InvocationTargetException in WAS 4.0.4 [message #165035] |
Tue, 02 December 2003 20:56 |
Originally posted by: hungjc.us.ibm.com
I'm getting an InvocationTargetException error
(java.lang.reflect.InvocationTargetException: java.lang.NoSuchMethodError:
com.ibm.etools.emf.ref.impl.RefBaseObjectImpl: method
refSetXMIName(Ljava/lang/String;)V not found) on WAS 4.0.4 during server
startup, when using a new version of IMS resource adapter. The error
message is attached below. The same application ran successfully before,
using an older version of IMS resource adapter. One noticible update made
to the IMS resouce adapter was the addition of latest mof.jar, which is
needed for running on WAS 5.0.2. Can this possibly affect server startup
in WAS 4.0.4? Is there a way around it?
Thanks in advance,
Jenny Hung
IVB3675E: The OLT client/server run-time cannot initialize the connection
to the event server.
IVB3679E: The OLT run-time cannot establish connection with the OLT event
server.
com.ibm.etools.emf.ref.impl.RefPackageImpl.<init>(RefPackageImpl.java:27)
com.ibm.ejs.models.base.resources.gen.impl.ResourcesPackageG enImpl. <init>(ResourcesPackageGenImpl.java:28)
com.ibm.ejs.models.base.resources.impl.ResourcesPackageImpl. <init>(ResourcesPackageImpl.java:19)
com.ibm.ejs.models.base.resources.gen.impl.ResourcesFactoryG enImpl.getPackage(ResourcesFactoryGenImpl.java:142)
com.ibm.ejs.models.base.resources.init.ResourcesInit.default Init(ResourcesInit.java:23)
com.ibm.ejs.models.base.resources.init.ResourcesInit.init(Re sourcesInit.java:32)
at com.ibm.ejs.models.base.config.init.ConfigInit.init(ConfigIn it.java:47)
at com.ibm.ws.runtime.Server.initializeWCCM(Server.java:206)
com.ibm.ejs.sm.server.ManagedServer.initializeWCCM(ManagedSe rver.java:561)
at com.ibm.ws.runtime.Server.<init>(Server.java:171)
at com.ibm.ejs.sm.server.ManagedServer.<init>(ManagedServer.java:280)
at com.ibm.ejs.sm.server.ManagedServer.main(ManagedServer.java: 163)
at java.lang.reflect.Method.invoke(Native Method)
at com.ibm.ws.bootstrap.WSLauncher.main(WSLauncher.java:158)
FUDForum. Page generated in 1.21323 seconds
