gpNRlSfUlpC4Y pv4PZU0TRiYQ
0ufqPo6E/nDvA2HrMgGM/X7ru5XveI7r/858xwZkA48Q0pdb+J5s/n7rDWHr Fc/hKZ7xId7h
Ip7hI77xGo/xID/yIl/yc/1bblElbaHyR5GnRHEXrmERLv+vE4CAB35ABTdf 7lux6enuGYbt
0zBubtU16otdF419wz8uhD2+mq3O9LwOIXJ+6zsW9TqJ8Lre5whC9VpPk00f 7FUe5quN5V8v
9qrt5WO/5Wef5Wqf9mxf9mDv2NUe939B6UAMk20Rw9ae99duwnYP5hD67eFe 7l485j3/H2vM
7lQZd+JmN/EeGPMO579h8UVW507PfA2PZKnBmsjmEKwJbAdfEJ3f8KPR+V0v 9atB+kDu3Nwt
3dm9+tbt+q2/3LGv+rK/3bUP+7ZP+7rf3Ly/xwch99W+Y8GBmrztGsCf99NB /M5R8zqPyWFd
+FHi6aeO7kNffjNe9EWd3hayk6r/DvVQ7+uwbusfgmQ1SetIeCFzzvVNb+we ourgL+w7viFB
Lu3JXv/Obv/Rjv/0f//8f9UJkQoAkYqaQIHUqE0zeDAhQmr/GCo0iJDgQIrU 8BWEmJGhw4Ud
Ixqs4sejRo+ppvxDmVLlSpYtXb6EGVPmTJo1bd6E6e+fwZZ+/KSsAoMKjKBD g6LACbMhzJ8W
qflLCBXfUxQonlKrCtWq1qtZq17FajVrVKdfr041qxUFVINW8Zn9OtWfWLdU t1pc+1Xt3Lt0
DXK12haFXLKE/zplexas4sRSFztujLjwY8mHDTOeHPky5MydLVPeXBnzZ82g TZdG7Xn0as6k
VbdmLRr2/2zZtUPfPv3adm7XvWPjTu2bNnDdxIWL5sn7t/LDwZc7Hw7WZ1Lq 1a1fx579ZUOE
LU2mVAEj/HjxMJBq3xkz1c6EGROaFYy1/fvAVe3XD/xQsP6w+u8HDkuh/w6C TzD74kPwPvoO
NBDAj+Zzb6T2+HtwPgojrHBCCDHk8EIPN/wQwhAtBLFEEU0k8UQVU2RRwxVd bFFCGTOcsUMU
YcSxxhFzpLFHG1/U8cYggfRxxyFjLFLIJFX0ByMjl0Syw+/Qo7JKK6+8qaGp evoJy+1iamoq
g8R0asyEyETzTDXNZLNMN9NsE84315wzTjrlxPNOPe3ks04/8+wT0D/3HDRQ Qv8FRfRQRQ1l
tFBHE20U0kcXnTRSSiXF9FJNLeW0Uk8z7bM9UD/dlNRIp/MyVVVXxW4a9rw7 iVWVlnppvZEe
wvVWXSvMldddSfI1WGCH7ZXYX4tF9lhlhU2W2WWNdTZaaKdtltpnq8X2Wm2l zZbbba31Nlxw
x+2W3G/LRfdcdcVNl911IZpSVnnnpTclnbZkyQ/odtv3MjDZe6445aLrd2B+ BS44YYQXPs64
gBs22GGCGX644okhVhhjii+2+GCNP+5YYo9DjrjkjEk+mWOVR15ZZHxQrTdm mbFsiKeZb7L1
yR+j1LlnJXfmEegjg/aZSKGhJPrnonlWummjl076aaf/mZa6aqqvjhrrobdG muujv4ba67C7
JhvsG+O9OW21k2oIqrVpCpOsNhMjk2653bT7sLnpzHuxuvkGfG/B8Q6c8MH/ PvxuxA1nfHHH
FYdc78Yj95vyvi8v/HHJNa98c8sz/zxxz0fvvHTMRTcddNJPn3x11VNHnXXO ZQ+9ddhtp931
2F/P/fa6YX47eOFbctXm4V2y1V3lzV2+Xeafdz76d6Vvfnrrq8ce+uu1z556 7r/3Pvztxe9+
fPOVR/t49d/Wyfj1VYo7ZZbnd9nkjem3H+SW80f5/vrl/5//+Lc/AA4QfwVE oAATqL8DKtCB
DAwgBA0YQeC9z4Iy4w6tLviP/+SJbWpZA6EHrRbCso3NbCMUodZK+MEUkvCE KnyhC004Qxau
EIU2hCENbxjDFvYQhzJM3waFyCotafCCcevUqJRYqiUmkYlPdGIUTTXFJlIR ilaUYhW1eMUt
ZpGLX/RiGLE4xi6SEYxUrOAQ1eil4hnRgh0kH/jOJ8fy1ZGOd4xjHueoRzvy EY97BGQfA/lH
QRaSkIQM4hoVSaV7ufF9TZHgAvsXyQdO0pIErCQmKbnJSzaQk5rsZARDOUFS ShKUp/TkKE2Z
SlTeJo2LhCV2aubI9a0nFX64ZS5xuUtd9pKXv/RlMIE5TGEWk5jHNGYykblM ZTaTmc90ZjSh
OU1pVv+Tmte0ZjaxuU1tdpOb3/RmOME5TnGWk5znNGc6v2mQRMbSnWz7h9uG 2KV31tOe98Rn
PvW5T36+7ymv7Oc+21iTYr7kPtqB4yD9uFCFNtSQDH2oQw8J0YlKlKIXtWhG I7rRij6onQHN
Z/to2ROStuQ8VIpfJlm5UlG2spQqbSlLX/pJma4ypjedqSphmlOX2pSnNd2p T4VqEICCFJ8Z
JGhKTroelpxUJfZByUGj6lSWdPCHPuThVbWaVa7qMIc17CpYvSpDsZZ1h2PF Klq3qtawntWs
X3VrXHP4UaPas4g1oedJ6fnUpir1HydFClVJakYxltGwZzxsY
Re: adding (horizontally growable) fieldeditor(s) inside a (horizontally growable) group in a prefer [message #18521 is a reply to message #15541] |
Wed, 01 July 2009 11:37   |
hi, I think you musn't reuse gridLayouts (gridLayoutSingleColumn) and
GridData, I read it in the javadoc i think. They only compute their size
once I think.
What is commonly done, is to use GridLayoutFactory and GridDataFactory
(clearer) or recreate new GridLayout and GridData.
hope that's it.
v.
Ralf Buschermoehle a écrit :
> Hello,
> way ...
> // global composite
> 3. Define the first group with fields extensible horizontally ... that's
> ok.
> // compiler
> addField(new
> // cdo
> addField(new
> "CDO Repository &DB:", 50, groupCDO));
> group preferences.
> Greetings,
> Ralf
Re: adding (horizontally growable) fieldeditor(s) inside a (horizontally growable) group in a prefer [message #20037 is a reply to message #18521] |
Fri, 10 July 2009 12:18  |
Hi Vincent,
hm - good idea - but no, that did not solve the "problem" (using the
factories) ...
Greetings,
Ralf
> once I think.
> hope that's it.
> v.
>> Hello,
>> way ...
>> // global composite
>> that's ok. // compiler
>> addField(new
>> least that's the plan. When I comment line X (see below) in/out I get
>> the following attached screens.
>> // cdo
>> addField(new
>> addField(new
>> group preferences.
>> Greetings,
>> Ralf
Current Time: Sat Jul 26 05:14:46 EDT 2025
Powered by FUDForum. Page generated in 0.07276 seconds
